cracked off the nipple on the bleeder screw
Discussion in 'The Hokey Ass Message Board' started by greg_usa, Jul 31, 2011.
  1. greg_usa
    greg_usa
    from New York
    Hey Fellas - trying to get the wheel cylinder off my 51 plymouth. Was trying to get the bleeder screw out so that I'd be able to turn the cylinder itself so i can get it disconnected off the brake line of the other side of the backing plate.
    Anyway - the ****** cracked off and I'm having a really hard time now getting a grip on it to get it off. Any reccomendations on what to try here?
    Drill it? Heat it up? One thing I was thinking... there is a notch through the backplate that the bleeder screw goes through. If I drilled that notch a little bigger I can probably get the wheel cylinder off and have a lot more room to get at the bleeder screw. Is that a bad idea?
    Once again... bear with me and any stupid questions as a I'm a newbie. Any input would be greatly appreciated!
    Thanks fellas!
  2. boldventure
    boldventure
  3. propwash
    propwash
    from Las Vegas
    are the flats still on the nut? If so, there is a broached EZ out tapered with machined cutting/snagging edges on all four sides that may fit in the remnants of the bleeder screw. Other option is to drill it out a little bit and try that EZ out or one of the reverse threaded type. You can always just grind off the part of the bleeder screw that is apparently not allowing you to remove that cylinder and then take off the two mounting bolts. Keep in mind that if you do any drilling or grinding, you'll have to completely clean and rebuild that cylinder.
    Good luck...these sort of problems are what separate the complacent mechanic from the one that teaches everyone within earshot new and disgusting words.
    dj
  4. aaggie
    aaggie
    What condition is the cylinder in? If it needs replaceing anyway just do what you need to do to get it off. If you are doing a complete brake job just cut the flex hose and take the backing plate off and work on the bench.
  5. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    If it's that corroded, you probably need new cyls as well as update the steel brake lines. Hell, just go for it, then you have reliable brakes and more enjoyment driving your car.
  6. greg_usa
    greg_usa
    from New York
    got the hose through the backplate by peeling away the copper bushing. So was able to get the cyliner off and then get the screw out on the bench. Thanks for the help fellas! I'm inspecting the cylinder - I think you guys are right - probably smarter just to replace.
    Thanks for all the help fellas!
  7. MrHavard
    MrHavard
    Unless brand new wheel cylinders are ridiculously expensive, replace them. If they're pricey look into a rebuild kit. But don't re-use them as is.
  8. budd
    budd
    always the best way of getting a usefull responce is to post pictures, so you have a
    steel line going to the wheel cylinder? if so just cut it off.
  9. gimpyshotrods
    gimpyshotrods
    $30-$50 depending on front or rear. There are two in each front, upper and lower.
  10. 28chevrat
    28chevrat
    New ones the are way to go. Only way I've ever freed any stuck bleeder screws is to use some good penatrating oil (I mean good, WD40 is not the best stuff out there) let it soak for a day or two days and should break loose !!
  11. alex211
    alex211
    from NW PA
    I always heat the bleeder with a torch a little before trying to remove them if they are stuck, always has worked for me.
