If the 97 is the cool 2BBL, what is the cool vintage 4BBL?
Discussion in 'The Hokey Ass Message Board' started by gnichols, Aug 22, 2011.
  1. gnichols
    gnichols
    from Tampa, FL
    Just wondering, what were the best performing / coolest 4 barrel carbs used in post WWII rods / customs / racing, say thru the early 1960s? Gary
  2. Truckedup
    Truckedup
    More or less the 4 barrel was introduced on new cars in the early 1950's.I believe Stromberg was first? Then the Carter WCFB,goofy looking Holley 4000,Rochester, and around 1957 the AFB and the Holley 4150 design .
  3. tommy
    tommy
    WCFB no they did not come on this manifold.
    Mid 50s Lincoln intake and carbs.
    One thing for damn sure it wasn't the modern Edelbrock carb with that big red neon sign saying this was not built in the 60s. If you want your car to look like an old g***er, get rid of theses signs. Just a pet peeve of mine. I had a thing for the Carter AFBs on the early 60s Chrysler engines and some Chevies but they did not have red advertising signs on them.:D Sorry sometimes I just can't help myself.:D
  4. gnichols
    gnichols
    from Tampa, FL
    Perhaps there was a cool Weber 4BBL in the 50's? (before Edelbrock started to copy them?) Gary
  5. big duece
    big duece
    from kansas
    My vote is the wcfb vette setups
      248.5 KB
  6. carbking
    carbking
    Four barrel introduction years
    1952
    Carter WCFB, Rochester 4-GC, Stromberg 4A
    1953
    Holley 2140
    1955
    Holley 4000
    1957
    Carter AFB, Holley 4150
    Factory dual quads in the mid-1950's
    Carter WCFB (Cadillac, Chevrolet, several Mopar)
    Holley 4000 (Ford, Mercury, Lincoln)
    Rochester 4-GC (Cadillac, Packard, Pontiac)
    Jon.
    HelmuthBrothers likes this.
  7. Tunning ease would be the Holley. I don't know as far as cool factor. I have always been a Holley man myself.
    I also have a real soft spot for carter AFBs and WCFBs. I guess mostly everyone is going to say that the WCFB is the coolest.
    Most of the fellas that have not grown up with WCFBs say that they are a ***** to tune. The cool factor goes right out the door if you can't make one work for ya.
    Please forgive me for high jacking the thread but . . .
    Jon,
    I got a Carter Compe***ion Series sitting on my shelf, I guess its a souped up AFB. When did they produce those?
  8. flathead4d
    flathead4d
    Definitely the Carter WCFB.
  9. R Pope
    R Pope
    Definitely NOT the Holley "Teapot", also known as the Towering Inferno!
  10. carbking
    carbking
    ****** - there are two groups of carbs marked Carter Compe***ion Series. The first are the true Carter Compe***ion Series numbers 4758, 9, 60, 1, 2) These came out in the late 1960's. The second set, with numbers above 9000, are actually clones.
    Jon.
  11. carbking
    carbking
    My first post in the thread was to list what was available.
    "Cool" is in the eyes of the beholder.
    "Best performing" is going to depend on the capability of the tuner.
    Jon.
  12. seventhirteen
    seventhirteen
    from dago, ca
    Edelbrock carbs are made by Weber
  13. Jon
    Thanks mine is 4759S I am one short of a pair. I guessed later '60s or early '70s.
  14. carbking
    carbking
    ****** - the 4759s is a 625 CFM manual choke. If you are short one of a pair, you need to revisit your old stomping grounds. ;) There is a hillbilly in Eldon that will trade carburetors for pictures of dead presidents in green frames. :D
    Jon.
  15. carbking
    carbking
    Gary - should you decide to go further with your project:
    Determine which carburetor make and type with which you (or your tuner) is comfortable. Then do the math!!! For best results, when migrating an original equipment carb from one application to another; the donor engine SHOULD be within 3 percent displacement of the donee engine. Thus if you have a 300 CID engine, 3 percent would be 9. You could use a donor carb from engines of 291~309 CID.
