Hey, Everyone! I have a question I've got a 2 door Chevy 53 210 sedan, I have rebuilt the front end with lowered springs, dropped spindles, and disc brakes. I want to run power brakes all around but money is very tight so I'm going to have to go old skool and install a later firewall mount pedal/booster/ master ***embly and I want to know what is a good junk yard GM setup that would work and has anyone out there done this already?? OR..... What would be a good aftermarket setup both frame mount or firewall mount? Thanks, Matt!
I did a mail jeep with an 80s Camaro pedal/booster, and used a Corvette master for a drum drum setup. Whatever you get, cruse the boneyard for a car with the steering column removed already, it saves a lot of work and contortions. Later I started making my own petal ***emblies. all seemed to work well.
