Projects My Willys Gas Coupe build
Discussion in 'The Hokey Ass Message Board' started by langy, Mar 20, 2011.
  1. R Frederick
    R Frederick
    from illinois
    Holy cow, that's a lot of production. Would have taken me at least a week to get that far. That's anywhere from 7 to 12 showers for me. How often do you take one? :p
  2. SOLID9
    SOLID9
    from EuroTrip!
    Ah I see so the belts just go over it to change the direction of pull. 10-4
    Just out of curiousity, Are you going to paint the floors to color match the body or is that going to get a carpet? Just wondering because it doesn't have that finish as the outside of the shell. Is it going to get sanded smooth? I havn't got the slightest clue about fibergl*** workings...
  3. langy
    langy
    I want this car to be streetable as well so it will get a bit of thin black carpet, the floor is pretty smooth but the underneath of the car will be smoothed off and probably stone chipped the same colour as the body.
    Fibregl*** is a real easy product to use if you follow the laid out rules, its very adaptable.
  4. langy
    langy
    Once a month whether i need one or not :D
  5. BACAGrizz
    BACAGrizz
    Just read through this thread. Great build. Can't wait to see the finished product.
  6. langy
    langy
    Thanks mate.
  7. langy
    langy
    It was raining here last evening so i had an evening on the lathe sorting my fuel filler and column drop.
    I found a lump of 2.5" stainless round bar in the s**** bin so managed to get both bits out of a chunk of it.
    Started with this
    And produced these
    I had an old motorbike flip cap laying around so gave it a repolish and made a flange from a bit of sheet stainless, put it together and got this
    Made up a couple of tapped spigots and welded them to the boss for the column support, The bolts that hold the rose joints in place also hold the collar in place on the column, they have points which engage in small holes in the column outer.
    Fitted the filler cap and it had stopped raining so made up the filler tube from some stainless bend offcuts, nothing wasted here.
  8. roll_low
    roll_low
    from Rigby, Id
    That fuel filler is awesome man! Looks great.
  9. langy
    langy
    Thanks, i'm pretty pleased how it turned out.
  10. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Really nice work. You're masterful with a lathe buddy!!!
  11. Filler looks killer!
  12. langy
    langy
    I'm no master turner mate but i get by, thanks.
  13. langy
    langy
    Thanks Kev, your a poet and ya don't know it :D
  14. cruiserbuddy
    cruiserbuddy
    from Germany
    First I have to say: A great build!!! Do Your ladder bars join the frame in one point or are they split?
  15. hemipwd41willys
    hemipwd41willys
    from Wyoming
    Steve,
    The car is looking amazing. Love the attention to detail it all pays off in the end.
  16. RodStRace
    RodStRace
    Not that you need to be told this but make sure that the flip cap doesn't beat against the body when opened - for the rest of us stealing all these great ideas!
  17. SOLID9
    SOLID9
    from EuroTrip!
    This build gets better and better mate. What hot rodding is all about, making something out of nothing... Love it!
    Cheers man
  18. AHotRod
    AHotRod
    Great job mate!
  19. langy
    langy
    Split mate, they are around 8" apart at the front
  20. langy
    langy
    Thanks Ken, can't wait to see yours started, gonna be amazing.
  21. langy
    langy
    First thing i checked buddy, clears easily, thanks.
  22. langy
    langy
    Your dead right mate, I enjoy making stuff and its individual, nothing wrong with buying parts but its pretty cool to make your own and its cheap too :D
  23. hemipwd41willys
    hemipwd41willys
    from Wyoming
    You have inspired me. I am also looking forward to getting started with the coupe, maybe this winter. We are getting closer with the HJ. Still waiting on the motor to get finished up.
  24. langy
    langy
    Its gonna be dead cool to have the HJ next to the Willys Ken, your a lucky guy, very cool.
  25. 41 Dave
    41 Dave
    Langy, Don't shoot the messenger . . . . Just not feeling the column drop. It is clean and simple . . . But just does not seem to fit. I guess I am just use to column drops made out of steel plate. Seems to need something more to it.
    Dave
  26. langy
    langy
    Whose Lippy ???
    Sent from my iPhone using TJJ
  27. tattedfordguy
    tattedfordguy
  28. Jimmy Tee
    Jimmy Tee
    Langy...... Your a Master Fabricator..... Lucky it rained that day otherwise we would have missed out on this great piece of fabrication.
  29. SOLID9
    SOLID9
    from EuroTrip!
    Thats kind of the point... To build something of your own and makeit different than things your used to seeing. I'd say Lippy has got things well covered ;)
  30. 64fairlane500
    64fairlane500
    Interesting build and your ch***is ingenuity is great! Regarding rear end....I agree with you the 8 inch would be a weak point. "BACK IN THE DAY" a lot of these g***ers were set up with a 57-64 Pontiac or Oldsmobile 9.3" rear end. Don't know how period correct your are trying to go but that would be a consideration. Really a strong piece and if you can locate one I know a buddy of mine found the parts for his from an outfit in Texas. The site is fabcraftmetalworks.com . Good luck with the build and keep the posts coming I look forward to following.