    Jon.
  16. I have some of those photos but I am out of toner for my printer. :D
    Next time I have two nickles to rub together I'll have to make it down that way.
  17. gnichols
    gnichols
    from Tampa, FL
    Dang, I always thought they were made in the USA under license from Weber. Not that Webers are not great carbs!
    Thanx for all the tips and info guys... please keep'em coming! Gary
  18. belyea_david
    belyea_david
    from Regina, SK
    What about the hot pink distributor cap?- probably not available in the 50's either.
  19. jay7262
    jay7262
    Nobody cares for Quadrabogs (jets)
  20. moefuzz
    moefuzz
    The 'best performing' would have to be the Autolite 4100.
    Probably one of the very few carbs ever manufactured that comes close to atomizing the fuel.
    Atomizing the fuel is what makes fuel injected engines more economical while producing more hp.
    Due to it's simple uncluttered design, The 4100 was also an easy rebuild and virtually maintenance free, unlike the Holley, carter and Rottenchester carbs.
    Autolite 4100's came in several cfm sizes, 480, 600 and a 670 cfm, all dating back as far as 1957/58.
    The design of the 4100 was more or less the offshoot of taking 2 Autolite 2100 carbs and gluing them together. The Autolite 2100 2 barrel is/was known as a very economical and reliable 2 barrel.
    clean looking:
    carbs don't get much simpler then this (holley should take notice):
    Note the four annular discharge rings, that's what atomizes the fuel:
    Fits aluminum intakes:
    Maybe not as cool sounding as "I gots a holley" but it'll make more hp and use less fuel while doing it.
  21. gnichols
    gnichols
    from Tampa, FL
    Now THAT's an answer, ICW pix. Safe to ***ume these were Ford only carbs? Or not? Gary
  22. moefuzz
    moefuzz
    Yes, Ford used them on their performance based small blocks as well as on most all FE (352/390/428) engines both for performance/Police and for regular production engines from about 1960 to 69.
    Easily found on ebay, -not so much so at pic n pull. -One hint would be to look for Big sedans with 390's in them.
    (I buy my carb rebuild kits for $20 thru ebay)
    4100 Service Manual is available on line:
    http://www.cl***icinlines.com/4100A.asp
    Ponycarbs rebuilds and modifies them but they are pricey:
    http://www.ponycarburetors.com/default.asp?page=carburetors#autolite2100
  23. Deuces
    Deuces
    I have one of these in the garage somewhere..
  24. moefuzz
    moefuzz
    It's fairly easy to figure out what you have and what the cfm/size and application were by looking for the stamped numbers found behind the accelerator pump.
    There will be a clock face with the primary venturi diameter number stamped inside of it.
    1.08 (480cfm) and 1.12 (600cfm) are the norm, 1.19 inches is the 670 cfm (good luck in finding a 670!)
    Just below that (on the mounting ear) is the actual part prefix (application/specifications number) which will tell you what engine and car the carb was designed for.
