horn relay 53 plymouth
Discussion in 'The Hokey Ass Message Board' started by alfonsothefons, Aug 9, 2011.
  1. alfonsothefons
    alfonsothefons
    from Georgia
    problem is figuring which of the horn relays connection are what?
    the diagram shows somewhat
    but the relay , it has a bullet connection,a
    center nut which is the main horn line and 2 more connects.
    i am trying to see which goes to[coil neg.,ignition,flasher] and [ ammeter,starter solenoid]
    and which to [horn ****on]ground?
    please i have car almost done! and this is keeping me from driving it.
  2. plym_46
    plym_46
    from central NY
    here is the diagram for the 46 through 49. It should be close enough to allow you to figure out yours. I think the later ones were a bit different but it should be close. If you are still running 6V make sure you use 12 gauge minimum for the wiring. You can power from the battery side of the starter solenoid, rather than the coil if you prefer. The horn ****on completes the ground to sound the horns.
  3. alfonsothefons
    alfonsothefons
    from Georgia
    thanks
    i ended up buying 2 12v 30amp relays and spread the load to ignition and horn on one and flasher and back up switch to other
    now saving for a gadget to drop 12v to 6v for gauges
  4. plym_46
    plym_46
    from central NY
    the only gauge thing needs changing are the bulbs. if you are going negative ground, you need to swap terminals o the ammeter, gas gauge works on resistance so they don;t care about voltage.
  5. alfonsothefons
    alfonsothefons
    from Georgia
    here is diagram i been using,can you tell what to change in ammeter diagram to make it negative ground i am new to this and just followed the print
  6. plym_46
    plym_46
    from central NY
    take the wires off the terminals and switch them to the other one.
  7. 49 Custom
    49 Custom
    Welcome to the HAMB... Take a look at the tech archives for how to build voltage reducers for $3 apiece; you'll save quite a bit and learn some about your car's electrical system.
    -Stefan
  8. alfonsothefons
    alfonsothefons
    from Georgia
    i was looking at my p24 diagram if you look by batt
    it looks to me like it is negative ground am i right?
  9. alfonsothefons
    alfonsothefons
    from Georgia
    the routing is starter relay
    to horn relay to
    ignition
    to ammeter.
    there are several wires on both terminals
    do you mean the line from ignition to ammeter?
    or everything on left terminal switch over to right and everything
    right terminal to left?
    trying to do this once , i am blind in one eye ,cant see out the other too well
    and fun upside down to boot
  10. deanopopino
    deanopopino
    from Troy, MO
    What on the diagram gives you that idea? No, the p24 is positive ground.
  11. alfonsothefons
    alfonsothefons
    from Georgia
    thank you deano,
    so do i move the ignition connection to the left terminal on ammeter as you would look at dash, and will that solve the issue? of switching to neg ground.
    i am using the 12v battery neg ground and positive to starter relay now and last thing i have to wire is the headlight switch.
  12. plym_46
    plym_46
    from central NY
    take all the wire and transfer them to the opposit terminal.
  13. alfonsothefons
    alfonsothefons
    from Georgia
    ok did that taking break from under dash as we type
  14. alfonsothefons
    alfonsothefons
    from Georgia
    drove car tonite and whole system died it was about 9 pm and still parked somewhere,tried field switch horn relay,with another still no lights or anything ,i drove over speed bump
    a contact from the relay i believe the ammeter lead hit the firewall and took out the electric.
    where do i start checking to make it run?
  15. MORRISGAUGE
    MORRISGAUGE
    I'd start by looking up an experienced automotive electrician. Sometimes a second set of eyes can find an overlooked issue. Have you checked if the ammeter has continuity still?
  16. plym_46
    plym_46
    from central NY
    fuse on the rear of the headlamp switch??
    Check the connections on the battery side of the solenoid. I had mine loosen up and it was like there was no power anywhere, but the battery was still reading 6.4 volts, but nothing worked.
  17. alfonsothefons
    alfonsothefons
    from Georgia
    i miss read a relay paired wires wrong ,i guess it goes with blind in one eye
    barely see out the other and not having sense to ask someone how to understand the schematics of them plastic things.
    that was a $100 tow lesson
