For you Edsel lovers
Discussion in 'The Hokey Ass Message Board' started by Hivolt5.0, May 23, 2011.
  1. clean cut creations
    clean cut creations
  2. clean cut creations
    clean cut creations
  3. OoltewahSpeedShop
    OoltewahSpeedShop
    That's my old Villager. I knew it would turn up eventually. Went to Sweden a couple of years ago.
  4. edsel.fi
    edsel.fi
    <iframe width="560" height="345" src="http://www.youtube.com/embed/YWhVaSRB8Qo" frameborder="0" allowfullscreen></iframe>
  5. edsel.fi
    edsel.fi
    <iframe width="420" height="345" src="http://www.youtube.com/embed/xY-2QwBN5Gc" frameborder="0" allowfullscreen></iframe>
  6. edsel.fi
    edsel.fi
    My son shot me and Elli in action :O)
    <iframe width="560" height="345" src="http://www.youtube.com/embed/7speAMtGKzM" frameborder="0" allowfullscreen></iframe>
  7. edsel.fi
    edsel.fi
    <iframe width="420" height="345" src="http://www.youtube.com/embed/Tm6tS4zq_QE" frameborder="0" allowfullscreen></iframe>
  8. edsel.fi
    edsel.fi
    <iframe width="560" height="345" src="http://www.youtube.com/embed/BzUB5ovSi2U" frameborder="0" allowfullscreen></iframe>
  9. edsel.fi
    edsel.fi
    different....
    <iframe width="560" height="345" src="http://www.youtube.com/embed/Q8ARV_ySj_w" frameborder="0" allowfullscreen></iframe>
  10. 0rg0
    0rg0
    Here's my '59.
  11. DRUGASM
    DRUGASM
    Well, like a teenage girl changing clothes before a big date I've changed my mind again! I decide to sell it then I buy a bunch of parts to fix it. I'll be sending the 390 block down to the machine shop soon. I have my new, used vintage Offy intake for it and have been researching cams for the rebuild.
    Wish me luck. Any hints, tips, or suggestions for pulling the engine? I am thinking about pulling the whole front clip off... That seems like a daunting task that's just asking for paint damage. I also have been thinking about fabbing up some type of swing-set puller to yank that thing straight up and the roll the car out from under it.
    I know kuumayktii has done the pull.... Who else? What works? What doesn't?
  12. Oldmics
    Oldmics
    I yanked the 361 outta my Roundup wagon.
    I did it with a modified P.O.S. Horrible Freight hoist.
    I extended the boom arm on the H.F. piece another 10" to clear the front of the cars "horse collar".Worked like a charm.
    A BlueBird will not have the extra length to clear the grill.
    Oldmics
  13. I took the sheet metal off, but I haven't painted yet.
    That is a whole lot of engine to get up and over.
  14. DRUGASM
    DRUGASM
    Oldmics that engine is almost as ugly and greasy as mine! That's is a whole lot of weight to get up and out. I'm planning on pulling as much off as I can before it comes out. Hopefully I'll just be pulling a short block. No heads, intake, manifolds, trans, etc.... time will tell.
    Anyone else? That is helpful so far....
  15. edsel.fi
    edsel.fi
    I first took whole front end off.. bit by bit. I had to do it, I wanted to rebuIld & repaint everything under hood.
    Most painful was 2 fender bolts behind kick panels. Paint will suffer when you took fender off (or install those). Maybe even those 2 clips what are holding bolts under kick panels, start to turn freely, you can`t take bolt of from ther without violence.. Well, when bolts starts to turn freely, you can pull front fenders foreward... clips will sepertate from fenders without damage. SO, now Elli is working nicely, and front fenders are there tooo... quess what, while tightening driver side kick panel nut, it started to turn freely there... time to took fender off, and weld that clip to its place.. There are some clearing issues on Driver side door and front fender now..
    Pulling engine is not so difficult, playing with front fenders are!
  16. '59Edsel
    '59Edsel
  17. I had to use my cherry picker just to remove the intake! ;)
  18. clean cut creations
    clean cut creations
    The captured nuts in the fenders are a P.I.T.A!!!! Rust in the bolt threads takes over and becomes stronger than the tiny welds/crimps holding them into the fenders. Take your time getting these ****ers off. Patience is the key.....
  19. wallygator
    wallygator
    Drew I have a heavy duty cherrypicker you can use that has plenty of lift and strength, just come and get it.
  20. DRUGASM
    DRUGASM
    I want to try and leave the clip on, but that's a lotta weight to swing over the fender. No matter what I am guessing I'll have to pull at least the hood.
    Time to start working out.... I may need some muscles for that iron SOB.
  21. Oldmics
    Oldmics
    Pulling the hoods DEFINATLY a two man job and is a must for engine removal access.
    That being said as long as your cherry picker has enough boom length to extend to the center of the engine WITHOUT bumping into the horse collar and of course the heigth,I would not worry about the paint.
    I had to remove the engine from my Roundup once it was painted and had no issues at all.Just cover everything thing up-twice!
    I would yank it all out at once rather than diss***embling the intake,heads,etc.
    Your mileage may vary however.
    Oldmics
  22. Jeff Walker
    Jeff Walker
  23. DRUGASM
    DRUGASM
    I guess it's time to turn in the recycling and sell some parts off... Thanks for the input guys.
  24. hotdamn
    hotdamn
    hey guys just wanted to let ya'll know I dropped the price of my Edsel down to 9k. very motivated to sell as I found another car I cant live with out :D
    This Edsel is super solid with only one very small rusty spot. everything else is like a Lional Ritchie brick house :D
    http://www.jalopyjournal.com/forum/showthread.php?t=593066
    dig it.
  25. lounissarte
    lounissarte
    here is mine Villager 58...
  26. DRUGASM
    DRUGASM
    Well Lou ---- go on. Tell us more about that wagon... it looks awful damn low and I like it.
  27. peter schmidt
    peter schmidt
    from maryland
    One off my rust buckets [​IMG]
  28. '59Edsel
    '59Edsel
  29. That makes me reconsider the green I bought.
  30. edsel.fi
    edsel.fi
    <iframe width="640" height="480" src="http://www.youtube.com/embed/rLK_k84EBlk" frameborder="0" allowfullscreen></iframe>