    You can use the info (Below) and at this link to decipher the Part/Spec number:
    http://mustangtek.com/4100/ford4100.html
    5752425
    Unconfirmed Application. Information may or may not be complete or accurate58 383 Mercury
    1.19 venturi 4V
    670 CFM
    Mercury Hi-torque
    C0AE-J
    Unconfirmed Application. Information may or may not be complete or accurate60 352 Full size, Thunderbird,
    Edsel
    1.12 venturi 4V
    600 CFM
    4 speed
    No Image
    C0AE-K
    Unconfirmed Application. Information may or may not be complete or accurate60 352 Full size, Thunderbird, Edsel
    1.12 venturi 4V
    600 CFM
    Auto
    C1AE-AG
    Unconfirmed Application. Information may or may not be complete or accurate61 390 Full size
    1.12 venturi 4V
    600 CFM
    4 speed
    C1AE-AH
    Confirmed Application. Information has been double checked with at least a second source61 390 Full size
    Unconfirmed Application. Information may or may not be complete or accurate61 390 Thunderbird
    1.12 venturi 4V
    600 CFM
    Auto
    C2AF-AK
    Unknown or incomplete Application. At best, the information listed is an educated guess62
    1.12 venturi 4V
    600 CFM
    C2AF-AL
    1.12 venturi 4V
    600 CFM
    C2AF-N
    C2AF-T
    C2AF-Z
    Unconfirmed Application. Information may or may not be complete or accurate62 390 Full size
    1.12 venturi 4V
    600 CFM
    Auto
    No Image
    C2AF-U
    C2AF-S
    C2AF-Y
    1.12 venturi 4V
    600 CFM
    4 speed
    No Image
    C2SF-A
    Unconfirmed Application. Information may or may not be complete or accurate62 390 Thunderbird
    1.12 venturi 4V
    600 CFM
    Auto
    C2SF-B
    1.12 venturi 4V
    600 CFM
    Auto
    C3AF-AT
    Unconfirmed Application. Information may or may not be complete or accurate63 390 Galaxie
    1.12 venturi 4V
    600 CFM
    C3AF-AU
    Unknown or incomplete Application. At best, the information listed is an educated guess63
    1.12 venturi 4V
    600 CFM
    C3AF-BU
    1.12 venturi 4V
    600 CFM
    C3AF-BV
    1.12 venturi 4V
    600 CFM
    C3AF-N
    C3AF-S
    Unconfirmed Application. Information may or may not be complete or accurate63 390 Full size
    1.12 venturi 4V
    600 CFM
    4 speed
    No Image
    C3AF-R
    1.12 venturi 4V
    600 CFM
    Auto
    C3AF-T
    1.12 venturi 4V
    600 CFM
    Auto
    No Image
    C3OF-AB
    Unconfirmed Application. Information may or may not be complete or accurate63-64 289 HiPo Fairlane
    1.12 venturi 4V
    600 CFM
    No Image
    C3OF-AJ
    1.12 venturi 4V
    600 CFM
    C3SF-B
    Confirmed Application. Information has been double checked with at least a second source63 390 Thunderbird
    1.12 venturi 4V
    600 CFM
    Auto
    C4AF-DF
    Unknown or incomplete Application. At best, the information listed is an educated guess64
    1.12 venturi 4V
    600 CFM
    C4AF-DG
    1.12 venturi 4V
    600 CFM
    1964 352 4v ford and Mercury carburetor
    C4AF-DH
    Confirmed Application. Information has been double checked with at least a second source64 390 Full size
    1.12 venturi 4V
    600 CFM
    4 speed
    No Image
    C4AF-DJ
    1.12 venturi 4V
    600 CFM
    Auto
    C4AF-N
    Confirmed Application. Information has been double checked with at least a second source64 352 Full size
    1.12 venturi 4V
    600 CFM
    4 speed
    No Image
    C4AF-R
    1.12 venturi 4V
    600 CFM
    Auto
    C4GF-AA
