Shoebox floors...
Discussion in 'The Hokey Ass Message Board' started by fordy-nine, Jul 28, 2011.
  1. fordy-nine
    fordy-nine
    So I got my car home and I start digging into the floor situation. I removed the interior, and the rockers more or less fell off the car. :( I then notice that the p***enger side A pillar isn't attached to anything at the bottom. And the driver's side A pillar has a very crude brace welded to it. I can see the remnants of a factory floor brace. Looks like it bolts into the frame and I'm going to ***ume that the opposite end welds to the A pillar? I'm not sure how it all attaches. Everything is rotted off of the car. Also, if someone can point me in the right direction as to a measurement that the base of the A pillars are supposed to be at, that would be just simply awesome! Maybe somewhere I can measure off of the frame? Both doors sag a good inch when I open them up. It even did this before the rockers... err what was left of the rockers fell off.
  2. fordy-nine
    fordy-nine
    Oh and I forgot... maybe if someone might have some build pics of underneath the car, or even from the top side? I'm sure someone else has replaced the floors and took pics of the process? Any help and a point in the right direction is greatly appreciated!
  3. tedster
    tedster
    Might check at shoeboxford.com also.
  4. big creep
    big creep
    you need to buy the green bible! all the info you need!
  5. Chopp'd49
    Chopp'd49
    do a search on this forum. There are a ton of good shoebox build posts and pics that the great members of this HAMB have inspired me with.
    BTW - pictures would be cool... and good luck with the build!
  6. badshifter
    badshifter
    Ahh yes, welcome to shoeboxes. ^ good advice up there, I made my own inner and outer rockers(woodie) but lots of stuff out there. Try and find another car local to take measurements from. Good luck.
  7. chaddilac
    chaddilac
    For $850 you can come down and get this 2 door sedan I have that has all new floors front to back, with newly rebuilt door hinges!
  8. fordy-nine
    fordy-nine
    Green bible? I guess I'll search ''green bible'' then. Thanks!
    Chopp'd49, I tried to upload some pics, but for whatever reason it won't let me upload... but if you go here, you'll see a couple pictures: http://www.jalopyjournal.com/forum/showthread.php?t=612079
    Everyone else, thank you for the info!
  9. Chopp'd49
    Chopp'd49
    fordy nine - I grew up jut south of Geneva in a little place called Brookfield Ohio. my first 49 I bought from Youngstown had alot of the same issues you described with the doors dropping, except the seem on the firewall was split and you could watch the firewall flex when you lifted the door.
    It is tough to find a nice Ohio car. The one in my avatar was sold at columbus around 6 years ago. Good luck with your build!
  10. big creep
    big creep
    the 49-51 ford service manual, they are for sale on e-bay and other places on line.
  11. tedley
    tedley
    from canada
    Not sure if this pic helps but mine where gone to. Not totaly but warrented a replacement. Made my own braces but you can get them repop from emc or others. Replaced a section of floor as well both sides
  12. tedley
    tedley
    from canada
    opps forgot the pic
  13. fordy-nine
    fordy-nine
    You're tellin me! I could have bought something nicer, but I just don't have that kind of money. Besides, I've always wanted to say ''I built that.'' So this will give me a good chance. I've driven through Brookfield before. There's lots of Ohio people here, it's cool! Thank you for good luck. I'll need it.
    I found one last night on Amazon for 23 dollars. SWEET!
    Exactly some of what I needed to see! Thank you! Do you have any idea what the dimension might be from say the bolt hole that goes into the frame, to the bottom of the A-pillar?
  14. msalamanca
    msalamanca
    Take a section at a time. It can be overwhelming at times. What i have done, is make a project list for it.
    Easy stuff that just takes some elbow grease, then a the list that cost big money (engine, panels ect.)
    I bought my "Green Bible" on ebay.
    Search here for "shoebox build"
    Book mark them under thread options.
    the tech archive has some great things.
    If you know how to do sheet metal, or are willing to learn, it might be easier to buy the tools, then by the panels.
    Also dont be afraid to ask questions on here, but do a good search first.
    Start with the main things of the car, when you get burnt take a break to do a fun custom mod on it.
    Just some tips that help me.
    My A post are not rotted as you described, but my rockers and front rear 1/4 where (i am guessing since they where cut off when I bought it)
