Customs 35 Ford 3-window build
Discussion in 'The Hokey Ass Message Board' started by Fomocokid, Oct 25, 2010.
  1. matt 3083
    matt 3083
    from Tucson, Az
    I am really impressed. I have learned a
    great deal from your text and pictures.
    Thank you for taking the time to share.
    Matt
  2. u r ready for black ez
  3. oldman2
    oldman2
    Looking good as always.....Jim
  4. 32SEDAN
    32SEDAN
    Nice work! You have skills my friend.
  5. TomH
    TomH
    :eek: :) :)
  6. kisam
    kisam
    Impressive metal skills!
  7. Fomocokid
    Fomocokid
    from Rapid City
    Here are pics of all the damage on the drivers side. B pillar is better but the A pillar is rough. The entire a pillar was twisted and the door jamb was smashed and twisted. Gene got the pillar straight and then I cut the door jamb sheet metal from my parts car and welded it in.
    mgtstumpy likes this.
  8. oldman2
    oldman2
    Nice repair on the A pillar...Jim
  9. Strange Agent
    Strange Agent
    Some killer work going into this car, inspiring...
  10. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Hey man I realy like what you have done sofar.It`s the first time on this thread for me but it`s not the last,that`s for shure.Got a 36 3w my self and gonna build it up in a similar way so this is gonna be a big help for me.Once again,great work....Kenny
  11. Fomocokid
    Fomocokid
    from Rapid City
    Last night I cut the sheetmetal off of the quarter and the cowl. I built up the sheet metal by the latch. I fixed the rust in the wheel well and I clearanced the sheet metal around the shock mount. I also cut the floor out.
    Today I fixed the base of the A pillar. Replaced the front of the rocker. Fixed the D-nuts. Made the bottom of the A-pillar. And i bolted the hinge on
  12. bjinx
    bjinx
    I subscribed to this thread quite awhile ago and you progress and skill never ceases to amaze me. It is inspiring and motivating.
  13. oldman2
    oldman2
    Nice job on all the repairs....Jim
  14. Fomocokid
    Fomocokid
    from Rapid City
    I got the rocker welded in today. I also patched the bottom of the b-pillar. I patched the subrail behind the b-pillar on the inside and outside edges
  15. TomH
    TomH
    What happened to the floor?? I though that part was ok . Of course everything else looks good.
  16. Mr48chev
    They do that when you pull then out of your jeans pocket with your thumb on the screen. No need to ask why I know that tidbit.
    That car just keeps looking better every time I look at your updates. And makes me want one for my flathead's new home more all the time rather than an A sedan.
  17. Fomocokid
    Fomocokid
    from Rapid City
    tonight I got the quarter patch tacked on. I made the door jamb and got that welded in. I also fixed the rust in the wheel opening.
  18. Fomocokid
    Fomocokid
    from Rapid City
    The floor was alright but It will just be better with new ones
  19. Sorry for the dumb question, but are making or buying your patch panels??? From following this thread I know you've made several, but I was just curious about the outer body patch panels. Either way I'm really enjoying your build and you are doing an excellent job.
  20. Fomocokid
    Fomocokid
    from Rapid City
    I bought the rockers, door patches, cowl patches, and the quarter patches. I made everything else
  21. stlcrzn
    stlcrzn
    Looking great as usual. Keep working at this rate and I will get to drive your car before you know it!!!!
  22. Fomocokid
    Fomocokid
    from Rapid City
    I fixed the front foot of the cowl tonight.
  23. stlcrzn
    stlcrzn
  24. Fomocokid
    Fomocokid
    from Rapid City
    Made the door jamb on the cowl tonight. I tacked the cowl patch on and I made the bottom of the cowl patch and welded it on
  25. Fomocokid
    Fomocokid
    from Rapid City
    Welded up the cowl and quarter patches today
  26. Fomocokid
    Fomocokid
    from Rapid City
    Here is a pic of the driver's door to remind you guys how much of a piece of **** it is. I got a sedan door that I plan to splice to the 3 window top. I cleaned the skin up tonight. I will also have to use the inner out of the 3 window door since my car has a forward inner door handle and the sedan door has the handle in the middle of the door.
  27. Fomocokid
    Fomocokid
    from Rapid City
    I drilled the spot welds and took the inner panel out of the sedan door. I took all of the undercoating off of the skin. The bottom hinge had been arc welded to the support structure. I cut that chunk off of the 3-window frame work. I fixed the cracks in it.
  28. oldman2
    oldman2
    Boy that undercoating did a great job saving the metal, to bad the whole door wasn't covered in it, nice repairs.....Jim
  29. Fomocokid
    Fomocokid
    from Rapid City
    I got the bottom of the inner support welded on tonight. I also got the upper part of support structure tacked on
  30. TomH
    TomH
    Are you going to finish the top of the door now, or leave that for the chop?