    Confirmed Application. Information has been double checked with at least a second source64 289 HiPo Comet
    1.12 venturi 4V
    600 CFM
    4 speed
    No Image
    C4GF-AB
    1.12 venturi 4V
    600 CFM
    Auto
    C4GF-AE
    Mustang
    Confirmed Application. Information has been double checked with at least a second source64.5 289 Mustang
    1.08 venturi 4V
    4 Speed
    480 CFM
    C5ZZ-9510-D
    1964 Mustang 4100 D code carburetor
    C4GF-AF
    Mustang
    1.08 Venturi 4V
    Auto
    480 CFM
    C5ZZ-9510-D
    C4GF-E
    1.12 venturi 4V
    600 CFM
    Auto
    C4GF-F
    Unconfirmed Application. Information may or may not be complete or accurate64 289 HiPo Comet (Canadian)
    1.12 venturi 4V
    600 CFM
    Manual choke
    No Image
    C4OF-AL
    Confirmed Application. Information has been double checked with at least a second source64.5 - 65 289 HIPO Mustang, Fairlane
    1.12 Venturi 4V
    600 CFM
    Manual Choke
    4 speed
    C4OZ-9510-D
    C4SF-B
    Confirmed Application. Information has been double checked with at least a second source64 390 Thunderbird
    1.12 venturi 4V
    600 CFM
    Auto
    C4ZF-C
    Mustang
    1.08 venturi 4V
    4 Speed and Auto
    480 CFM
    C5ZZ-9510-D
    C5AF-AA
    Confirmed Application. Information has been double checked with at least a second source65 352 Ford (w/CM)
    1.12 venturi
    Auto
    600 CFM
    C5AZ-9510-K
    C5AF-AC
    Confirmed Application. Information has been double checked with at least a second source65 390 Ford (w/MT)
    1.12 venturi
    Auto
    600 CFM
    C5AZ-9510-M
    No Image
    C5AF-E
    Confirmed Application. Information has been double checked with at least a second source65 352-390 Ford (w/MT)
    1.12 venturi
    4 speed
    600 CFM
    C5AZ-9510-B
    No Image
    C5AF-F
    1.12 venturi
    Auto
    600 CFM
    C5AZ-9510-K
    C5AF-H
    Confirmed Application. Information has been double checked with at least a second source65 390 Ford (w/CM)
    1.12 venturi
    Auto
    600 CFM
    C5AZ-9510-M
    C5AF-Z
    Confirmed Application. Information has been double checked with at least a second source65 352 390 Ford (w/MT)
    1.12 venturi
    4 speed
    600 CFM
    C5AZ-9510-B
    No Image
    C5OF-J
    Mustang289 HIPO
    Confirmed Application. Information has been double checked with at least a second source65 289 HIPO Mustang, Fairlane after 15-feb-65
    1.12 venturi 4V
    4 Speed
    600 CFM
    Manual Choke
    C4OZ-9510-D
    C5SF-A
    Unconfirmed Application. Information may or may not be complete or accurate65 390 Thunderbird (w/CM)
    1.12 venturi 4V
    600 CFM
    Auto
    C5SZ-9510-A
    C5SF-B
    Unconfirmed Application. Information may or may not be complete or accurate65 390 Thunderbird(w/CM)
    1.12 venturi 4V
    600 CFM
    Auto
    C5SZ-9510-A
    C5ZF-C
    Confirmed Application. Information has been double checked with at least a second source65 early 289 Mustang Fairlane Falcon
    1.08 venturi 4V
    4 Speed
    480 CFM
    C5ZZ-9510-J
    1965 289 Mustang 4100 A code carburetor Autolite manual 480cfm
    C5ZF-D
    Confirmed Application. Information has been double checked with at least a second source65 289 Mustang Fairlane Falcon
    1.08 venturi 4V
    Auto
    480 CFM
    C5ZZ-9510-J
    1965 Mustang 4100 A code Autolite carburetor
    C5ZF-E
    1.08 venturi 4V
    4 Speed
    480 CFM
    C5ZZ-9510-J
    65 Mustang 289 Autolite 4100 carburetor 1.08 venturi 480 cfm
