Gasser Axle Caster Setting
Discussion in 'The Hokey Ass Message Board' started by Lakeshadow, May 22, 2010.
  1. Lakeshadow
    Lakeshadow
    Hello, I am building what I call a Streetrail. 45 Dodge pick-up
    I am fabricating a gasser axle over frame, spring behind, four link front end. The engine will be about three feet behind the axle.
    I am curious as far as opinion on this type of fabrication, what the positive caster should be set at?
    I have tried to make a level surface. The best I can come up with is a department store mirror shimmed up with poster board. I have found that the practice king pins rock fore and aft on the gauge blocks slightly. I would like to know if anyone has seen a Speedway gasser axle off just a little bit. I know I will not no for sure until I find a surface plate to set this up on.
    Info will be greatly appreciated in this anal hour of need.
  2. krooser
    krooser
    I'd shoot for 7 to 9 degrees... that should be enough to keep it straight... but I'm sure others may have a better idea.
  3. 117harv
    117harv
    Diggers and some altereds will sometimes run as much as 17 degrees of caster. When you try and back up if with that much caster the front end will flop over and rip the wheel out of your hand if you are not carefull. As the other poster said 7-9 degrees shoud be fine, but you could go for a little more maybe 10 or 11 degrees as the wheels are further out and it will be easier to steer and it will give you that leaned over front wheels look of a dragster.
  4. Lakeshadow
    Lakeshadow
    Thanks so much Krooser and 117harv. The H.A.M.B. is the place for the facts and insightful information that can't be found anywhere else.
    I am taking my axle, pins and gauge blocks to a surface plate tomorrow. Even though Tim29A is convinced I am splitting hairs again. I know he is right, yet I must find out for sure what I am starting with. :D
  5. straightaxlenova
    straightaxlenova
    I'm running 10* in my drag car, and it keeps it going nice & straight down the track. It makes the steering a little hard to turn driving around the pits though.
    If you are driving only on the street, about 6* would keep the car real stable, and not be too hard to turn at slow speeds.
  6. gladeparkflyer
    gladeparkflyer
    how about a decent camber number for a mostly street driven rod that will see the occasional pass?
  7. straightaxlenova
    straightaxlenova
    I would try for 0* but alot of tube axles have some sag in them, and it doesn't seem to be a problem, but tires will wear faster.
    I run 0* in my car, but a few years ago I raced the car with a bent axle, and it probably had about 5* of neg. CAMBER, but didn't seem to matter.
  8. cafekid
    cafekid
    for a street driven car you want no more than 7*. when i set up cars for for customers i normally go between 5 and 7*.
  9. gladeparkflyer
    gladeparkflyer
    thanks nova! i think ya got a problem there in yer avatar pic... them tires dont go all the way to ground...... :eek:
  10. Lakeshadow
    Lakeshadow
    Here it is. Nine and one quarter positive caster.
  11. straightaxlenova
    straightaxlenova
    Very nice! I can't wait to see it installed.
  12. Lakeshadow
    Lakeshadow
    here we go
  13. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    What the heck is going on there?
    Unkl Ian likes this.
  14. Lakeshadow
    Lakeshadow
    Hello Chuckles,
    Well, the design is a design in progress. A continuing development. Next thing to fabricate will be the four link rear brackets. The radius rods will run all the way back to the cab. They're mounting location will be hidden, behind fabricated cab sheet metal parts, which will bolt on as the rear of the stock fenders did. The suspension parts as well as all the suspension build so far, front and rear, will be height adjustable, at least for now. Until there is a fully dressed Hemi and six speed bolted in. And cab and box completed.
  15. Lakeshadow
    Lakeshadow
    Front end, rear 4 link brackets.
  16. Big Khaunaa
    Big Khaunaa
    rat rod stuff
  17. Lakeshadow
    Lakeshadow
    A revolutionary new design concept. Ladies and Gentlemen I present to you, the first Streetrail.
  18. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Good parts, and great fabrication, but I think the truck will be WAY out of proportion. I mean, I am guilty of that crime in the past myself, but this one seems wacky IMO.
  19. Lakeshadow
    Lakeshadow
    Streetrail
      32.3 KB
      32.6 KB
      32.7 KB
      30.9 KB
      27.2 KB
      31 KB
  20. Streetrail? Really? Traditionally, we'd call it a rat rod.
  21. Lakeshadow
    Lakeshadow
    This is indeed a "Streetrail". There is no other build like this. Seriously...
  22. d.reese
    d.reese
    Wrong lakeshadow, my brother built this 147" wheel base 35 ford last year. Now this is a street rail mate.
  23. paintcan54
    paintcan54
    Well, ah yea, ok, I think? My eyes hurt.
  24. Lakeshadow
    Lakeshadow
    It's killing me to be so revolutionary...
  25. metalman
    metalman
    power rack on a straight axle????
  26. is this a joke??????
    rat rods,shock rods,junk rods.....
    this is killing me too
  27. Lakeshadow
    Lakeshadow
    No rats allowed
  28. Lakeshadow
    Lakeshadow
    Someday I'll have a spokesman too.
  29. Da Tinman
    Da Tinman
    so once you get your rack mounted do yourself a favor.
    cycle the front suspension and watch what happens to your toe in/out.
    what your building is an uncontrollable/undrivable death trap.
  30. Lakeshadow
    Lakeshadow
    It is indeed lonely at the top. The top of Mount Innovation...
