235 remote oil lines
Discussion in 'The Hokey Ass Message Board' started by slinginrods, Aug 23, 2011.
  1. slinginrods
    slinginrods
    from florida
    i have a beehive remote oil filter i want to use with my 235 chevy,what size lines should i run? i was thinkin 3/8 ,it had some -4 braided line on it when i got it.also where can you get replacement elements for it?
  2. markjenks
    markjenks
    You could go with 3/8 or 1/4 if you are running a babbit 235.
    If you are running a full pressure, I would look a 1/4 lines to make sure you get the flow.
  3. slinginrods
    slinginrods
    from florida
    its a 1955 235 ,there full pressure right?
  4. Kustom Kid 53
    Kustom Kid 53
    Yeah it is a full pressure engine. I got a fram filter form autozone.
  5. slinginrods
    slinginrods
    from florida
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    Remember if this is the stock style byp*** filter system there MUST be a 1/16 [.062] restricter fitting in the supply line. Otherwise you will starve the bottom end for oil. 1/4 " line is more than big enough.
  7. slinginrods
    slinginrods
    from florida
    it was installed on the engine when i got it,where would the restricter be?the lines that were on it were leaking ,one was cracked.its not thekind that mounts to the intake.ill try to get pics up
  8. markjenks
    markjenks
    Byp*** was only on the babbit, not the full pressure? On mine they called it byp***, but did they call it byp*** also on the full pressure?
  9. Kustom Kid 53
    Kustom Kid 53
    Sorry I misread that you have a beehive filter cant help with that.
  10. slinginrods
    slinginrods
    from florida
    pics
