Can I use my Stock 47 gauges with my upgraded 12 volt 302 ci C4 drivetrain
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by scottpaul2, Aug 25, 2011.
  1. scottpaul2
    scottpaul2
    I would like to know if it is possible to connect and/or adapt my stock speedo, amp(volts) and temp gauges on my 47 ford sedan to the upgraded 12 volt system with a 302 ford engine and C4 ******. I would prefer not to add additional gauges nor change the look of the stock gauges. Any recommendations????
  2. millersgarage
    millersgarage
  3. scottpaul2
    scottpaul2
    So, the sensors and speedo connections on my 302 and C4 will produce the correct reading to the stock 47 ford gauges? (other then the voltage change) Thanks for the advice!!!
  4. millersgarage
    millersgarage
