Aug 2011 Banger Meet. Better late then never
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Aug 3, 2011.
  1. Crazydaddyo
    Crazydaddyo
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.billsbangers.com
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculatorfin.jsp
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
  2. Crazydaddyo
    Crazydaddyo
    Getting back into this again. Trying to get it ready for the Route 66 hill climb.
  3. Bluto
    Bluto
    Thank you Craaaaaaazzzzzze
  4. BCCHOPIT
    BCCHOPIT
    Thanks DaddyO
    Good luck at RT.66
    Is your dads truck going this year?
  5. Crazydaddyo
    Crazydaddyo
    Pop broke his engine. ***embling parts for it's replacement now.
  6. Jaguar6165
    Jaguar6165
    Question time again. Who has installed the Flat Head Teds brake kit? I just did the front with the kit and relined the shoes. The fronts were really easy to do, but now it the drums heat up really quick and during braking the car pulls hard to the right. I've adjusted the wedges but I don't want to over adjust them and it seems that they may be because the drums get so hot. Should I adjust the brake rods now that I have some new components up front? I will be doi ng the rear next week.
  7. BCCHOPIT
    BCCHOPIT
    Did you size the new shoes to the new drum size
    Did you center the shoes to the spindle
    I just did my brakes with teds stuff I did up grade to 1935 brakes up front and 32 in the rear
    Ted is always on fordbarn look up some old post on brakes ask over there and he will chime in
  8. RussTee
    RussTee
    what model head is that crazy rajo made a lot of different heads looks like you may have got a valve cover with that as well nice find
  9. Stovebolt
    Stovebolt
    CDO, did you dad blow the mill in the yellow 31CCPU?
    It sounded real strong in the video.
  10. ebtm3
    ebtm3
    Jaguar 61-65
    I installed Ted's kit only on the front of my '30 Tudor and they work wonderfully.
    I always use "Green Gripper" lining, and bond it to the shoes. Use a piece of waxed paper between the drum and the lining, and clamp the shoe, lining and drum together with a C clamp until the epoxy sets. Sounds to me like you didn't arc the shoes to the drum (allowing for the lining thickness), and perhaps the lining has a gap between it and the shoe. Whatever the cause, I'll bet it isn't Ted's fault.
    Put the car on 4 jackstands. Adjust the square adjusters on the backing plates so that there is just the lightest drag, then back off one click. Make up an adjustable prop to go from the seat mounting, to the brake pedal, with the pedal down about 3/4". Now, adjust the rods so that you can barely turn the front wneels by hand, and the back wheels have a heavy drag.
    Herb
  11. Crazydaddyo
    Crazydaddyo
    It is a dual plug "B" With the bigger chamber.
  12. Crazydaddyo
    Crazydaddyo
    Ya, the Rutherford headed B in the 31 P/U. We haven't pulled it yet, but the rear of the block is broken off. No pictures yet.
  13. BCCHOPIT
    BCCHOPIT
    Is this pay back for all the **** you broke of your pops when you were young :)
  14. SPEEDBARRONS
    SPEEDBARRONS
    the update to "find" thread
  15. Rolf
    Rolf
    Whazzat?? Overdrive?
  16. KCTA Chris
    KCTA Chris
  17. Nice Chris! She sounds great! Who did the machine work?
  18. SPEEDBARRONS
    SPEEDBARRONS
    Yep Rolf, you should be even more in love with it since it's Volvo
  19. Rolf
    Rolf
    Cool. Love to see that!
  20. SPEEDBARONS,
    Any more info on the Volvo overdrive (years/models)?
  21. Bluto
    Bluto
    That's a Ley**** J from M-41 or M-45 Volvo o/d
  22. SPEEDBARRONS
    SPEEDBARRONS
    detail
  23. BCCHOPIT
    BCCHOPIT
    Nice job on the step up on the frame. Looks like ford did it.
  24. Bobby Green
    Bobby Green
    I posted this on it's own thread, but thought it was appropriate to post again on here as I know some of you chaps only ever look at the monthly Banger thread...
    W,ell after a solid few months of work from myself, Max jr. and sr. at H and H Antique, and Logan Davis and Chuck at their new shop "Vintage Performance Automotive", I am happy to report that the new banger is finally together and running in the Bellytank. All test fired and broken in, she's ready to hit the salt. We loaded her in the trailer yesterday and we head out on Wed. Were still running 3 of Clives new Stromberg 97's and the Gemsa overhead cam head, but everything underneath is brand new..... Stronger, lighter etc.
    Were hoping for speeds in the 160 + range. Wish us luck !!
    Here's a short video:
    <iframe width="425" height="349" src="http://www.youtube.com/embed/MxcArkQf-q8?hl=en&fs=1" frameborder="0" allowfullscreen></iframe>
  25. Awesome Bobby! Good luck and be safe!
  26. Looking for information about a Kingston Vacuum Fuel Pump on a 29 Plymouth two door sedan. The car is completely stock with the original four cylinder engine. The dump valve will not seat correctly. We think there might be some missing parts.
    Thanks
  27. BCCHOPIT
    BCCHOPIT
    Look up Ken CT on the ford barn.
    He might have the parts
    Good luck
  28. BCCHOPIT
    BCCHOPIT
    WOW....
    Every one is out playing and no good news.
    Just work for me but on the good side I got to drive the car to work.
    I think I might get lost on the way home :)
  29. jakeknapp29
    jakeknapp29
    This is my first post on here. Thought you guys would like to see my banger projects. 20 yrs. old and on the third banger project. Got my coupe when I was 14 and spent two years doing a body off restoration and then started an A speedster. Now working on a T hill climb speedster.
  30. RussTee
    RussTee
    nice work jake would love to see more of your projects welcome
