37 ford coupe to roadster
Discussion in 'The Hokey Ass Message Board' started by Bart78, Jul 12, 2011.
  1. swissmike
    swissmike
    The roof doesn't seem like the biggest obstacle considering the shape of the project.
  2. Atwater Mike
    Atwater Mike
    Yes they did. Look in a good Ford manual. (looks like a convertible, but no roll up windows...no wings either. Most had rumble seat)
  3. Bart78
    Bart78
    My first thought on the roadster was not even haveing a top. I cant drive the car to work. I run a landfill and every thing gets covered in dust. The only time i would drive it would be after work. And usualy here you can tell when it is going to rain.
  4. MR. FORD
    MR. FORD
    from Austin, TX
    Agreed. Save the roof.
  5. Bart78
    Bart78
    Would I have more options on doors. Could I use sedan front doors sence I will not need the tops of them?
  6. Here's a photo of a real '37 roadster done by Roy Brizio's back in 2008.
    It's not as hard as you think to turn the '37 coupe into a roadster. You would have to change the cowl from the belt line up, since an open car cowl is completely different. You would also need to change the door tops, and you would need to know where to cut the rear portion of the roof off since all open cars have a thick steal band around the rear opening in the body.
  7. sololobo
    sololobo
  8. raidmagic
    raidmagic
    While that doesn't look bad the coupe is far nicer.
  9. dodored
    dodored
    from Concord NC
    If you cut the coupe up you will kill the value for resale unless you invest the $$,$$$ to do it right. Save the coupe!!
  10. 50flathead
    50flathead
    from Iowa, USA
    Done correctly a roadster or carson style top would be great. These will also be the easiest to screw up and end up looking bad. I'd probably fix the top and keep it a coupe but that's just what I'd do. If you want a roadster build one. it's your car.
  11. RICH B
    RICH B
    Just saying, I've seen a roadster conversion using a '36 looking rolled cowl and windshield frame that looked more like a roadster should than Henry's '37 roadster.
    It looked like it took a lot of planning and hard work to pull it off.
    Personally I would repair the roof, does not look that bad, and build it as a coupe.
  12. alex211
    alex211
    from NW PA
    Fix the roof and keep it a coupe.
  13. JimC
    JimC
    from W.C.,Mo.
    Consider your skills.
    Consider the commitment to a project like this 37.
    If you have skills, money, and a commitment, do what makes YOU happy.
  14. gauthier
    gauthier
    keep it as a coupe... pls
  15. clubcoupe37
    clubcoupe37
    Blue One...love the color of those coupes...especially the burgundy?/maroon one..do you know what the paint code is?
  16. 32SEDAN
    32SEDAN
    Roof is salvageable and is more feasible than going the roadster route.
  17. clubcoupe37
    clubcoupe37
  18. tedley
    tedley
    from canada
    I did a transfer from a 37 club coupe to a club cabriolet. I found a racht 38 club cabriolet and it had all the parts i needed. W/shield cowl section, exact fit, door tops transfered over to 37 doors, b pillars and tub section tranfered to coupe body. Even got the top bows. Worked out great.
    Unfortunatly i had to sell unfinished at the time but the car did get finished, complete with a traditional flatty
  19. tedley
    tedley
    from canada
    I did a cabrio conversion from a club coupe but i found a ratched cabrio for the vital parts. Was a easy swap if you can find the parts. Roadster is a tall order thou.
    opps duplicate wouldn't delete sorry
  20. Remember if you cut the roof, you just lost the structural integrity of the body. The frame will have to be beefed up to prevent body flexing. My .02
  21. tedley
    tedley
    from canada
    Not so much on the frame on this one but the post area for sure At the base of the post there is a 'foot' style reinforcment welded to post and floor about 5 inches or so if memory serves me. Plus the upper rear tub section is fairly stout on the inside.
  22. And just to upset the applecart, Ford made Roadsters up until 1940 here in Australia...a mate has one........supposedly 20 Roadsters and 70 Convertibles were made by Ford Australia. the body shell is the same as that used from 1937 with factory mods to allow the 40 fenders and no windup windows, only clip side curtains. He's had it for about 40 yrs.
  23. old soul
    old soul
    from oswego NY
    Sell it and find a roadster body!!!
  24. heyitsnate
    heyitsnate
    on my 36 i have not done any roof repairs yet, my best advice to you is start from the bottom, front to back. do the work the car needs as you can , and by the time you really need to work the roof the car and the process will give you the answer. there's a heck of a lot of work ahead of you, and plans can change as the build progresses so i would not sweat it just yet...
  25. DAVEG2
    DAVEG2
    Keep lt a coupe.
  26. chinarus
    chinarus
    from Georgia
    Looked at this 37 conversion a few weeks ago.
    Fenderless drop top might be interesting if you don't have much to work with.
