Projects Model A Mechanical Brakes-Who has them?
Discussion in 'The Hokey Ass Message Board' started by Model A Fan, Aug 3, 2011.
  1. Model A Fan
    Model A Fan
    I'm going to go with original mechanical brakes for my truck, but I haven't a clue how they work. I have I think the basic parts, but haven't seen how they all hook together.
    Anyone have photos of mechanical brakes prior to putting their Model A body back on? Any photos in general and any advice?
    Thanks!:D
  2. dudley32
    dudley32
    Try Ford Barn at bottom of this page...
  3. scootermcrad
    scootermcrad
  4. gardon
    gardon
    from kansas
    If it is powered with anything but a stock 4-banger, get some hydraulics on it.
  5. 1932tub
    1932tub
    Do a search on Fordbarn for Flathead Ted, he makes a kit for Model A brakes that greatly improve their stopping power
  6. Bigcheese327
    Bigcheese327
    Properly set up and adjusted, equipped with cast drums and Flathead Ted's floaters, mechanical brakes shouldn't be any worse than pre-1949 Ford hydraulic brakes. But, that's a lot of variables. Be safe and make sure you know what you're doing when you go through them.
    Ford Barn will be a good place to start, and there are lots of old HAMB posts on this topic, as well as the benefits of upgrading to a 1932 mechanical system if you can find one.
    -Dave
  7. xix32
    xix32
    there can be so much slop in worn bushings and clevis pins that all the pedal travel can be used up before the shoes are applying pressure to the drums.
    there is a good reason ford put spring steel bumpers on those cars, they aren't just ornaments.
