Art & Inspiration Small car fantasy
Discussion in 'The Hokey Ass Message Board' started by 50Fraud, Jul 7, 2011.
  1. MikeyFIN
    MikeyFIN
    Any purpose built Garage made car ( ie. a racecar or a no compormise street car disguised as one)will blow the doors of a factory car.
    Back in the day HO specialities owner had a tripowered 455 64 GTO that with a Regular 16" GTA wheel and tire Combo kicked a ZR-1 royally up in the rear in the Slalom and the road racing track plus skidpad...
    A friend had a 1300cc Turboed Starlet doing 9.7 in the quarter.. another has a 1600cc Toyota GT Corolla doing also high 9s's and still be a good road race car..both fully street driven. The Starlet being a tad radical though..
    An old pilot teacher and rally racer did 71 vette with just a 355 that screams 9000 on the street be faster on a track than the new ZR-1's of today. Although a lot of credit goes behind the well too..he races even today. Still he tells the Vette is clumsy compared to his Opel GT.. although a lot faster.
    An relatively easy task could be getting an old Formula roller and put a spyder prototype on one just like the Sports-2000 racers basically was.
  2. 29bowtie
    29bowtie
    I like your way of thinking, go for it. Of course many fine ideas could come from the cars hiding at your Dad's place.;)
  3. DrJ
    DrJ
  4. Dyce
    Dyce
    I have a little '48 Anglia 2dr I alway wanted to build into a cornering machine someday. It's a stock body and frame complete with no engine or trans. I was thinking about adding about 6"-8" of width right down the center of the body so I can make a wider track width and have more room for a trans/engine tunnel.
    Anyone out there seen this done?
  5. metalshapes
    metalshapes
    Berpop...
    Edit.
    There was a widened Pop/Anglia (not the fenders but the body, like you said ) in one of the Brit Rodding magazines sometime in the '80s.
    I did not like it.
    It really messed up its proportions....
  6. OLLIN
    OLLIN
    Ahem....
    My top 3:
    1) 1951 xk120 roadster...
    2) '53-'55 corvette
    3) porsche speedster
  7. Dyce
    Dyce
    I know I don't like the wide fenders. It would be a simple photoshop. I only have 2 cars ahead of the Anglia....
  8. Swifster
    Swifster
    I always liked MGB's and Sunbeam Alpines/Tigers. I also thought about putting BB tortion bars and a small block in a Valiant for grins and giggles. I can't remember if the '63-'66 cars used the same length bars as the early '60-'62 cars or the later '67-'76 cars.
  9. The37Kid
    The37Kid
    I've had a 1969 Volvo P-1800 outside on the side of the garage for years now, only project that isn't inside. Plan is to put a Ford small block in it, I should move projects around and somehow squeeze it into the garage.
  10. seamstome
    seamstome
    How about a SIMCA ARONDE American styling, small, and light. Put in the drive-train of your choice. Much easyer, and less expensive to find than the OCEANE, or SPORT 8 like in your photo. Just a thought.
  11. refried confusion
    refried confusion
    ____________
  12. Bigcheese327
    Bigcheese327
    1959 Rambler AMX. Too bad there's virtually zero chance an AMC 327 would fit in there.
    -Dave
  13. sodly
    sodly
    from middle
    I've also been searching for the same type of car as the original poster... only I DO want a convertible. Any ideas out there that failed to warrant a mention previously because they were open cars? Is it OK if we include convertibles in this thread, too?
    I don't really need a car that kills on the track, just something quick and fun on the street and that makes good sounds with the wind in your hair. Like most red blooded American boys, I like c2 vettes but they are a little big, a little cliche... and so ridiculously expensive. They do have some investment upside, however (at least till the Boomers die off). A 3.2 911 might be fun, too, as a previous poster mentioned. Too bad both 911s and Vettes carry some unwanted baggage, image-wise, a****st the public.
  14. Bigcheese327
    Bigcheese327
    MGB V8s have been mentioned before, but would seem to fit your criteria well. I find the GTs unspeakably ugly, but the roadsters look good.
