Heat Riser Weight: '57 235.
Discussion in 'The Hokey Ass Message Board' started by Vetteman61, Aug 22, 2011.
  1. Vetteman61
    Vetteman61
    from Tennessee
    Does anyone know where I can get the weight for the heat riser on a 235 in a 57 chevy. I can't find one anywhere.
    Thanks,
    Brandon
  2. squirrel
    find a cracked exhaust manifold in someone's junk pile. Sorry, I s****ped the one I had last summer.
  3. henry29
    henry29
    I have a complete 235 I pulled out of my 57. I'll look and see if Its still there.
  4. Vetteman61
    Vetteman61
    from Tennessee
    Thanks Henry, I'd really appreciate it. I was planning on driving my '57 to the Frog Follies this weekend but I'm not sure if I'll make it. Isn't that always how it goes.
    Brandon
  5. henry29
    henry29
    Well no luck, my intake and exhaust manifold seem to be missing.
  6. Vetteman61
    Vetteman61
    from Tennessee
    Dog gonnit! Thanks for looking anyway!
    Brandon
  7. Wire it open, I did that when the spring broke. Runs ****py when it's cold but once it warms up it's fine.
  8. Vetteman61
    Vetteman61
    from Tennessee
    Nope, no halfway job for me. When I drive it on cold mornings it will barely run. By the time it finally warms up to idle I'm already where I'm going. I have plans to make a new shaft out bushings out of stainless steel so I won't have this sticking problem any more. If the darned weight hadn't broken I'd be doing OK.
    Brandon
  9. Well, I'm not saying do it permanent, but it will get you where you have to go in the meantime.