    C5ZF-F
    1.08 venturi 4V
    Auto
    480 CFM
    C5ZZ-9510-J
    C5ZF-J
    Unconfirmed Application. Information may or may not be complete or accurate65 289 Mustang Fairlane Falcon exc/hipo
    1.08 venturi 4V
    480 CFM
    Left front Toe may be stamped C5ZF-C
    C5ZZ-9510-M
    C5ZF-L
    1.08 venturi 4V
    480 CFM
    C5ZZ-9510-M
    No Image
    C6AF-AB
    6A-AB
    Unconfirmed Application. Information may or may not be complete or accurate66 390 Ford (w/MT & TE)
    Unconfirmed Application. Information may or may not be complete or accurate66 428 Ford(exc/PC) (w/MT & TE)
    1.08 venturi 4v
    4 speed
    Cal emissions
    480 CFM
    C6AZ-9510-AD
    No Image
    C6AF-AC
    6A-AC
    Confirmed Application. Information has been double checked with at least a second source66 390 Ford (w/CM, C6 & TE)
    Confirmed Application. Information has been double checked with at least a second source66 428 (exc/PC) (w/C6 & TE)
    1.08 venturi 4V
    480 CFM
    Auto
    Cal emissions
    C6AZ-9510-AE
    C6AF-AF
    Unconfirmed Application. Information may or may not be complete or accurate66 428 Police Ford(PC) (w/MT & TE)
    1.12 venturi
    Manual
    600 CFM
    C6AZ-9510-AB
    No Image
    C6AF-AG
    Unconfirmed Application. Information may or may not be complete or accurate66 428 Police Ford(PC) (w/C6 & TE)
    1.12 venturi
    Auto
    600 CFM
    C6AZ-9510-AC
    No Image
    C6AF-AJ
    6A-AJ
    Confirmed Application. Information has been double checked with at least a second source66 352 Ford (w/CM & TE)
    1.08 venturi 4V
    480 CFM
    Auto
    w/Thermactor Emissions
    C6AZ-9510-AF
    Ford Mercury Autolite 4v carb
    C6AF-BU
    6A-BU
    Unconfirmed Application. Information may or may not be complete or accurate66 428 Ford (exc/PC) (w/C6 exc/TE)
    1.08 venturi 4v
    Auto
    480 CFM
    C6AF-9510-BU
    No Image
    C6AF-E
    6A-E
    Confirmed Application. Information has been double checked with at least a second source66 390 Ford (w/MT exc/TE)
    Confirmed Application. Information has been double checked with at least a second source66 428 Ford(exc/PC) (w/MT exc/TE)
    1.08 venturi 4V
    480 CFM
    Manual
    C6AZ-9510-E
    C6AF-F
    6A-F
    Confirmed Application. Information has been double checked with at least a second source66 390 Ford (w/CM, C6 exc/TE)
    Confirmed Application. Information has been double checked with at least a second source66 428 Ford(exc/PC) (w/C6 exc/TE)
    1.08 venturi 4V
    480 CFM
    Auto
    C6AZ-9510-F
    C6AF-J
    Unconfirmed Application. Information may or may not be complete or accurate66 428 Police Ford(PC) (w/MT exc/TE)
    1.12 venturi
    Manual
    600 CFM
    C6AZ-9510-C
    No Image
    C6AF-K
    Unconfirmed Application. Information may or may not be complete or accurate66 428 Police Ford(PC) (w/C6 exc/TE)
    1.12 venturi
    Auto
    600 CFM
    C6AZ-9510-D
    No Image
    C6AF-L
    6A-L
    Confirmed Application. Information has been double checked with at least a second source66 352 Ford (w/CM, exc/TE)
    1.12 venturi
    600 cfm
    Auto
    C6AZ-9510-G
    C6OF-D
    Unconfirmed Application. Information may or may not be complete or accurate66 390 Fairlane (exc/TE)
    1.08 venturi
    Manual
    480 CFM
    C6OZ-9510-A
    C6OF-E
    1.08 venturi
    Auto
    480 CFM
    C6OZ-9510-A
    No Image
    C6OF-H
    Unconfirmed Application. Information may or may not be complete or accurate66 390 Fairlane (w/MT & TE)
