6x2 Carb Set Ups - Pics and Information?? - who made them?
Discussion in 'The Hokey Ass Message Board' started by arkracing, Aug 1, 2006.
  1. oldsrocket
    oldsrocket
    Couple of mine for early pontiac. Still in the "project" phases...
    Edelbrock
    Offenhauser
    Looking for good sources for 6x2 linakge. Had trouble w/ eelco. Not willing to risk it with vintage speed. Any other sources that can be suggested that are good quality and deliver on time?
  2. A Rodder
    A Rodder
    I just put linkage from Eelco on my x1 and it was trying at first but I think it should work real good. Hope to put it on the wifes 30 tudor sedan by the weekend.
    What I want to know is if I can get away with running vacuum from the carbs to the dizzy, va***m modulator, and if necessary the pcv.
  3. junkyardgenius
    junkyardgenius
    from Kernow
    Here,s mine....
  4. scootermcrad
    scootermcrad
  5. Ill be running this setup on my blown Desoto Hemi....but instead of 94s Ill be using 4**2 Stromberg WWs
    Rat
  6. Dog_Patch
    Dog_Patch
    Eelco 6x2 on a 330 Desoto and 94's. I am trying to figure out the linkage right now.
  7. Bosco1956
    Bosco1956
    from Jokelahoma
    6x2 from showcars
  8. I Like Cars
    I Like Cars
    from England
    I think this thread needs a bump!
    Finally fitted. Although, realised yesterday that the air cleaners look better off centre. No pic though because engine has been taken out due to high oil pressure :(
  9. OCIE
    OCIE
    from TRINITY,TX
    Awesome thread, just started collecting pieces for mine and looking at others for ideas. Theirs sone good stuff on here. Gonna try and run all six straight linkage on a 327. Heres what I have so far.
  10. I Like Cars
    I Like Cars
    from England
    Good work on getting the thread back up.
    Those stacks are stunning, they far surp*** any that I have seen for sale. Can I ask where you got them or were they custom made?
    I just bought these for my fuel lines. Hopefully they will look alright (not my pic).
    <center><table border="0"><tbody><tr><td><table border="0" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="vs_w-a"><center>[​IMG]</center>
    </td></tr></tbody></table>
    </center>
  11. OCIE
    OCIE
    from TRINITY,TX
    Thanks, I made them. I saw some close to these online from the hotrod company. I work at a machine shop so I figured I'd just make my own :)
  12. I Like Cars
    I Like Cars
    from England
    Ah right, fair enough. Must be handy working in a machine shop (and having the knowledge/skill to machine something like that!).
    Your stacks look much nicer than the ones for sale. You could make money selling them.
    I look forward to seeing your linkage and fuel log/block.
  13. stewscoupe1929
    stewscoupe1929
    Dont want this thead.. hanging by a thread.. bahaha!
      246.4 KB
      194.6 KB
  14. OCIE
    OCIE
    from TRINITY,TX
    Gonna Finnish the linkage and run the fuel lines this week and hopefully will be bolting this down this weekend.
  15. mgtstumpy
    mgtstumpy
  16. Spud
    Spud
    from Ohio
    Finished the linkage, it will pull from the front with the cable running up thru the center. Fuel lines done. Mechanical choke linkage for the two main carbs. Now take apart clean, rebuild and put on the car
  17. lockwoodkustoms
    lockwoodkustoms
    What I have been putting together for my 39.
  18. Tudor
    Tudor
    from GA
    Blast from past - 2010 seems longer ago than that!
  19. rustisgold
    rustisgold
    When running non-progressive linkage should the middle 2 carbs still be primary style carbs and the end 4 be secondary style without idle circuits? Or should all 6be primary style carbs?
  20. dickster27
    dickster27
    from Texas
    It's ideal for the middle 2 as primaries and the outer 4 as secondaries all controlled by progressive linkage.
  21. rustisgold
    rustisgold
    Yes, I understand how the carbs are set up with progressive linkage, but what about the guys who are running non-progressive linkage?
  22. dickster27
    dickster27
    from Texas
    You can run them with straight linkage but you have to have enough motor as well as have all 6 synced. In my opinion it is not the most practical for average streetability. It is a proven fact that you can't take a **** load of carbs and just jet them down a bunch and expect them to run, it doesn't work that way. There are a lot of other issues to take into consideration.
  23. desotot
    desotot
    Here is a pic of my sbc edlebrock 6x2 1ntake I cut up and welded to the top of my home made desoto intake manifold. I uused 6 holley 94s and progressive linkage on this open plenum setup. I ran it forover 10 years. It was a ****** to warm up the engine in the middle of winter but it worked quite well otherwise.
