Projects My '59 El Camino - 8-13-11 - It's Finally Done
Discussion in 'The Hokey Ass Message Board' started by hemifarris, Sep 2, 2010.
  1. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    I see it differently ... 1958 was definitely the peak of excess. Look at any GM product besides Chevy, and they look pretty overdone. I feel like 1959, they brought it back just a little bit and hit a nice balance.
  2. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Ok I started reading your reply on May 25th and just finished now. :D I appreciate the insight into your mind and direction and I totally get it. I guess I thought this car was more along the lines of a "factory could have been" and I was looking at it in the approach that it seems like you went above and beyond to get everything just so for 1959 but the radials were sticking out to me so I was just wondering your reasoning. I love your approach and the fact that you're building it exactly the way you want and I totally respect everything you're doing.
    Like I said, I would like my '54 to turn out very similar even if it's only half as nice. The black walls and dog dish caps, the factory built engine, the oem interior...everything!!! I love to think about what some car might have looked like if GM sponsored a program that put out a line of cars with some serious *** behind them and not worry so much about all the fluff.
    Again, it may be one of my favorite cars on the HAMB and I would chew my arm off to have it. Thanks bud!
  3. Now that's a nice el cam! And the color is just right! I want one too....
  4. doozcoupe
    doozcoupe
    I agree. 58 was the excess year for chrome on all GM entries. Especially Buick, Oldsmobile, and Pontiac top of the line models.
  5. hemifarris
    hemifarris
    True...I guess my main thought was regarding the excessive fins that Buick, Cadillac and chevrolet introduced. You're correct regarding the Excess chrome of 1958........Mike
  6. hemifarris
    hemifarris
    Jeffrey, here's a couple of pictures of a '59 El Camino with stock wheels and bias ply tires. Note how small, and narrow the rear wheel/tire combination looks. I had to fill the wheel wells and the only way was with wider, 15" wheels and wider tires. I also added a custom made 1" spacer to bring the wheels out to where I wanted. I didn't want deep dish wheels so I added the spacers so it has more of a stock appearance as opposed to a last minute wide wheel choice...Take care,Mike
  7. olscrounger
    olscrounger
    Mike--looks like you are getting close--did you get a parking meter air cleaner for it yet--I too run radials on my black 57 Fuely with small caps as you know on 15 inch wheels vs 14's to fill the wheel well and make the stance suit me as well-good job-best El Camino I've seen.
  8. Toner283
    Toner283
    Wow Mike, From that angle the green Elky does kinda look like an elephant balanced on a roller skate. Cars (and trucks) always look better with the wheel wells filled up with a wheel/tire IMO. I still think your Elky is the nicest one I have ever seen. If you needed an extra left testicle I will trade ya!:D
  9. hemifarris
    hemifarris
    Hello Tim. NO, I still haven't found a parking meter. I've gotten everything else, including nameplates and flags but no duct. If the one we discussed ever becomes available, please let me know. I bought an aftermarket air duct, installed the small tube on it that connects to the rubber tube to the balance tube. I had it powdercoated silver. The car is done, except for the road test. I will post pics of the finished job in a week, or so.........Thanks, Mike...P.S....If you ever have the time, would you send me some pictures of your '57? hemifarris@aol.com
    Hi Tone. The wheelhousings are huge on the El Camino and needed to be filled. An El Camino will look like that from any angle with 14" wheels and tires, especially bias ply. As far as the extra nut........You saw me last summer. Do I look like I even have room on this fat body for an extra nut? I know you looked at, and photographed my El Camino from every angle and you know it well. I really appreciate your thoughts on it. Hopefully I'll see you two this summer, or fall. I have your parts,plus a new shift lever and knob, the '60 black/white houndstooth seat covers and door trim pads I took out of it. Maybe you can use the trim as a driver until you get yours done....Mike
  10. Toner283
    Toner283
    We are still planning a trip down this summer at some point, I am working a second job now so planning some time off is a little tricky logistically. I am working about 30 hours a week as a fabricator for these folks: http://www.hitmanhotrods.com/en/ Plus i am still doing the factory gig full time as well. And I appreciate the offer of the parts, I have plans to put them to good use. I will definitely take a few more pictures of your Elky with the new interior and the fuelie unit in place. I have been looking forward to hanging out with you again since last fall so I will do my damnedest to make it happen.
