1950 Chevy with Camaro engine
Discussion in 'The Hokey Ass Message Board' started by Treevorr, Aug 6, 2011.
  1. Treevorr
    Treevorr
    Hey, I'm new to this site, but I've spent hours reading random stuff when I started looking for a cl***ic car, and decided this is the place to ask questions. I finally found The One, a 1950 two door Chevy Fleetline with an unknown year Camaro engine and transmission. I'm completely car-tarded, and I'm wondering where I should start. The engine runs decently, but the fuel tank and radiator are full of sediment. The trunk doesn't really open. There is some rust on the block itself. The carburetor looks kinda shady. Obviously, either I'd need to be more knowledgeable about cars or someone would actually have to see it to give any major input, but I figured somebody somewhere could help. Thanks much
  2. indyjps
    indyjps
    go to the intro page and do one.
    have you purchased this car or just looking at it. Camaro engine doesnt matter, its just a small block chevy. pics might help.
  3. zman
    zman
    from Garner, NC
    Read This First! then do an intro, fill out your profile, then find some of the Charleston guys like flamedabone and see of you can hang out with them, maybe just maybe they'll look at it and tell you yay or nay...
  4. Treevorr
    Treevorr
    Intro done.
    I just bought it today. I'm gonna try to get the wife to take some pictures. I'm able to run a submarine engine but I'm hopeless around electronics...
  5. zman
    zman
    from Garner, NC
    Like I said lookup flamedabone and check out the south carolina hambers social group. There are some real good guys in your neighborhood, buy them a few beers and bet you can get some help from them.
  6. Treevorr
    Treevorr
    Got some pictures taken. The car takes up literally all the space in the garage, so the shots aren't the best. I'll get better ones when it isn't raining out.
  7. flamedabone
    flamedabone
    Is that the one that was parked in the old NAPA parkinglot??
    Welcome to the hood. Holler if you need anything.
    -Abone.
  8. Treevorr
    Treevorr
    The very same. Thanks for the welcome. I hit up the lowcountry group as well.
  9. F&J
    F&J
    It looks like they were not running antifreeze, just plain water, that turned rusty color.
    I'd start with removing the thermostat, then put the housing back on, so you can flush the cooling system out. Just keep a constant flow of water into the filler, with the radiator drain open. With no thermostat, it will keep circulating real good, and finally run clear. Then put a new thermostat in, with new antifreeze.
    If the tank is full of rust, I would see if there is a new repro tank available. It would pay off in the ong run.
  10. Treevorr
    Treevorr
    The water is a lovely shade of poop brown; I'm guessing it'll need a new tank.
  11. 50styleline
    50styleline
    Your ride would look much better without those unsightly fender skirts! You should pack em up and send them straight to me.(LOL) Nice score, and by the the way this site is the best place for advice and how to info. Good Luck
  12. koolkat269
    koolkat269
    WOW thats a kool ride.
  13. Salty
    Salty
    from Florida
    From the distant pic it appears that your carb is a rochester 2GC....good carb (if it is that) fairly idiot proof and parts are readily available.
    scince your "car-tarded" I"ll bring this up, get rid of the gl*** fuel filter or secure it down exceptionally good....gl*** breaks and the exhaust manafold is pretty close....your a sub driver you can figure out what could happen....that said start small, clean the engine compartment up, straighten out the wires, re-route for optimum functionality as well as looks, clean up all the errant ****ola layin all over the place and giver the ol' once over with a fine tooth comb cleaning stuff up and straightening things out as you go....
    Looks as if you have a very solid base to start with! (Sweet body style!)
  14. gimpyshotrods
    gimpyshotrods
    Sheesh, back when I was car-tarded, I had to start out with junk.
    Some people have all the luck. Nice lookin' ride.
  15. 50stude p/u
    50stude p/u
    Good advice, I know some people whos 59 el camino burst into flame after it was finished for only a week. Luckily they got the fire out before it engulfed the whole car and their shop. apparently the gl*** filter housing broke.
    Nice find by the way.
  16. 37gmc
    37gmc
    from upstate ny
    looks like it has camaro sub frame also .nice ride, make think ishould start on mine
