Cleaning Primer
Discussion in 'The Hokey Ass Message Board' started by 53FordGuy, Jul 18, 2011.
  1. 53FordGuy
    53FordGuy
    OK. I am not one of those **** types you see at shows polishing their car every 5 minutes cause some dirt got on it. However I do need to clean it sometimes. My car is all in primer & will be that way for the foreseeable future, I have 2 little boys who love to walk by & run their hands over it. When I try to clean it with regular soap & water it doesn't remove the prints. They are still there after the water drys. Same if it rains, when it's wet the prints don't show but after it drys there they are. Anyone have any tips/suggestions for cleaning a car in primer to remove prints? Thanks in advance for any help.
  2. Badfella
    Badfella
  3. Spidercoupe
    Spidercoupe
    from Bevier, MO
    what kind of primer ?
  4. 53FordGuy
    53FordGuy
    Not really sure what kind it is. The guy who owned it before me had it put on.
  5. 53FordGuy
    53FordGuy
    I like that one.
  6. bobss396
    bobss396
    I had puked out the window once on a primered car and it left an interesting pattern, so I left it that way as I felt it added character.
    You'd probably need to go over the primer with a compatible clear flattener which would protect the primer.
    Bob
  7. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Wax and grease remover works well.
  8. A buddy of mine has a primered car, He uses spray 409 on it.
  9. Camm
    Camm
    I use 409 also.
  10. Spidercoupe
    Spidercoupe
    from Bevier, MO
    the problem with primer is most of them are pouris [I know thats not spelled right] and absorb body oils or anything else that touches it. wax and grease remover might clean it but I doubt it.
  11. use solvent based wax & grease remover, then use a water based one afterwards...or just wet sand, re-prime, add topcoat.
  12. 53FordGuy
    53FordGuy
    Thanks everyone. Think I will give the 409 a try first.
  13. rramjet
    rramjet
    I think I used Simple Green on mine when it was in DP90. Eventually put
    PPG flat on it. Still use Simple Green or window cleaner to spruce it up once a year.
  14. 49ratfink
    49ratfink
    I'd use fine scotch brite pads.
    don't want to be putting no chemicals on primer.... Ok.. wax and ease remover maybe.. but nothing else.
  15. 409 works well. Your problem is that the little guys have oil in their skin this is not to say that they are greasy ******s. Everyone unless they have some wierd medical condition has oil in their skin. The hand prints are little oil stains.
  16. rougebeats
    rougebeats
    I cant be sure, but have heard many many good things about simple green diluted properly to degrease, then apply Turtle Wax "ice" spray on wax. Makes the prime look new and protects it from future fingerprints. I'll see idf I can find the thread I was viewing and post a link for before and afters.
  17. rougebeats
    rougebeats
    Heres a before and after pic of just the Turtle Wax "Ice" you can pick up from any auto store. It doesnt carry a "shine" to it, but definately makes it look clean. Good luck!
      38.9 KB
  18. R Frederick
    R Frederick
    from illinois
    How about paint?:rolleyes:
  19. 69f100
    69f100
    from So-Cal
    did this yesterday, the rough side of a sponge and soap. then used some furniture polish. looks clean and leaves a nice lemony scent.
  20. nachodog
    nachodog
    from socal
    If it's been block sanded smooth go with the Mr. Clean magic eraser and probablly 409 like others have suggested. They work pretty good on my skinny whites too.
  21. unkledaddy
    unkledaddy
    I use a little 'Awesome' on a damp sponge.
    Available from Family Dollar and similar stores. $1.00 a bottle and it removes blood stains!
  22. Yea but will it take the dent out? :eek:
  23. R Frederick
    R Frederick
    from illinois
  24. chaos10meter
    chaos10meter
    from PA.
    Wizards Products makes a matt finish wipe down, smells good too.
  25. vegas
    vegas
    409 here as well...and here I thought I was the only one who cleaned up my car with it! There is always stuff showing up on mine due to being ivory color.
  26. wood470
    wood470
    Try comet.aarasive kitchen cleaner. Always worked for me
  27. Gman0046
    Gman0046
    The black on the wagon in my avatar is base coat without the clear. It has a satin finish. Greasy hand prints wipe right off with any brand of spray detailer.
  28. unkledaddy
    unkledaddy
  29. Bull
    Bull
    I've mentioned this product in other threads -- as have other HAMBers, but we have just what you need to care for your flat/matte finishes. Our Wipe Down product is a quick detail spray that won't add a gloss to your flat/matte finish.
    And be sure to use coupon code HAMB15 for 15% off of your order!
