Projects 1955 Pontiac gasser build
Discussion in 'The Hokey Ass Message Board' started by 55chieftain, Aug 10, 2010.
  1. AA/Fuel34fordpu
    AA/Fuel34fordpu
    You can make we all have faith!!!!!!!
  2. HotRod60F100
    HotRod60F100
    Go for it man! :cool:
  3. 55chieftain
    55chieftain
    Here's a few pics taken at the Meltdown. I have some fuel surging issues i'll fix that held me back. But no other problems except for me getting used to driving the car. But it ran safely down the track with no breakage. I had a blast, what a way to break my car in!
    benchseat4speed likes this.
  4. hellerods
    hellerods
    Thanks for the pictures, it made my day!!!!
  5. Falfasnightmare
    Falfasnightmare
    Thanks for thrashing and getting it on the track...we loved a pair of Pontiac G***ers on the track....TO COOL!!!!! Thank you both!
  6. gassercrazy41
    gassercrazy41
    good looking car. ran good in byron
  7. 5w32
    5w32
    awesome ...keep up the good work!
  8. SOLO
    SOLO
    Great job! Now you can relax a little from the thrashing. Feels good, doesn't it?
  9. Lild
    Lild
    Seeing your cars at the meltdown and then seeing the build thread. Too cool. Something different a**** the sea of Chevys
  10. Model A John
    Model A John
    from wichita ks
    Very cool Pontiac!
  11. petritl
    petritl
    from Marion, TX
    Wow Bill,
    That car has come along way from when it was in your Washington garage. What were you and the old Injuns times?
  12. hydroshawn
    hydroshawn
    from Tx,Ca
    I had a 55 4 door wagon that was a Lions runner. 389 with 421 heads twin AFBs & a B&M hydro. I had to shut it down every time I went thru the drive thru. Early VW low back bucket seats look great in it.
  13. 51 Hemi J
    51 Hemi J
    Beautiful Car! I wish you were closer, I have a camshaft I would donate to the cause.
  14. GlassThamesDoug
    GlassThamesDoug
    Go Chiefton.................next year.....meltdown 2012
  15. 55chieftain
    55chieftain
    Thanks guys, I do plan on going next year after several upgrades...
    Fuel system, exhaust than worry about the rear after I have traction issues after the other stuff gets fixed
  16. That Poncho is soo F$£€ cool, man I want to build a G***er myself! I keep promissing myself, someday!
    klaus
  17. hellerods
    hellerods
    Thanks for showing that Poncho's can run with the big dawgs. Good luck. and keep up the good work.
  18. modelacitizen
    modelacitizen
    Too cool dude. Congrats! what did it run?
  19. 55chieftain
    55chieftain
    Thanks for all the comments. My et's really aren't worth mentioning considering my carb was running out of gas halfway thru 2nd gear . I'm running a 800 cfm qjet, I know not really period correct but it's what I have and the car runs pretty good with it-outside of trying to keep fuel in it. I need to replumb my fuel system, either sump my tank and go 8an (1/2") or at least go with a 3/8" sender over my current 5/16" and put in a better electric pump.
  20. HFKND1
    HFKND1
    from Peoria, IL
    Seen ya at the Meltdown and then in Pekin this weekend and had not seen this thread and did not realize you are a local.
    Hope you can make it out to the Run What Ya Brung Drag Fest at Cordova next Saturday and of course to the Bombs Away Bash on Aug 27th.
    Car looks and sounds great nice work!!!
  21. 55chieftain
    55chieftain
    I got some video of a couple of my runs at the Meltdown Drags. Big thanks to Hamber 50John for sending me a copy. All my runs were against Hamber "Old Injun" , a real 60's racer 56 Pontiac "Old Injun".
    This first p*** was alot of first for me. First time i've drag raced, first time to drive this car. I was nervous and excited at the same time. I'll admit and it shows in the video where I was supposed to line up and kept staging with my back tires, than once I got down the track trying to get used to the b&m shifter. So take it easy on me for looking stupid, I was just happy to get my car down the track after 7 years.
    http://www.youtube.com/watch?v=pkkv7An9OrI&feature=player_detailpage
    The 2nd video I think was my 2rd p*** and by this time my carb/fuel was hot and felt like it was vapor locking down the track.
    http://www.youtube.com/watch?feature=player_detailpage&v=f4to2fo1Z-Y
    I've since got a sumped fuel cell and will run 1/2 lines and also will have a return system to keep fresh fuel to the carb.
    Also on my rear springs, especially the lr which I thought were ok, decided to lay down on me from the extra pressure from the front end. I put in another shackle to lift it a bit and a week later it was worse than without the extra length shackle. So i'm going to take them apart, rearch the springs and I have some extra springs i'm going to add in. Also I think I will flip the springs forward so I have more material on the front end of the spring than clamp them all down together to prevent any axle wrap up . I may even add in a few small coil springs I have that are brand new for helper springs?
  22. swade41
    swade41
    from Buffalo,NY
    Way to go, congrats on getting it out on the track, lot of work to get where you are.
  23. nailhead terry
    nailhead terry
    Man I love the 55. I use to run a 70 gp 455 4 speed that car was fun !! I have a 41 pontiac coupe. I wonder what kind g***er that would make
  24. billys54
    billys54
  25. chieff51
    chieff51
    do you know where I could find a hurst front mount motor mount? i need of one.
  26. 55chieftain
    55chieftain
    I got the rear spring deal done for now. I took the springs apart and the extra rear pair of springs I had all apart and doubled up the 3 middle springs. I used a grade 8 - fine thread 5/16 x 3" bolt , 1" longer than stock and rounded the head off for the centering pin, the stock one was way too short with the added springs and also the u bolts for the leafs springs were replaced with longer ones. The rear sits about 2 higher without the sagging. I already spent the money and time putting in new bushings on the main leaf so this should work, it's stiffer but I expected that.
    I also unshaved my door handles, I had an extra door and made a template . Someone welded pieces to the backside of the door, instead of trying to remove that, I got the holes for the handle done and really didn't need to remove the inside stuff because of how the handle mounts to the door.
    chieff51 check the Hamb cl***ifieds, I saw a few for sale there. Just search pontiac under the parts for sale section.
  27. OahuEli
    OahuEli
    from Hawaii
    Are you going to radius the rear fenderwells?
  28. 55chieftain
    55chieftain
    Not yet, I'll wait till traction becomes an issue. I'm not sure how sticky the hurst piecrust slicks are but I did find another tire that may work from Hoosier too. Or go with the American Racers that are a dirt track tire, the old McCreary brand tires. These were only about 100 apiece and would work fine at my power level. The lower the series (bb) are the softer tires
    http://www.americanraceronline.com/racing-tires/p***enger.html
  29. 55chieftain
    55chieftain
    Getting a little more done, although not real sure how HAMB friendly a fuel cell is. However without having to worry about a rusty fuel tank and being able to supply the engine with the amount of fuel it needs it will be worth it. Plus the fresh paint for the trunk and got the firebreak installed .
  30. superchargedill
    superchargedill
    Looking GREAT Bill. You have guts hustling to get the car going and take it straight to the drags. YeeHawwwwww man!!!! especially never having drag raced and a new car to boot. You have cajones grande. Hows the fuel/ carb issue now ?
