tail light tec help
Discussion in 'The Hokey Ass Message Board' started by kingofknights, Jul 22, 2011.
  1. kingofknights
    kingofknights
    putting together a 56 chevy truck, installed some new tail lights but will not turn on, nor will they when i depress the brake. all fuses check out and everything is getting power. bad ground maybe?? any help is appreciated thanks
  2. 39 Ford
    39 Ford
    Are you wired thru a signal light switch?
  3. kingofknights
    kingofknights
  4. Scotts Enterprises
    Scotts Enterprises
    Bad ground or no ground...
  5. kingofknights
    kingofknights
    im thinking i might have to run a ground from each light to the frame because they are getting power just wont turn the damn bulbs on...
