1938 Chevrolet Pickup Fuel Tank Question
Discussion in 'The Hokey Ass Message Board' started by kartman01, Aug 10, 2011.
  1. kartman01
    kartman01
    from Michigan
    I have a 1938 Chevrolet 1/2 ton pickup with an underseat/in cab fuel tank. The existing tank is rotted beyond reasonable repair, so I have purchased a reproduction underseat tank from Chevies of the '40's...
    On the original tank, the filler neck was two piece... a fuel filler that sticks out of the side of the cab, a rubber hose 'joint' and then a short section of metal tubing sticking out of the tank.
    The reproduction tank has a 'one piece' arrangement going into the tank.
    My question: which is correct as the original configuration for a 1938 Chevrolet pickup? I have spent multiple evenings trying to find an illustration or photo of how the filler neck was configured out of the factory with no luck.
    Any help or insights will be appreciated.
    Thanks!
  2. tb33anda3rd
    tb33anda3rd
    my '39 gmc is one piece, i believe '38 is also.
  3. kartman01
    kartman01
    from Michigan
    tb33anda3rd... thanks for the help. If anyone else has any insights, please let me know :)
  4. tb33anda3rd
    tb33anda3rd
    i take it the running problem was rust plugging the shut off? how much was the tank? i have a little leak in mine.
