1940 Ford Sedan doors in a 1940 Ford Coupe???/
Discussion in 'The Hokey Ass Message Board' started by ricardo_rocha, Jul 24, 2011.
  1. ricardo_rocha
    ricardo_rocha
    from Brazil
    Hi Fellow Hambers...I come to you to ask if the doors of a sedan like this:
    Would fit a coupe, like this ????
  2. plumfat40
    plumfat40
    from colorado
    Nope, they are a few inches too long... 4door sedan front doors will work though
  3. hotrod40coupe
    hotrod40coupe
    No, you need one from a fourdoor and then you will still have to fit the top of the door to the coupe.
  4. ricardo_rocha
    ricardo_rocha
    from Brazil
    Ok! Thank you guys very much!!! What about the rear and front fenders?
  5. flatheadhero
    flatheadhero
    The 4 door one will fit- but the top corner where the door closes will need to be cut and brought down a tad, maybe a half inch to fit. Coupe doors slope down in that area, 4 door sedans slope upwards. The door may not fit exactly at the belt line either. Not that big of a fix, but not a bolt on and go.
  6. 4dFord/SC
    4dFord/SC
    I believe the top corners will have to be cut and rounded.
  7. 4dFord/SC
    4dFord/SC
    Oops! Hero beat me to it.
  8. ricardo_rocha
    ricardo_rocha
    from Brazil
    What about the Rear and Front Fenders, sir? Do you believe it fits the coupe?
  9. ricardo_rocha
    ricardo_rocha
    from Brazil
    Thanks my friend...those are great news!!!
  10. ricardo_rocha
    ricardo_rocha
    from Brazil
    Does anyone have made this match between the 4doors and the coupe doors before? Does anyone have any pictures on it? Or a draw or anything? Im really interested in that kind of project...
  11. oldhotrodguy
    oldhotrodguy
    There's a book on how to chop top were sam foose used these longer doors and it was a sweet looking car when it was done maybe a little searching and you could find it on line .
  12. 40Standard
    40Standard
    from Indy
    doors will not fit but the fenders will. take a tape measure to the doors
  13. HOTRODPRIMER
    HOTRODPRIMER
    I was under the impression that the rear fenders are different. HRP
  14. 40 & 61 Fords
    40 & 61 Fords
    Fenders are the same.
    As many have said, 4 door sedan doors fit on a coupe when the top is trimed.
    My coupe has a sedan door on the left side. We just cut through where the skin overlaps on the top. Pulled the inside edge of the overlap back, then cut the outer door skin to fit the opening. Then re-fit the inner edge, welded it up, and metal finished it.
  15. ricardo_rocha
    ricardo_rocha
    from Brazil
    Thank you guys...Good information to start...
  16. fatkoop
    fatkoop
    As said, a door from a 4-door will fit with minor rework. I used the same trick on my 36 5-window and it only took an hour or so to re-contour the top edge. The belt line is the same on 4-doors or coupes.
  17. ricardo_rocha
    ricardo_rocha
    from Brazil
    Great...Learning a lot from you guys...Thanks a lot!!!
  18. ricardo_rocha
    ricardo_rocha
    from Brazil
    One more doubt is about the ch***is...Would the different models(4doors, sedan, coupe etc..) share the same ch***is?
  19. hotrod40coupe
    hotrod40coupe
    They all share the same ch***is including the pickup, however, the pickup ch***is doesn't have the body mounts needed for the coupe or sedan. Those are available from Bob Drake.
  20. biggeorge
    biggeorge
    My coupe has front doors from a four door. They were put on by the person i bought it from.
  21. 40fordtudor
    40fordtudor
    BG----that coupe is a dead ringer for my high school car. Memories.
  22. biggeorge
    biggeorge
    It's nightmares now!
  23. HotRod40Deluxe
    HotRod40Deluxe
    You're good using any '40 front or '38 deluxe-40 rear fenders, same. The only rear fenders that won't work in those years are wagon and sedan delivery. You're good using any p***enger ch***is including sedan delivery or wagon. Pickup ch***is is fine too, but you'll need to add p***enger outer body mounts. Bob Drake now offers them in a complete 4-piece kit.
  24. DrJ
    DrJ
  25. ricardo_rocha
    ricardo_rocha
    from Brazil
    Thanks Man! It helps a lot!!!
  26. ricardo_rocha
    ricardo_rocha
    from Brazil
    I didn't know Bob Drake...Very good information...Very nice WebSite!...I just still dont understand if he ships internationally!!!
  27. ricardo_rocha
    ricardo_rocha
    from Brazil
  28. ricardo_rocha
    ricardo_rocha
    from Brazil
    Yes! They do ship overseas!!!
  29. ricardo_rocha
    ricardo_rocha
    from Brazil
    Im growing curious about the other years Ford models...What about the compatibility in between the 1933/34/35/36 Ford Models? Are the ch***is and fenders the same for Coupes, Sedans, Roadsters etc...???
