I know that someone has asked this question before. Did the search for about 2hrs and have not found any info. I **** at this computer ****. What width is the stock rearend in the 36 or what rearend is a good fit. Plan on using a 7" wide wheel on back with a 225/75-15
I have what I believe is an original 36 rearend. I measured outside of drum to outside of drum (where the face of the wheel touches the drum) at 57" and flange to flange at about 52.75"--accounting for bend in tape caused by banjo. Of course the pics won't line up with exactly where I measured.
The 57-59 Ford p***enger cars have the narrowest nine inch,they fit perfect under the early cars.I think the early 70s Ford Broncos are narrow also.
Thanks for the info. Called a few salvage yards for the Explorer rearend. Cheapest was $350. had 204K on it. $750 with 90K. Found a 72 Bronco rearend $500. I am a tightwad as these seem high to me.
TOO BAD you are not closer. They only cost $150/$200 in my area for the Explorer rear. NOW ... the Bronco is a different deal. They usually run $350 or so. Explorer rear ends are COMMON ... But I prefer the 57/58/59 Ford 9 inch for a early Ford. They are fairly common in my area also
Look for an explorer on craigslist that they want to get rid of and buy the whole thing. You may be able to use more then the rear.
I don't know where in Missouri you are but if you can find a U Pull it somewhere close to you a tool box will save you a fortune in a late model rearend. Seeing as how you know that 57" flamge to flange is perfect a tape measure and a couple of straight edges in your tool box may find you a bunch of rears that are close to correct.
Wish I was close to you. With s**** prices so high, just about everything around here is gone. Did check out CL nothing close to me (no suprise).
Went a picked up a 57 truck 9" ford last night for $200. Found it on CL, I find that you have to search with different wording for the same item to find all the results. I don't think I've found one yet searching for 9". They are still out there.
I put a late 70's Granada 8 inch under my sedan, with reversed 15x7 wheels ,the 235 -75's fit real nice in the wheel openings. Mitch