    -Dave
  15. CutawayAl
    CutawayAl
    from MI
    V-8 Miata swaps are common enough that you can buy well sorted out kits to install either a SB Ford or the newer aluminum Chevy LS engines. If you really want a top, removable hard tops are available. The car comes with the fittings needed to accept the top. Recent generation Miatas are available with a folding metal top.
  16. tommyd
    tommyd
    from South Indy
    I like that. Boy! does it look tight though.
  17. Outlaw Bender
    Outlaw Bender
    To all fans of the Amazon This is a hartop conversion made by a friend of me.
  18. MRK
    MRK
  19. Bigcheese327
    Bigcheese327
    The 1952 Chrysler D’Elegance was the Ghia-built showcar I was thinking of.
    Replacing the front sheetmetal on a Karmann-Ghia with something styled after the Chrysler would result in something really resembling the Ford/Simca Comete, IMO.
    And it would be a good excuse to use a Red Ram and a five-speed.
    -Dave
  20. Ned Ludd
    Ned Ludd
    That reminds me of an idea I had years ago, a front-engined VW Bug with a wheelbase stretch ahead of the cowl, an upright front grille, and extended/restyled front fenders. As I recall I had VW headlights moved inboard as on a '37/'38 Ford. The idea was to keep the VW floorpan and add frame stubs to the front to carry an engine, run the driveshaft over the top of the backbone, and suspend a DeDion axle off the original rear torsion bars' arms.
    That Chrysler is beautiful, even if it does look as if it has just received bad news in the post.
  21. Bigcheese327
    Bigcheese327
    Yes, the headlight placement on the Volkswagen and the Comete are preferable, IMO.
    -Dave
  22. Greasyman
    Greasyman
    I haven't read all the posts, but someone must have mentioned the Factory Five Cobra. If not, I am. Can buy good used ones for $25k, or build your own.
    I second the V8 Miata suggestion. There are kits available and the car is well balanced, due to the addition of the V8 ****** and diff. Weighs only a couple hundred more pounds than stock. Turbo and and supercharger kits are also available for the stock engine, 200+ whp is easy to get and you have a car that looks like an old Brit but does everything better. I have a supercharged one and it's a joy to drive.
    BTW, that Ford with the unpainted hood in the very first post is a dream car to me. I'll trade my Miata for that - no problem.
  23. DrJ
    DrJ
    Saab Sonnet II?
  24. 50Fraud
    50Fraud
    Thanks, John, but I think an MGB-GT (or most of the other cars in my summary in post #86) would be easier to find and easier on the eyes.
  25. wsdad
    wsdad
    How about a Karman Giha with a front wheel drive cadillac 500 stuffed in the rear. I saw one in Little Rock a few years back with a Torinado drive train.
  26. DrJ
    DrJ
    It was mostly for bringing it back to the top..... :cool:
    (I have an MGB GT "driver" I rarely use...)
  27. McTim is selling one of his Brit cars. I forget if is the Midget or the TR3?
  28. BHfanGB
    BHfanGB
    If you want to go way off the beaten path, what about a Renault Caravelle? Yeah, it had a wheezy little 4 cylinder mounted in the rear but it had some really nice lines that deserved better mechanicals than it ever got. I'd love to see one done up with modern suspension and either a front or mid mounted engine.
    And while this picture shows it as a convertible, it was also available with two different removable hardtops- one that was more squared off that did nothing for the lines of the car and one that resemb[​IMG]led a scaled-down '62 Bel Air hardtop roof. Autoweek just listed one sold at auction in Ohio a little while ago for under $3000!
  29. Jim Stabe
    Jim Stabe
    I've had this MGB since 1971 and it has had a 215 Buick, turbocharged Olds F85, and now is being rebuilt with an LT1, 6 speed and Corvette C4 suspension all around. I had to widen the car 11" to use the C4 suspension. The whole story with lots of pictures are in the links in my sig.
    Small cars with lots of power that handle and stop well are cool
  30. ^Awesome^
