Hot Rods dual carb vac advance
Discussion in 'The Hokey Ass Message Board' started by Sarge vt, Jul 19, 2011.
  1. Sarge vt
    Sarge vt
    from Bristol,Vt
    Has anyone out there used two vacuum lines hooked together at a tee then to distributor on dual carb manifold on flatheads and then to distributor? also does anyone have a NOS mallory cap with wires attached for a modelYCM mallory dist?
  2. flatjack
    flatjack
    You will get the same vacuum signal with the 2 teed together as you would with a single tapping on one of the carbs and it won't be the same as a single carb hookup.
  3. Sarge vt
    Sarge vt
    from Bristol,Vt
    thanks for that.I am going to give it a try to see if it works.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    You'll find N.O.S. caps for early Mallory distributors, but they didn't come with plug wires.
  5. Sarge vt
    Sarge vt
    from Bristol,Vt
    contacted mallory they have no source for 1950's distributors parts This model has the wires made into the cap as one unit.May try your suggestion of newer cap thanks
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Again, the wires are not part of the cap. There are two screws on the top of the cap that hold the top piece in place. When removed, the cap separates into three pieces: the lower part with the br*** contacts, the rubber piece that seals the wires, making the cap waterproof, and the plastic top piece that squeezes the rubber piece when the screws are tightened.
  7. Sarge vt
    Sarge vt
    from Bristol,Vt
    not on this one,it is all one piece no screws,wires fed into the br*** contacts on inside of cap.cap one piece.this one was from 1952-53May just break down and buy a newer distributor.thanks for the help
