ring and pinion question
Discussion in 'The Hokey Ass Message Board' started by 39RatRod, Jul 11, 2011.
  1. 39RatRod
    39RatRod
    from NH
    I have an 88 s10 rear in my 39 streetrod with 4:11's. From what I have found it is a 3 series eaton posi carrier. Could I put 2:73's on this carrier with the spacer kit?
    Thanks
  2. 39RatRod
    39RatRod
    from NH
  3. Truckedup
    Truckedup
    You need the other carrier......
  4. squirrel
    you need a negative thickness spacer to go that way....spacers only let you put steeper gears on a lower number carrier
    Get the right carrier for it
  5. George/Maine
    George/Maine
    If you looking for higher gear maybe change to another rearend.I,m running a Granda 8" with 2.78 gears.No posi only thing wrong with gears that high you have to run smaller tire.
    I'm running in my 39 ---205/70/15 2000rpms =55 mph.
  6. busguy71
    busguy71
    I got a late 90's s-10 rear with 3.73's for sale, $75, if that helps, I'm near Hartford CT.
  7. 39RatRod
    39RatRod
    from NH
    Thanks for the info. Guess I will try to find a set of 3:23's for my carrier.
  8. treb11
    treb11
    Malibu/MonteCarlo/Grand Prix/Cutl*** and 3rd/4th gen Camaros and Firebirds with the corporate 7.5" are potential donors as well
  9. 39RatRod
    39RatRod
    from NH
