58 imperial push button assy
Discussion in 'The Hokey Ass Message Board' started by stringjobs, Dec 29, 2010.
  1. stringjobs
    stringjobs
    from So Cal
    Any help out there or pictures or any experience rebuilding one of these things ?
    Help, I have a problem with the gear selector
    Thanks for your help in advance
  2. 73RR
    73RR
    You might try Imperial Services or check in on the ForwardLook site.
  3. stringjobs
    stringjobs
    from So Cal
    Thanks but not much help. Anybody have any idea how this monky motion works ? I did find a 62 out of a car and have some idea, but I real nice exploded view of the parts would be great. Thanks again for any help
  4. Factory service manual or a parts book should have that. Imperial's a little different because the ****ons are vertical rather than horizontal, but it boils down to a couple of cables that shift the trans and a lot of things that can rust or have old lube dry out and get sticky.
  5. Squablow
    Squablow
    I just got the one in my '62 Chrysler working, it was a cable adjustment at the transmission that was the problem, felt like you were halfway between neutral and drive or reverse all the time. Is that what yours is doing?
    My ****ons were also binding up, where one would not release when the other was pressed, turned out to be a cable routing issue, if the cable has any pressure on it it'll be harder to shift, mine got re-routed around a bracket and now it works great.
    The last thing you want to do is take the dash mechanism apart. Clean it and lightly oil it maybe, but that's it.
  6. petritl
    petritl
    from Marion, TX
    I don't know how different a 58 Imperial shifter is from a 62 300 but I would guess they are functionally similar.
    I have a 62 shifter on my bench, I can take some close up pictures of it this evening and send them to you.
  7. Phinney
    Phinney
  8. qool58
    qool58