    1.08 venturi
    Manual
    480 CFM
    Cal emissions
    C6OZ-9510-G
    No Image
    C6OF-J
    Unconfirmed Application. Information may or may not be complete or accurate66 390 Fairlane (w/C6 & TE)
    1.08 venturi
    Auto
    480 CFM
    Cal emissions
    C6OZ-9510-H
    No Image
    C6PF-H
    PF-H
    Unconfirmed Application. Information may or may not be complete or accurate66 289 Mustang, Falcon (exc/TE)
    (Ford service replacement)
    Unconfirmed Application. Information may or may not be complete or accurate66 352 Ford (exc/TE) (Ford service replacement)
    Unconfirmed Application. Information may or may not be complete or accurate65-66 390 Ford(PC), Thunderbird (Ford service replacement)
    1.08 venturi 4V
    480 CFM
    C3AZ-9510-AU
    C6SF-A
    6S-A
    Confirmed Application. Information has been double checked with at least a second source66 390 Thunderbird (w/CM, C6 exc/TE)
    Unconfirmed Application. Information may or may not be complete or accurate66 428 Thunderbird (w/C6 exc/TE)
    1.08 venturi
    480 CFM
    Auto
    C6SZ-9510-A
    1966 Thunderbird carburetor
    C6SF-C
    6S-C
    Unconfirmed Application. Information may or may not be complete or accurate66 390 Thunderbird (w/CM, C6 exc/TE)
    Unconfirmed Application. Information may or may not be complete or accurate66 428 Thunderbird (w/C6 & TE)
    1.08 venturi 4V
    480 CFM
    Auto
    Cal emissions
    C6SZ-9510-C
    C6ZF-A
    6Z-A
    Mustang
    Confirmed Application. Information has been double checked with at least a second source66 289 Mustang Fairlane (exc/TE)
    1.08 venturi 4V
    4 Speed
    480 CFM
    C5ZZ-9510-M
    C6ZF-B
    6Z-B
    Mustang
    Confirmed Application. Information has been double checked with at least a second source66 289 Mustang, Fairlane (exc/TE)
    1.08 venturi 4V
    Auto
    480 CFM
    C5ZZ-9510-M
    C6ZF-C
    6Z-C
    Mustang289 HIPO
    Confirmed Application. Information has been double checked with at least a second source66 - 67 289 HiPo Mustang
    1.12 venturi 4V
    4 Speed
    600 CFM
    Manual Choke
    C4OZ-9510-F
    1966 Mustang 289 hipo Autolite carburetor manual application 4v 1.12 external fuel filter
    C6ZF-D
    6Z-D
    Mustang
    Confirmed Application. Information has been double checked with at least a second source66 289 Mustang, Falcon (w/MT & TE)
    1.08 venturi 4V
    Manual
    480 CFM
    California Emission
    C6ZZ-9510-A
    C6ZF-E
    6Z-E
    Mustang
    Confirmed Application. Information has been double checked with at least a second source66 289 Mustang, Falcon(w/MT & TE)
    1.08 venturi 4V
    Auto
    480 CFM
    California Emission
    C6ZZ-9510-A
    C6ZF-F
    6Z-F
    Mustang289 HIPO
    Confirmed Application. Information has been double checked with at least a second source66-67 289 HiPo Mustang-Shelby
    1.12 venturi 4V
    Auto
    600 CFM
    Manual Choke
    C4OZ-9510-F
    C7AF-AL
    Unconfirmed Application. Information may or may not be complete or accurate67 428 Police Ford(PC) (w/MT exc/TE)
    1.12 venturi
    Manual
    600 CFM
    C7AZ-9510-AL
    No Image
    C7AF-AM
    7A-AM
    Unconfirmed Application. Information may or may not be complete or accurate67 428 Police Ford(PC) (w/C6, ex/TE))
    1.12 venturi
    Auto
    600 CFM
    C7AZ-9510-AM
    C7AF-AN
    Unconfirmed Application. Information may or may not be complete or accurate67 428 Police Ford(PC) (w/MT & TE)
