Model a doors?
Discussion in 'The Hokey Ass Message Board' started by WILTBILT, Aug 7, 2011.
  1. WILTBILT
    WILTBILT
    from VIRGINIA
    Hey can anyone help me identify these doors, I am looking for doors for my model A coupe. They measure 27.5 inches wide and have scroll like door handles. The other thing that is odd is the p*** door has a lock cylinder hole. Thanks for any help. They also have wood inside the door across the bottoms.
  2. F&J
    F&J
    Murray body
  3. WILTBILT
    WILTBILT
    from VIRGINIA
    Hey man I appreciate it.
  4. coupeHEAD
    coupeHEAD
    All Model A's had the key lock on the p***enger side.
  5. modelaman
    modelaman
    from sunland ca
    30/31 coupes have the door lock in the handle and not the door skin and roadsters and open cab pick ups didnt have outside door locks. not sure about 28/29
  6. aaggie
    aaggie
    Most old cars only had an outside lock on the p***enger side. Ettiquite of the day said you parked at the curb and locked the drivers door from the inside then slid across the seat and exited out the p***enger door then locked it from outside with the key. Also when getting into the car you unlocked the p***enger door and opened it for your companion and they reached across and unlocked the drivers door while you walked around the car.
    It was a different time and people had manners.
  7. NielsK
    NielsK
    from Denmark
    30 - 31 Fordor front door as mentioned above.
    Look closer, there might be more wood in there than you realised :)
