mcculloch supercharger
Discussion in 'The Hokey Ass Message Board' started by toucan, Jul 8, 2011.
  1. toucan
    toucan
    from sc
    need some help with a kaiser vs 57 supercharger. has anybody rebuilt one? what type of fluid goes in it? has anyone mounted one on a fe ford motor? i know the hamb will speak!:confused:
  2. Normbc9
    Normbc9
    What I can tell you is that Super Charger is the same design as those used by Ford in '57-60 with their high performance Y blocks. If you can't find any info in your lists for Kaiser, try Ford listings. They put a bunch of those out on their factory prepared cars in those model years.
    Normbc9
  3. metalshapes
    metalshapes
  4. Normbc9
    Normbc9
    Attached are some photo's of the McCullough Super Chargers Ford used.
    Normbc9
  5. jamesdfo
    jamesdfo
  6. olcurmdgeon
    olcurmdgeon
    New York State troopers ordered a bunch of McCulloch blown '57 Fords for New York State Thruway duty. I guess the State figured they could catch all the sports car racers that used the Thruway between NYC and Albany for speed trials. By '58-'59 almost every Ford dealer in the Hudson Valley had a used McCulloch setup on their shelves as the cars were refitted with the spread bore Holley four barrels. Don't remember why, perhaps local "tuners" at the Ford dealerships weren't up to hipo work?
  7. jrlemke
    jrlemke
    The Ford blower and the Kaiser are completely different! Kaiser used a variable speed pulley (like a snowmobile clutch), Ford was fixed. Find a Studebaker service manual for '57/'58 Golden Hawks. They used a similar if not the same unit as Kaiser
  8. 69fury
    69fury
    from Topeka
  9. toucan
    toucan
    from sc
    what is the electrical wire for that is under the mcculloch badge?
  10. RAY With
    RAY With
    I had a 57 with the blower and it did have a electrical varible pitch pulley and this is what the wire was for.
  11. tommy
    tommy
  12. toucan
    toucan
    from sc
    is there any reason i cant run a fixed pulley? trying to keep this simple.
