Stromberg 175 CD sidedraft carbs--on a six?
Discussion in 'The Hokey Ass Message Board' started by squirrel, Aug 8, 2011.
  1. squirrel
    My son is playing with ideas how to hop up a 250 then possibly a 292 for an OT car with a low hoodline. I have a pair of Stromberg/Zenith 175 side draft carbs off a late 60s volvo. Wondering...anyone ever stuck three of these things on a straight six?
  2. Weasel
    Weasel
    Volvo did (two 175 CD) on their 3 litre six in the late 1960s....
  3. Is there any benefit to running these over earlier SU's? I have a pair of these as well as some HS2's /HS4's to run on my '28 Chevy engine.
  4. I have three 175 CDs that I plan on putting on my Chevy 250. Advance Auto has carb kits for about $25 each.
    Won't be getting around to it for a while though. I currently have a Offy 4bbl intake and Edelbrock 500 CFM carb. The car is newly built...well, it WILL be newly built one day, and I want to drive it to work all the bugs out before I start dinking with carbs and dealing with the drive-ability and tuning issues that will no doubt come up with triple carbs. I'm primarily interested in them for the 'LOOK'. They'll just look better on my roadster.
  5. GM's Holden in Oz used triple CD strombergs on the 1971/72 Holden Torana XU1, this was on the 186 & 202 cube six, basically a smaller version on the 250 chev.....there should be plenty of info on the net..........andyd
  6. 6inarow
    6inarow
    I'm doing them right now on my 235 - but am using SU's
  7. deuce354
    deuce354
    Tell Us More About This Roadster, It Is KICK-***
  8. Weasel
    Weasel
    ^^^ +1 - memories of a BMW 328 spring to mind.
    SU's are generally a preferred choice over Stromberg CDs....
    bathcollector and need louvers ? like this.
  9. Thanks Weasel for the advice AND the 328 pic!
  10. squirrel
    We have the Strombergs...and they're bigger. But I'll have to see if my brother still has the SUs.
    Thanks. Something like this?
  11. 80vette
    80vette
    I've got a sequentially numbered set of Dellorto DLHB 35 side drafts I'm trying to get rid of.....if you're interested.
  12. Cody Walls
    Cody Walls
    Here's what I built for my 292 , I mateded a Clifford and 2 datsun 240z manfolds together and a lot of other creative re engineering . I've haven't got it running yet but I'll let u guys know how it turns out when when I do .
  13. squirrel
    That's neat! Did the datsun use SU carbs or a copy of them?
  14. Cody Walls
    Cody Walls
    Yes datsun made there own copys of the European verson , the early verson are good carbs , the later ones are junk .
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I'm using two HS6 SUs on my champ car with a crossflow-headed 300 Ford six. I made the intake manifold.
  16. Check your PMs.
  17. Buddy Palumbo
    Buddy Palumbo
    I dig thinking out of the box ! I've been working with both the ZS and SU carbs for many years . IMHO , I would rather use a set of 1.75 SU carbs over the Zenith Stromberg carbs any day - it's a much better carb .
    Since you've already got the ZS carbs ... run 'em & try it out .
  18. volvobrynk
    volvobrynk
    from Denmark
    Did this project ever get off the ground? @squirrel
  19. squirrel
  20. Rusty O'Toole
    Rusty O'Toole
    Jaguar used triple SUs for years on their straight six.
  21. mgtstumpy
    mgtstumpy
    Local GM on XU1 Holden, as stated smaller version of 250
    volvobrynk and squirrel like this.
  22. Having the Strombergs available is the only reason you would choose them over SUs
