Hey guys I'm having some brake problems. Let me start with the parts I'm using. Speedway model a m/c. Speedway front disc setup 70's Ford rear drums. Wilwood proportioning valve, and speedway rpv 2# for the front line before the tee. A 10# rpv on the rear line. The problem is that after bleeding all the air out of the system I am still not making good pedal pressure. It gets worse, the front calipers will not release after pumping the brakes. The calipers will release if I open the bleeder. Adversely the rear brakes won't engage at all. The residual pressure valves are marked only with "in" and "out" I installed them with "in" from the m/c and "out" towards the wheels. Am I wrong? I'm freakin lost and I need some ideas. Thanks for any info.
You need to back off your M/C rod for one thing. That should take care of the fronts locking up. You will however loose more pedal doing it. What is your pedal ratio and how much throw do you have?..................... You have the in & outs rite. You either have the wrong M/C bore and or your not throwing rod far enough into bore. You can try a front line mounted Hold off valve that will let rears build up a bit before fronts or install a metering valve.
I don't really know what the pedal ratio is. This m/c came with the pedal rod bracket and pedal ***embly. I have tried backing up the push rod with no noticeable change. I can see that the piston doesn't return completely on its own. It stops about an 1/8" short. I can grab the pedal lever and pull it forward and the piston will move all the way out.
did you adjust out your rear brake shoes after installing them to where they are contacting the drums ?
I did adjust the rear shoes and yes the prop valve is on the rear line. I don't have a return spring on the pedal. I've never used one before. Do you think the rpv's are backwards?
The spring will only stop the fronts from locking up and may or may not help the rear........... I'll bet that if you jack the rear up, put in drive, press hard on the pedal the rear tires will still be spinning.
If you have no freeplay between the pushrod and piston in the master you will never get the brakes bled properly. You need freeplay first, then bleed again.
