Disk Brakes on the Street Roadster
Discussion in 'The Hokey Ass Message Board' started by bigticket, May 2, 2005.
  1. bigticket
    bigticket
    from Ithaca NE
    I have added a couple of new pics on the street roadster web site showing my front end set up with the disk brakes...go to
    www.msnusers.com/streetroadster
  2. Slag Kustom
    Slag Kustom
    hmmmmm looks like a blizzard or is everything painted white with a white back drop?????
  3. Did you do the Ackerman thing to your steering arms when you moved the tie rod to the front?
  4. bigticket
    bigticket
    from Ithaca NE
    well that is somthing I'll have to deal with I guess....Maybe you have some words of advice......bigticket
  5. curbspeed
    curbspeed
    You need to heat your steering arms and bend them out toward the tire more. Eye of steering arm needs to be inline with kingpin and rearend center. Hope that helps. Maybe someelse can explain it with a drawing or something.
  6. Bill.S
    Bill.S
    from NW OH
  7. bigticket
    bigticket
    from Ithaca NE
    WEll now, that is the first time some one ever made it clear to me with that drawing....with the wheel spacers i had to add for clearance i will probably have room to correct the problem...thanxz a ton....bigticket