    1.12 venturi
    Manual
    600 CFM
    C7AZ-9510-AN
    No Image
    C7AF-E
    1.12 venturi
    Manual
    600 CFM
    C7AZ-9510-E
    No Image
    C7AF-F
    Unconfirmed Application. Information may or may not be complete or accurate67 428 Police Ford(PC) (w/C6 exc/TE)
    1.12 venturi
    Auto
    600 CFM
    C7AZ-9510-F
    No Image
    C7AF-L
    1.12 venturi
    Manual
    600 CFM
    C7AZ-9510-L
    No Image
    C7AF-M
    Unconfirmed Application. Information may or may not be complete or accurate67 428 Police Ford(PC) (w/C6 & TE)
    1.12 venturi
    Auto
    600 CFM
    C7AZ-9510-M
    No Image
    C7ZF-B
    7Z-B
    Mustang289 HIPO
    Confirmed Application. Information has been double checked with at least a second source67 289 HiPo Mustang (w/Man_choke) (w/MT & TE)
    1.12 venturi 4V
    4 speed
    600 CFM
    Manual Choke
    C7ZZ-9510-B
    C7ZF-C
    7Z-C
    Mustang289 HIPO
    Confirmed Application. Information has been double checked with at least a second source67 289 HiPo Mustang (w/Man_choke) (w/C4& TE)
    1.12 venturi 4V
    Auto
    600 CFM
    Manual Choke
    C7ZZ-9510-C
    No Image
    C8AF-AE
    Shelby
    Confirmed Application. Information has been double checked with at least a second source68-69 Police Interceptor Ford(PC) (w/C6 & TE)
    Confirmed Application. Information has been double checked with at least a second sourceearly 68 GT-500
    1.12 venturi
    600 CFM
    C9AZ-9510-AA or C7AZ-9510-AS
    PI Autolite 4100 carburetor 1.12
    C8AF-BG
    Unconfirmed Application. Information may or may not be complete or accurate68 428 Police Ford(PC) (w/C6 & TE)
    Confirmed Application. Information has been double checked with at least a second source69 428 Police Ford(PC) (w/C6 & TE)
    1.12 venturi
    Auto
    600 CFM
    C8AZ-9510-BG
    Dash Pot
    Autolite 4100 Dash Pot
  25. Real Carter afb's are a little different than an Edelbrock. The Original afb carbs came with either a drivers side OR p***enger side fuel inlet,and were a bit small than the newer Eddies. The Edelbrock performers are based of the 9000 series Carters with mechanical secondaries and the Edelbrock thunder series is the later vacuum secondary version. Before Vic bought the patent rights to them, Weber did make them. They ran into financial trouble and sold the rights to him. Now Edelbrock is makeing them in the old tooling that still has Webers markings on it.{Only doing a better quality control job}
  26. Fe26
    Fe26
    Good thread with excellent info, thanks
  27. gnichols
    gnichols
    from Tampa, FL
    Greatly appreciate all the info you guys are posting. What do the Chevy, BPO / Caddy, and Mopar guys like the most? Other cool factory HiPo stuff like the Fords? No rush, just researching my options for the next build. Later, Gary
  28. tommyd
    tommyd
    from South Indy
    The dual wcfb's are nice! Like the gl*** bowl filters.
  29. carbking
    carbking
    Real Carter AFB's, depending on original application came:
    (A) Fuel inlet pump side rear
    (B) Fuel inlet choke side rear
    (C) Fuel inlet front, choke side
    AND
    CFM ratings from 400 to 939
    I believe the clones range from 500 to 750 CFM
    Jon.
  30. jamesandrewjohnson
    jamesandrewjohnson
    from Iowa
    My dad has a Holley 4 barrel from a '57 Ford in the attic... you can't tell it apart from a traditional 4150 series. I think the 4150 was probably always the popular 4 barrel.
