Paint peeling in sheets???
Discussion in 'The Hokey Ass Message Board' started by Wild Turkey, Aug 20, 2011.
  1. Wild Turkey
    Wild Turkey
    What went wrong? I bought this pickup two weeks ago, owner said it had been repainted but there were a few flaws -- mostly rust spots on hood.
    I got to working with one of the spots this morning after I had sanded and primed them to stop the rust until I got time to find out what the problem was.
    One small piece had "flagged" from the sanding so I tried to pull it off.
    You guessed it -- peeled like an overripe orange:eek: Here's part of one of the pieces I peeled off.
    Here's the hood -- you can see the line between the two pieces I peeled off.
    Those scratch marks were there beneath the paint.
    Here's some close-ups of the back side of the paint.
    Yes, those little white spots are there.
    Even closer.
    Did the painter not sand and clean between the gray and the white before the topcoat of red?
    It was not a base/top coat finish, just a single. I belive the hood was a repop piece to replace the damaged one.
    What do I do now to make sure it doesn't happen to my paint?
    (And yes, thoughts of adjusting the at***ude of previous owner with daddy's 1-1/2" combination wrench did p*** through the evil back sections of my mind :rolleyes:)
  2. Shizzelbamsnapper
    Shizzelbamsnapper
    from Ohio
    Is this an O/T truck? If so is that a replacement hood? Reason I ask, if it is an replacement hood that comes in Black that stuff has to be sanded off 100% or the paint comes off like that. The other problem that could be is it looks like it was sanded with 600 or finer paper, usually 320- 400 is where we stop.
  3. Ob1
    Ob1
    Might be cheap lacquer based primer over the black...
    I would take a pressure washer to that hood, probably wont have much stripping to do after that!
  4. Wild Turkey
    Wild Turkey
    What is the black stuff? Why would they put it on pieces that will be painted?
  5. Shizzelbamsnapper
    Shizzelbamsnapper
    from Ohio
    Electro plating to keep it from rusting. Primer will let the moisture thru and the metal will still rust.
  6. Bad Daddy
    Bad Daddy
    Looks like a quality GM factory paint job from a few years back. . .
  7. Scotts Enterprises
    Scotts Enterprises
    Could be a aftermarket replacement hood and whomever did not sand the E-coat off before sealing it. The stuff they try to p*** off as E-coat is pure **** and if you dont sand it off, this is what can happen...
    My first clue was the rust you mentioned. Pretty typical.
  8. Engine man
    Engine man
    from Wisconsin
    Reminds me of high school auto shop. There was a body shop in a nearby town that would paint any car for $39.95 including paint. On of the teachers had a car painted there. He was driving and the paint peeled off the hood and flopped back covered the windshield. He brought it into the auto shop and it looked like the guy didn't even wash the car before he painted it. You never get more than you pay for.
    I wouldn't buy anything with a fresh paint job unless there is a warranty because you don't know what's under the paint.
  9. RichFox
    RichFox
    My '93 Dodge pickup did the same with factory paint as did my neighbors 2009 GMC pick up. Both white.
  10. Scotts Enterprises
    Scotts Enterprises
    I can understand the Dodge, they had problems then... but the 2009 GMC?
    Waterborne basecoat and urethane clear. It shoulda stuck on the 2009.
    The EPA pushes the Automakers real hard to eliminate VOC's. The only problem is we are the guinea pigs and have to live with the automakers experimentation.
  11. KrisKustomPaint
    KrisKustomPaint
    There are sealers that will stick to e-coat even with out sanding. Spies Hecker, good ****. Lifetime warranty. Obviously that is not good primer. It does look like fairly fine sand scratches but it should have been fine with a decent primer.
  12. mgtstumpy
    mgtstumpy
    De-laminating as they call it, little of NO prep so it won't bond and will continue to peel. The rest as they say is history. You'll have to strip the whole car.
  13. RichFox
    RichFox
    Yeah he came home from work one day with practically a primered truck. All at once. I just bought an '11 GMC in red. Hope it sticks.
  14. lukey
    lukey
    If thats a replacement hood, it was probably just sanded with wrong grit, or washed with the wrong type of cleaner before the paint was shot. Lotsa newbies use an automotive washing solvent after sanding instead of final kleen.
  15. Wild Turkey
    Wild Turkey
    The good news is that the rest of the truck seems to be ok -- only the repop hood is bad.
    But that's bad enough:(
  16. duste01
    duste01
    Take it to the car wash and take the rest off.
  17. Blackmaria60
    Blackmaria60
    "It'll buff out"!
    Looks like the hood of my '98 Aurora!
  18. SmoKerch
    SmoKerch
    Just what I was thinking - 1975 Oldsmobile Silver.
  19. 57tony31
    57tony31
    from Woods
    Let it rust and go with the flow then it will look like its 50 years old lol..................
  20. noboD
    noboD
    They MAY have just used scotch brite, no sanding.
  21. VoodooTwin
    VoodooTwin
    from Noo Yawk
    ^ exactly what it looks like. Real bad prep.
  22. It's just a cheap paint job to make it look nice so it'll be easy to sell. Once it's yours they don't care what happens to it. Sorry.
  23. super plus
    super plus
    You drove it to fast
  24. nailhead terry
    nailhead terry
  25. 40fordtudor
    40fordtudor
    It would likely blow off with compressed air---been there, done that.
  26. carcrazyjohn
    carcrazyjohn
    from trevose pa
    As said before da hood ,Down to metal and get start over ,And be thankful it was only the hood,Go to a place that can color match the paint,
  27. Gunrack
    Gunrack
    I used a bunch of Imron years ago on big trucks. That stuff would adhere to ANYTHING, except lacquer based primer! If it wasn't sealed with with a self etching epoxy based sealer, you were in trouble!
