Let's see some taillight/brakelight ideas...
Discussion in 'The Hokey Ass Message Board' started by essexrat, Aug 11, 2011.
  1. essexrat
    essexrat
    Time to think about what kind and how to mount tailights/brakelights on my Es*** Coach...let's see what's out there...
  2. Scotts Enterprises
    Scotts Enterprises
  3. SlickRick83
    SlickRick83
    from merced
    I added these to my '54 Bel Air. Do you know what they are??
  4. damagedduck
    damagedduck
    from Greeley Co
    here some i've done for bikes,i love using L.E.D truck light as a start.their bright as all get up.most are made out of out car lights,the 1 on my chopper is a cab lens of a old peterbuilt truck,i use 32 led lights,they give a real crazy effect when put behind car lens..
    http://s946.photobucket.com/albums/ad310/damagedduck/mentally ill/
  5. 40fordtudor
    40fordtudor
  6. 28chevrat
    28chevrat
    Packard tails....
  7. SlickRick83
    SlickRick83
    from merced
    Packard lights have a little bit different shape. They are '56 Chevy bubble lenses.
  8. OldCrow
    OldCrow
    69-72 Blazer side marker lights modified for use with 1157 bulbs. (I also redid the edges in br*** instead of the original chrome). available new aftermarket for a few bucks. flush mount. the Blazer uses this twin lens unit OEM.
    Russ
  9. padorey
    padorey
    What year Es*** ? Other guy what year Packard? 56 Would take a lot of work. How about a Model A light or 32, or 33 Ford, Or some thing realy off the wall, like VW monuted on rear fenders?
  10. padorey
    padorey
    Packard (56) have a lot different shape.
  11. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    Look like 56 packard :confused:
  12. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    They look sad and droopy. Looks like the top edge drops down too far.
  13. Kripfink
    Kripfink
    Well, these were knocked up using some parts I had laying around, but I know they can all be bought aftermarket;
    If they should float your boat at all here's a link to what can be laughingly described as the tech thread;
    http://www.jalopyjournal.com/forum/showthread.php?t=555032
    Perhaps I should add the Impala cones fit over the top of the 59 caddy bulb holders, (with a little persuasion:D) with two screws, which means you could flush mount them if you didn't want the h***le of Frenching.
    Hope this is of some help to you, good luck whatever you decide.
    Paul
  14. Kripfink
    Kripfink
    If I read his profile correctly, it's a 1930 Es***.
  15. 1971BB427
    1971BB427
    from Oregon
    I'd like to see the car to determine what lights might be appropriate for the style of car. A rod would use something different than say a stock look, or custom look.
