Customs Chevy S10 front clip or whole frame under a 1951 up Studebaker
Discussion in 'The Hokey Ass Message Board' started by Bearhawke, Jun 5, 2011.
  1. Bearhawke
    Bearhawke
    from Arizona
    Has anybody here done a Chevy S10 (2WD) frame swap or at least a front clip swap under a Stude?
    Why I wonder is such a conversion would give modern brakes, steering and suspension as well as easy mtg points for a SB Chevy.
  2. The Shocker
    The Shocker
    Is it a Stude car or truck ? I have took part in a late model frame swap or two under an old car and its alot of work ,but i thought it was worth it in the end personally .A clip installation and rearend change is alot easier ...
  3. jedrattle
    jedrattle
    If it is a truck, it will be real narrow in the front end, and look like ****!
  4. badshifter
    badshifter
    You could just buy an S10 and drive it. Put the Studebaker emblems on it. Modern drive train, old look. Just an option....
  5. Da Tinman
    Da Tinman
    yep and would have more cl*** than the frame swap brand X motored thing.
  6. Terraizer
    Terraizer
    There is a 1951 2dr sedan on a S-10 ch***is on the Denver Craigslist, it looks really good in the pics.
  7. roddinron
    roddinron
    Hmmmm, and yet, it's for sale.:rolleyes:
  8. Bearhawke
    Bearhawke
    from Arizona
    Car like a Lark, Land Cruiser, etc. I would not modify any sort of Hawk/Starlite in that manner unless starting out with a clapped out POS.
    And I would prefer to weld up an S10 front stub to the Stude frame rails which would eliminate fiddlefarting around with custom body to frame mounts, rear bumper mtg issues, etc. :)
  9. Da Tinman
    Da Tinman
    you dont own the car yet? and already looking for advice on a frame swap...
    Ok, dont.
    get a car with a decent frame and use the stocker, its funny they bolt up just like they were made for one another.
    as for the brand x motor,,, if you get a car with a decent drivetrain theres no reason to swap it. parts for studey motors are easy to find and reasonable in price too. They provide plenty of power and will live a long time. Get good mileage too compared to other cars of the day, in fact mine with the 170 six and a tall gear gets 28 mpg and will run 80 all day long.
  10. Hnstray
    Hnstray
    from Quincy, IL
    Depending on how much you are willing to consider spending, you might want to check out www.slickstreetstuff.com . Complete bolt on replacement front suspension, "A" arms with ball joints, spindles, disc brakes, rack and pinion steering gear, larger anti roll bar...requires some suppporting mods such as modifying or replaceing your steering column to hook up with the R&P, brake master cylinder upgrade for the disc/drum system. But, no frame mods, no welding, just wrenching.
    Ray
  11. ckltrk
    ckltrk
    from Peoria, Il
    Hello There, I: am in the process of putting a Fatman stub under my '51 Stude Champ. I looked at the s-10, but thought the rails were too wide. Have an LS1 to go in next.
  12. low-n-slo54
    low-n-slo54
    I can understand the front and rear swap but an LS1. Seriously?
  13. ckltrk
    ckltrk
    from Peoria, Il
  14. catman
    catman
    from El Reno
    ls-1 =serious power
