White walls question
Discussion in 'The Hokey Ass Message Board' started by camojams, Aug 23, 2011.
  1. camojams
    camojams
    What does everybody use to clean there white wall when they get a little older?
  2. FormerFueler
    FormerFueler
    I always had good luck with Bleche White.
  3. 49ratfink
    49ratfink
    I use the same stuff I used when I was younger.
  4. hombres ruin
    hombres ruin
    do a search ,this topic is all over the hamb..but for old times sake i use bleech white
  5. WDobos
    WDobos
    I used bleech white for years and never liked the fact that the acid in it would atack paint and alum. I found that Simple Green does just as good of a job with NO harmful problems. Just spray it on give it a min. or so then brush it off. The whites are as white as new!!!!!!!!!!!!!!!!
  6. wizzard23
    wizzard23
    Simple Green or 409 works on our Diamond Backs.
  7. 03GMCSonoma
    03GMCSonoma
    I used to use SOS pads.
  8. Stevie Nash
    Stevie Nash
    And that's what they recommend. Bleach will dry them out over time...
  9. Wide Whites
    Wide Whites
    from N. Texas
    I typically just use some SOS pads. Scrub them good and let it sit. Then just rinse off. Sometimes just sitting them in the sun for awhile brings the white out!
  10. Big Dan Style
    Big Dan Style
    Yup.. bleche white cleans awesome but it seems mine dried out fast. I have switched to simple green/soap and water now.
    ** I have wondered 1000 times why the hell its spelled BLECHE. I had to do a damn google search just to see if i was right!!
  11. hotrod_32
    hotrod_32
    Simple Green is the **** ! Get a bad spot,600 wet paper with alittle dish soap works great. Diamond back says no bleach white !
  12. pecker head
    pecker head
    Never had a set of biasplys last long enuff to get old !
  13. 48 Chubby
    48 Chubby
    Really old white walls will clean up nice with the profesional floor wax stripper. It is sort of hard on em, but to get whitewhite on several year old tires it really works. It also seems to melt the top layer of rubber.
    It is sold under the brand name "Jet Axe".
  14. hotrodladycrusr
    hotrodladycrusr
    Yep, like others have said, Simple Green. Wet the tire, spray it on, lite scrub with a brush then rinse off. Just as good as new. I never use anything with bleach in it on rubber.
  15. HOTRODRUBBER
    HOTRODRUBBER
    Mr Clean MAGIC ERASER and Wesley's.
    Yall can thank me later :D
    HURST RACING TIRES
  16. Answer: Paint the car to match a dirty side wall...
    ...or use Arm & Hammer cleanser if you're into clean white tires.
    I prefer the road film though:cool:
  17. gasser300
    gasser300
    from Ft Worth
    Mean Green from Dollar general.
    5 bux a gallon and much better than Simple Green. IMO
  18. mgtstumpy
    mgtstumpy
    Ajax and a nylon kitchen scourer and some elbow grease.
  19. coolbreeze1340
    coolbreeze1340
    from Indiana
    Simple Green is the BOMB! Some whitewall makers say not to use the old bleach white because it dries them out and causes cracks. Simple green can clean anything. I use it (deluted) to take the bugs of the fairing on my HD dresser. Just be sure to cut it with water for painted surfaces.
  20. Andrew Williams
    Andrew Williams
    i use SOS/Brillo pads and 409, works good.
  21. Peck
    Peck
    I've had some success with a mix of laundry stain remover (Vanish etc), washing up liquid and water. Mix it to a runny paste, scrub it in, leave it for a while, then rinse it off.
  22. Lone Star Mopar
    Lone Star Mopar
    Magic Eraser and water, No bleach needed. Its the easiest thing Ive found to clean my whites.
  23. Chris Stapley
    Chris Stapley
    Spray Nine, take it from a kid who grew up at a used car lot. Best interior cleaner you can ask for too!
  24. lowphat53
    lowphat53
    from Virginia
    Mr. Clean Magic Eraser is the best thing EVER!!! use it with water and even bleach white if ya want but you all you really need is water... It does wonders!
  25. damagedduck
    damagedduck
    from Greeley Co
    Mr Clean MAGIC ERASER.
    soft scrub with bleach.
    simple green.
    cheap *** toilet brush.
    man the dollar store is my friend.i been using all 3 for years on my W/walls on my chopper for years with no problem.-chuck
  26. carlos
    carlos
    from ohio
    SOS pads Still best!!
  27. camojams
    camojams
    Thanks for all the input