  11. hemifarris
    hemifarris
    If you make it down, great. If you don't, the parts aren't going anywhere........I'm glad you're working a lot. You've got to earn it while you can, and while you're young......
  12. hemifarris
    hemifarris
    I'm finally finished with my El Camino. Since I originally posted it as being 99% done ,I've done the following;
    1- installed a new interior as my lower cushion cover was faded
    2- for safety sake I installed new heater and headlamp switches
    3- installed new, clean dash bulbs
    4- installed an N.O.S. factory push ****on radio
    5- restored my underdash air conditioner
    6- new fuel pump (safety)
    7- new door weatherstripping
    8- new factory rubber floor mats
    9- 4 new T3 sealed beams
    10- had speedometer restored w/new AC Delco odometer...several numbers were off color
    11- installed restored factory Rochester fuel injection system, air hoses and core support mounted air cleaner.
    12- installed a set of correct '59 p***enger car fuel injection flags and nameplates. I had to have these reproduced.I did them in polished stainless steel. These were Chevrolet p***enger car 1 year only parts.
    12- fabricated upper radiator hose as Chevrolet never offered air conditioning on fuel injected '59s and I needed to clear compressor.
    Here's some photos............. Mike
    Cosmo49 likes this.
  13. afan
    afan
    from michigan
    Mike,the emblems looks perfect.The car is perfect!!!!!
  14. johnybsic
    johnybsic
    from las vegas
    Dude I gotta say your ride is out-right awsome. god damn is that thing rad!!!
  15. hemifarris
    hemifarris
    Thanks Jim. The emblems are finally done and installed. I think I cost Kelly a couple of hairs by having him install them knowing what an ***hole I am regarding my cars. It runs just like a modern electronic fuel injection system, as opposed to the '59 mechanical unit that it is. I'm happy with it.
  16. DRUGASM
    DRUGASM
    Wow. That is awesome. It was beautiful at 99% and it's just a little better now. Congrats. You plan on putting some serious miles on it now?
  17. Boones
    Boones
    from Kent, Wa
    you should consider making extra emblems and sell them
  18. shoprat
    shoprat
    from Orange, CA
    That's one fine El Camino.
  19. bogart62
    bogart62
    Hey Stranger, Kent here. Car looks ***s. Emblems an F.I. look bad ***. Looking forward to hearing it. Hope you are doing ok Mike. Hope to see you soon.
  20. qzjrd5
    qzjrd5
    from Troy, MI
    What Kent said!
    Mike
  21. hemifarris
    hemifarris
    I own the molds. I will NOT reproduce them as long as I own my El Camino. After, or if, I sell it they'll be reproduced for sale. I have a lot of money in those 2 flags and fuel injection nameplates. Actually, when building a first series El Camino, nothings cheap.......:)
  22. CW's40TPU
    CW's40TPU
    JUST AWESOME!
    Thanks for sharing.
  23. gashog
    gashog
    In-frickin- amazing...
  24. beanis
    beanis
    Very, very nice. Congrats and thanks for sharing!
  25. BOP-Nut
    BOP-Nut
  26. Harrison
    Harrison
    Looks great!!!!
    JH
  27. SKULL ORCHARD
    SKULL ORCHARD
    from KS
    one bad *** truck !! would love to have it.
  28. rob-redm
    rob-redm
    The best El camino I have ever seen.... Great ride !
  29. Toner283
    Toner283
    That looks great Mike, the FI install makes the look of the car. Love the FI badges too, I have never seen a 59 in person with them. Do I remember correctly that your were casting them in stainless? Or did you have them cast in pot metal? Just curious.
    Yours is still the most beautiful, well detailed Elky I have ever seen. I hope mine turns out 1/2 as nice when I am done with it.
    Amen to that brother!
    Do you have any pictures of the new interior? I would like to see it too.
  30. The emblems look great! I'm glad I found the the originals, for you to be able to reproduce them. The 59 is amazing, Mike! Thanks
