Custome stuff you have made for your mill
Discussion in 'The Hokey Ass Message Board' started by 28 jalopy, Aug 20, 2011.
  1. 28 jalopy
    28 jalopy
    from arizona
    I wanted to see what else you guys have made for you mills cause you did'nt like what was on the market and you also wanted a custom touch. Here is a picture of the crank pulley I made at work cause I wanted to run a double belt setup on my 53 flatty. now I am in the proses of making matching water pump pulley's for my new drake pumps.
  2. 28 jalopy
    28 jalopy
    from arizona
    I figured on making the flatheads aluminum water pump pulley's the same dia. size as stock so there wont be an issue with turbulence from the impeller spinning to fast and churning the coolant.
  3. loose1
    loose1
    I made some air cleaner tops for my mill with my mill.
    Matt
  4. I've made a 2barrel carb riser and a remote oil filter block adapter for the Y block in my somewhat OT F600.
  5. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    Nice pulley ... I bet the matching set is gonna be real sharp.
  6. 28 jalopy
    28 jalopy
    from arizona
    Thanks! I appreciate it!
  7. OCIE
    OCIE
    from TRINITY,TX
    I made the stacks, oil fill tube, and oil fill cap cover.
  8. 28 jalopy
    28 jalopy
    from arizona
    Great machine skill on the sacks and breather! looks great on the six pack! Keep them ***ming.
  9. CheaterRome
    CheaterRome
    from URANUS
    I am going to volunteer a fellow club members Mike Lange stuff because even after 4 years it still amazes me.
    His blower that he built. An Italmeccanica along with it's intake. Plus all the pulleys. carb scoops. The man is talented
    Yeah he cast and machined the blower casing, milled the impellers and made everything o- ring sealed and with sealed bearings it's just ****in nuts.
  10. CheaterRome
    CheaterRome
    from URANUS
    Some more pics.
    Yeah he figured out the gear reduction too for using a mechanical ww2 airplane tachometer off the generator.
  11. 28 jalopy
    28 jalopy
    from arizona
    Beautiful! looks vintage. Now there is a man with some patience and skill. He cant be hitched yet or his wife is very forgiving. Keep'em ***ming, I love this kind of gearhead stuff!:D
  12. CheaterRome
    CheaterRome
    from URANUS
    Oh no he's hitched. For quite a while now. Lots of patience and a very awesome wife who understands his madness / genius.
    Before he was bitten by the hotrod bug his talent was that of a vintage (pre WW2) motorcycle restorer / racer
    http://michaellangevintageharleyracers.com/
    Nice job on the pulleys and love the Hallock on the model a.
  13. 28 jalopy
    28 jalopy
    from arizona
    Thanks! The Hallock is in the process, Made the hallock type frame out of 3/16 cold rolled sheet metal. Hope to grind and sand it for a clean chrome job. I raked it at 35 deg. to me the Hallock is awsome but I wanted even more streamline.
  14. captainjunk#2
    captainjunk#2
    wow mike langes one very tallented man , that blower set up and work on the flatty is awesome
  15. swekustom
    swekustom
    from Sweden
    Started to build some exhaust-manifold for my shoebox !
  16. 28 jalopy
    28 jalopy
    from arizona
    Please, Keep them ***ming!
  17. A-Bomb
    A-Bomb
    Finned master cylinder cap, coil cover, nerf bars from aluminum tubing and flat stock, Moon tank mounting brackets, gauge panel, finned gas pedal.
  18. badshifter
    badshifter
    Dude, You're grossing me out. It's "coming". This isn't you****.
  19. 28 jalopy
    28 jalopy
    from arizona
    Badshifter, your sence of humor is as narley as mine and my workmates! Thats awsome. HA HA HA!
  20. 28 jalopy
    28 jalopy
    from arizona
    Just finished the driver bank touching up the braided plug wires. Tomorrow the p***enger bank. Man I love how they look flowing into a Mallory 2 piece cap!
  21. 28 jalopy
    28 jalopy
    from arizona
    I was thinking on making a fuel rail out of billet. It would look good blasted to give the cast look. The more heat sink fins to match the heads the better I think. Whats your opinion?
  22. toolman1967
    toolman1967
    Good looking parts here. Love that Blower on the flathead.
  23. 28 jalopy
    28 jalopy
    from arizona
    Mike Lang is an artist! hands down. I wish I had enough time to finish all my small odd's and ends if it wasn't for family and work. But that's what playing hooky is for!
  24. 28 jalopy
    28 jalopy
    from arizona
    Just finished the water pump pulley's for the flathead! I made a pair of 304 stainles steel hubs to mount on the water pump shafts so I could bolt and remove the aluminum pulley's for maintnence on the mill. Double 5/8 V belt grooves to match the crankshaft pulley. I was thinking on making the tension pulley to run tucked down near the bottom corner of the block running a shaft driving the alternater behind the mill. I like the look without the generator or alternator jumbled in the way like an eyesore.
  25. roseville carl
    roseville carl
  26. 28 jalopy
    28 jalopy
    from arizona
  27. I think Mr. Lange could make a lot of people happy if he cast some more of those blowers!
  28. 28 jalopy
    28 jalopy
    from arizona
    I agree! But I don't know, He might want to be the only cool kid on the block with that sweet setup. We can only hope.
  29. CheaterRome
    CheaterRome
    from URANUS
    Yeah he made them originally just so he could have one and cast a hand full of housings. Doing this so he could recoup the money on the patterns and castings. Selling a few to collectors and the guy who provided the NOS Italmecannica blower to begin with.
    Everything else is machined... by hand. The few that are/were around roughly the same price if not a little more that the S.C.o.T. blowers by H&H.
    Nice job on the pulleys. Anytime you can make a piece that is functional and cool looking..... winner.
    Rome
  30. Nice work. Stainless is a ***** to machine. Hard and gummy. What kind of taps do you use?
