so the volt gauge in my model a has been acting funny the last week or so, jumping around alot between 14-16 volts.... ok no problem ill just rebulid the alternator... fast foward to today. I take apart the alternator (stock chrome GM style internal reg.) to find the diode trio is burned up, Great! i install the new voltage regulator, diode trio, brushes, ohm the stator, clean up the commutator where the brushes ride, new bearings etc.... put her all together, runs good charging just over 14. Cool! go to shut it off..... still runs... ? i know about putting a diode in with the exciter wire to keep from feed back to the ign switch. ( had to do this on my OT Nova) my question is why now? i put this car together 6 years ago and never had this problem before? why with a rebulit alternator does this problem start? or could it be in the ing switch and it just **** today? what do you guys think?
I'm guessing that the old regulator in the alt didn't need the diode and the new ones does. 5 mins fix after a trip to radio shack.
no stock points ing system, i know what you mean about the MSD box, i run a digtal 6 box in my Nova and it did the same thing to me after i installed it. that i could understand because the car had never ran with a msd system before.
oh by the way guys i forgot to add in my first post.... after the car not shutting down with the chrome alternator that i was in, i put on a stock GM alternator that i had laying around just to try it...... same **** wont shut down....? Mark i see what your saying about the new regulator not needing the diode, but with 2 different alternators and still the same problem?
If you have an accessory side on your ignition switch, if you tie the exciter to that side and the ignition to the ignition side, they will separate when power is off and you won't need a diode.
There is a little known condition with GM alternators where they are prone to backfeeding despite all electrics being switched off - cost me a lot of money finding this out the hard way. Painless Wiring has a kit for around $85.00 to eliminate this problem....
thanks for the info guys, iam sure i will get this taken care of later today when i get out of work, my question is still why has this car been fine and shut off for the last 6 yrs? only when i changed the parts in the alt. with new parts has this problem came up? i dont have a problem doing any of the above to slove it...it just really seems odd that it has been fine up untill now?
All power to your dizzy should go through the ignition switch with the exception of the hot start wire that comes from your starter solenoid. You should not be getting any hot directly from the alternator to the ignition. if you are you have it wired wrong. First thing I would try is this; if you have a hot start wire from the solenoid to the coil, shut the switch off and then pull the hot start wire from the solenoid. If that kills it I would suspect the starter solenoid. If it still doesn't shut off I would suspect the ignition switch.
I think any electrical part that has small colored parts in it is FM, (FREEK'IN MAGIC) and I don't argue with it, put in the diode! Lights will go bad setting on the shelf I have found fuses that LOOK good, are not the list goes on.............................
Guys i think everyone is missing my question......... i dont have a problem putting in the diode if thats what needs to be done, what i want to know is why does it need it now? this car has been shutting off with the key for 6 years with out a diode in the wire!
I Remember now,one of the bolts in the diode trio is the wrong one and is grounding it full time,ck the bolts and you should be fit to go. All three should have a plastic washer on them.
ok thanks this was the kind of answer i was looking for, when i took it apart only 2 had the plastic washer around them, so i put it back together that way........ maybe this is the reason that the old diode trio was burnt to a crisp, and the volt gauge was jumping around all over the place....??? iam going to take the alternator back apart and double check everything... thanks guys!
I have the exact same problem, when my chromey alt went out, got to go to radio shack to get a diode. Anyone have a part #? My local radio shack is lacking a little knowledge in that department. Thanks.
how is your alt wired? mine was...the exciter wire was to #1 on the plug and #2 looped over to the battery lug it worked fine this way for 6 years, untill i replaced the parts, talking to a friend that rebuilds alternators, generators, starters etc.... he told me that some of the replacement parts they sell require the #1 and #2 to be switched....dont ask me why?? he went into why they have to be switched but i didnt get what he was talking about. anyway, i did this and the car shuts off with the key and charges just fine...... try this it may work....
