Sometimes "just because you can"
Discussion in 'The Hokey Ass Message Board' started by HotRodChassis, Jul 11, 2011.
  1. Francisco Plumbero
    Francisco Plumbero
    from il.
    Aux out the back to get the heat away from it.
  2. Dakota
    Dakota
    from Beulah, ND
    I saw a 6 deuce intake for an FE... Not on a cammer. In that truck. Whats the deal there?
    im an FE fan....
  3. HotRodChassis
    HotRodChassis
    Alliance Vendor
    We borrowed our motor for our slingshot to build the motor mounts in the truck before the builder was done with the SOHC. We have an Edelbrock 6x2 for it. 390FE with a nice lumpy cam.
  4. bigglugg
    bigglugg
    "Da Badder da Bedder"
  5. jipp
    jipp
    as you older timers would say.. that's boss!
    its coming along nice..
    chris.
  6. roseville carl
    roseville carl
    Wow nice job.......................
  7. czuch
    czuch
    from vail az
    It'l never work. The frame is too heavy and the motor is too underpowered.
    HEY ORVILLE,,,,,,,,,COME BACK!!!!!!!!!!!!
  8. Jpriebe66
    Jpriebe66
    Very funny! Kinda early to be drinking ain't it
  9. iFlip
    iFlip
    from San Angelo
    So when is this going to be in texas so i can feast upon it with my own two eyes?:D
  10. fab32
    fab32
    Another awesome build from the Chicago area boys. I suggest you invite the naysayer about your ch***is out to the track during a test and tune session. A couple of runs strapped to the underside of the frame should dispell any thoughts of "inadequate":eek::D
    Frank
    kidcampbell71 likes this.
  11. We'll take that as a compliment :D
    Great looking build.
  12. norm ricardo
    norm ricardo
  13. monkeywrenching
    monkeywrenching
    from maryland
    That is going to require some plastic bags and a box of depends to drive. Sweeeeet!
  14. Franklin Delano !!!!!!!
  15. only thing i see breakin is hearts..
  16. Francisco Plumbero
    Francisco Plumbero
    from il.
    I could see how someone at very first glance could be thinking there could be problems with rotational torque.
    But then you have to examine all of the cross bracing and the center tunnel and realize that this engine is mounted extremely well and the trans mounted in tight too making the whole unit rigid.
    And that is the real beauty of it in my opinion, that it can still look delicate up front......but it's not.:D
    That's why I like looking a their tube work.
  17. Nads
    Nads
    from Hypocrisy
    Now there's some engineering.
  18. Just keep the pics comin'.
    I'm taking notes.
  19. How do you do the bends for the kick-up in the rear?
    Those are some nice looking rails.
  20. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Thanks Fab32! LOL
    The rear, as well as the front, rails are mandrel bent box tube. And are 3/16 wall. All the round tubing is 4130. The entire ***embly is GTAW (Tig) welded.
    For those that can't see it from my ****py photographs, the ****ter shield is solid mounted to the ch***is, making the motor/trans somewhat monocoque. As the block is aluminum, and mounted from the skirt mounts, there are urethane bushings in the end of them at the ch***is. Mounting any high horse power motor from the skirt solid is a bad idea, as the vibration can crack the skirt. The trans is mounted with a standard rubber mount at the tail shaft. I'm sure a ton of drag racers that made the mistake of running a solid mount on the tail shaft of their trans will profess to the FAILURE the trans experienced. LOL
  21. Damn, I would kill you and feed you to my dogs for that engine.
  22. dirtbag13
    dirtbag13
    omfg ! holy santa clause **** ! that ****ers gonna be a rocket ! sohc baddest motor of all time ! hrc fantastic work on the fabrication and ch***is top notch work as always ! cant wait to follow this build as it comes to life !
  23. 52pickup
    52pickup
    from Tucson, Az
    Very nice. I like how the triangulated center structure goes from the kickup all the way up under the ****ter shield. Where'd you source the mandrel bent rect tube? Morrison?
  24. dustdevil
    dustdevil
    from illinois
    This will be yet another bad*** ride from you guys. I hope to make it to your open house coming up in august after goodguys.
  25. Django
    Django
    from Chicago
  26. mtrhd
    mtrhd
    I'll just leave these here. Jan. '65 Hot Rod mag article on this beast of a motor.
  27. dana barlow
    dana barlow
    from Miami Fla.
  28. Jpriebe66
    Jpriebe66
    Gotta love these Hambers, thanks for the articles!
  29. FrozenMerc
    FrozenMerc
  30. Jpriebe66
    Jpriebe66
    Again, I love the Hambers, thanks for finding the obscure articles. You guys are scary!
