Straight Axle Help?
Discussion in 'The Hokey Ass Message Board' started by 1low1954ford, May 13, 2005.
  1. 1low1954ford
    1low1954ford
    from LA
    I NEED SOME HELP GUYS! I HAVE DRUM BRAKES AND SPINDELS AND A STEERING BOX FROM A 1954 FORD PICK UP AND SOMEONE TOLD ME I CAN MAKE THESE WORK ON A CUSTOM SPRING OVER STRAIGHT AXLE.
    IAM LOOKING FOR A STRAIGHT AXLE THAT WOULD GO WITH THESE BRAKES BECOUSE THEY ARE SELF ADJUSTING AND THEY ARE JUICE BRAKES.
    I WAS LOOKING AT AN AXLE FROM SPEEDWAY PRODUCTS THAT COMES WITH 6" DROP,SPRING OVER,& RADIUS RODS FOR ABOUT $400.00.
    COULD I MAKE THESE BRAKES FIT THIS FRONT END. IT IS GOING ON A 1931 CHEVY PICK-UP. IF ANYONE COULD HELP I HAVE NOT DONE A STRAIGHT AXLE YET THNX.:confused:
  2. bad gas
    bad gas
    As Far As I Know The Brakes Will Fit On A 46-48 Spindle. There Is A Tex Smith Book How To Build A Hot Rod Ch***is And It Shows How To Do The Conversion.
  3. 1low1954ford
    1low1954ford
    from LA
    THANKS I HAVE ALL THESE PARTS FROM DOING THE CLIP ON MY 54 AND KEPT THEM FOR THIS PROJECT ANYWAYS THANKS AGAIN:cool:
  4. Paul
    Paul
    Editor
    duplicate posts are not necessary
    typing in all capitols is yelling
    a 6" dropped axle is not a straight axle.
  5. 1low1954ford
    1low1954ford
    from LA
    sorry about 2 posts did not know if i was doing it right :confused:
    i meant straight axle becouse it is not ifs.
  6. The correct term... if you are so inclined to want to know what it is... is solid front axle... :D
    Sam.
  7. 1low1954ford
    1low1954ford
    from LA
    thanks sam now i dont have to sound like such an idiot i thought i had it right now i know:D
  8. manyolcars
    manyolcars
    Your 54 Ford pickup brakes work on Fords from 1928 to 1948, and on the pickups til 1956. those brake shoes fit 1948 to 1966 pickups. 54 wheel cylinders were slightly larger than the other years, may be hard to find that one year only.
  9. 1low1954ford
    1low1954ford
    from LA
    thanks for the detailed help i will need all this when i tackle it
  10. 1low1954ford
    1low1954ford
    from LA
  11. Scott
    Scott
    I just finish this swap with advice from deuce roadster. Actually followed his instructions
    you will need 37-41 spindles. here is the post
    http://www.jalopyjournal.com/forum/showthread.php?t=5877
    As bad gas stated tex smiths book also gives a good instruction. howver Deuce roadster gives you more options for parts interchangeability utilizig self adjusting brakes
