Dead 264 Nailhead with Dynaflow. Which Motor will fit on my Dynaflow?
Discussion in 'The Hokey Ass Message Board' started by OldKustoms, Aug 12, 2011.
  1. OldKustoms
    OldKustoms
    Hi @ all,
    I´ve got a problem.
    My 1955 Buick 264cui Nailhead need to be send into the mashine shop.
    But is it possible to mount a later nailhead on my Dynaflow like a 401 or something like that.
    Thanks in advance.
    Marcel
  2. Griznant
    Griznant
    I believe only 264s and 322s are a direct bolt-on for that trans. The later 364/401/425s are different.
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Using your existing transmission limits you to '53-'56 engines. However, if you could come up with a '57-'60 Dynaflow, it would still be set up for an enclosed driveline and would allow the use of the later nailheads.
  4. telriv
    telriv
    from Conn.
    Change the bellhousing & torque converter to one from a '57-'63 DynaFlow. Read the book VERY CAREFULLY. A '57-'63/364/401/425 with the dynaflow crank will be just about a bolt-in swap.
