Hot Rods who says you cant by a 32 ford for $500 anymore
Discussion in 'The Hokey Ass Message Board' started by titus, Jul 26, 2011.
  1. titus
    titus
    Well its only a pick up truck cab and funny rolling ch***is but still $500, i bought it of an online auction (not ebay) i was surprised it went as cheap as it did.
    Its sitting on a 46 ford truck frame that the x member and front member have been removed from and its been squeezed a little narrow at the front, then someone drilled some holes in the front parallel leaf axle and bolted some 40 bones there, the axle is complete with 42-48 square back spindles and juice brakes, it also has a 40 ford rear end just wire tied in, and then a set of 35 wires are bolted to them. I consider all the suspension stuff above as a bonus anyways.
    My plans are to maybe take the frame and shorten it up a bunch, sweep the rails in the front some, narrow the frame all the way thru, put a dropped axle front end in it with a flat front crossmember and put a square tube rear crossmember in it also.
    then maybe stick a sbc or a nailhead in it with an adpator to a 39 ish trasn and shorten up the torque tube rear end.
    JEFF
    kidcampbell71 likes this.
  2. F&J
    F&J
    Hmm, er, nice stance....Have you crossed over to the other side?:D
  3. Atwater Mike
    Atwater Mike
    Man...that's a deal. Plus it's "down-sized". (isn't that the new politically correct term for chopped top?)
    Seriously good deal there. Kudos.
  4. 067chevy
    067chevy
  5. Rocky
    Rocky
    Classified Editor
    Jeff...How the hell do you come up with these deals??? I admit my last 32 ford cab was only $350 but that was before vintage tin prices went through the roof. Congrats and good luck finding doors. I usta have a great source for doors etc but the ol' guy died and all his stuff was auctioned off...I bought some of it but am out of doors..
    Nice score!
  6. titus
    titus
    thats just the way i got it. it will look a hell of alot different when i get done with it.
    Too much internet surfing! Jens 32 pick up was bought for $350 about 6 years ago, and was missing a door, but thats when they were obtainable, luckily this one has doors or i probably wouldnt have bid on it!
    jeff
  7. Very cool man! PM me your number, I gotta talk about that T stuff we discussed.
  8. brad chevy
    brad chevy
    Good buy,looks like you saved it from being one of those little 4-legged creatures with a tail.
  9. Jeff,
    That is actually a pretty cool find. There is an option that you can do ch***is wise that is moderately cheap. Find yourself a model BB ch***is I believe that is correect. it would be the ton + ch***is from that era. They are fairly cheap usually. They are a little thicker and of course longer than the stock pickup ch***is but can be cut down and made to look correct.
    Anyway whatever you do it will come out just the way you want it, right?
    You are a lucky man I only really don't like you now. If it were more complete I would actually hate you. :D
  10. HOTRODPRIMER
    HOTRODPRIMER
    Heck Jeff,That's a big time score,we all know the doors are worth their weight in gold,,well greenbacks.:D HRP
  11. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Wow! Congrats!!
  12. Flat-Foot
    Flat-Foot
    from Locust NC
    Damn, I'd take that deal all day. Hell of a score!
  13. R Frederick
    R Frederick
    from illinois
    Can;t wait to see what you do with it, please post many pics.
  14. Big Tony
    Big Tony
    Sweet deal and sure it will be even sweeter when the progression has begun.
  15. Neat
    was that something local ?
  16. titus
    titus
    So i unloaded it and couldnt help playing with it a bit, did some measuring on it, put the rear end about where it goes, slid the cab back so the wheel base to the rear tires was about where i think it should be, did some motor measurements and drew a line where i figure the front axle should be place, cut abut a foot off the front of the frame rails and slid the front end where i think it should be, raised the back of the cab cause it was sagging a bit in the rear and its better, the rear end is gonna come up some more with the correct size tires, and the front should stay about the same, im thinking i may put a flathead in it too.
    JEFF
  17. Great score! looks much better.
  18. FityFive
    FityFive
  19. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I found my '32 for $5000 as well.....Wait what's that? $500? Awe ****y **** ****, I over paid never mind. :D
    Nice score that frame is worth twice as much!
  20. titus
    titus
    Its not a 32 frame unfortunatly, its a 48 frame, worthless basically!
    i got my 32 fiver for $1000, it had "for sale $100" on the belt line, ****!
    I took the whole thing apart, got the frame cut up, got the rear crossmember sunk into the frame, got all the measurements figured out on it, narrowed the rear up a bit, narrowed it at the cowl and had to widen the front of the rails for the grille shell, got it all squared up and tacked together, just need to put in the front crossmember, then i can make it roll again.
    JEFF
  21. nice score...the last '32 cab I looked at was trashed and the cat wanted double what you paid.
  22. what else do ya need?
  23. partsdawg
    partsdawg
    from Minnesota
    Looked at the truck this morning while picking up my stuff from that auction.
  24. wlspdshop
    wlspdshop
    from Missouri
    congrats Jeff...
  25. littlechris
    littlechris
    from MILWAUKEE
    you already have one!
  26. gassercrazy41
    gassercrazy41
  27. titus
    titus
    got a little more done, got the motor and trans in got the frame narrowed and shortened, got the front suspension mostly on, got to roll it outside again.
    jeff
  28. titus
    titus
    oh, and does anyone have a single cab corner patch, maybe you only needed one? i can make either side patch work.
    thanks
    jeff
  29. sodakmini
    sodakmini
    Would love to see some updates on this. I'm buying a project with a 48' car frame. Hoping for the same look. Trying to wrap my young head around this. Thanks in advance.
  30. gbones32coupe
    gbones32coupe
    Push me around in it ill drive it like that!!!!
