Cadillac sombrero hubcaps
Discussion in 'The Hokey Ass Message Board' started by BICKFORD, Jan 3, 2010.
  1. BICKFORD
    BICKFORD
    from CA
    i thought i saw a article in TRJ about a place that makes repos. if anyone has any infor on them please let me know.
    j
  2. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I know a gut that has mint hubcaps ,He wants 900 for them .These are concourse quality
  3. 48cad
    48cad
    Mcvey's has em
    UNSHINED 2 likes this.
  4. Gotzy
    Gotzy
    Are sombrero's 16" or 15"?
  5. Mr48chev
  6. john walker
    john walker
    Mcvey's have a brown tone. the center medallions are nice though.
  7. Gotzy
    Gotzy
    What do you mean there, bad chrome?
  8. Kiwi 4d
    Kiwi 4d
    what wheel are the repo caps designed to fit? What h***les can we expect fitting to 15x6 late ford steels. I am thinking the 57 caps
  9. I've got originals on my '54 Ford. I welded them to trim rings that fit the Ford wheels. They need to be re-plated but I can't find anyone that will do them. I don't have a picture on file and it's 9 degrees outside so you'll have to use your imagination.
  10. K13
    K13
    Theres are stainless so it is not bad chrome.
  11. shoeboxsean
    shoeboxsean
  12. Ian Berky
    Ian Berky
    What's the deal with these caddy sombrero caps on chevy wheels? I hear you gotta weld a different inner cap or something like that? That means buying a fresh new cap and having to weld on it??? :confused:
  13. resqd37Zep
    resqd37Zep
    from Nor Cal
  14. K13
    K13
    I think most guys use a trim ring but yeah that is the general idea. These days I would be more inclined to use an automotive grade adhesive than weld them so you don't have to worry about warping etc that welding might cause.
  15. Special Ed
    Special Ed
    I've got mine mounted on some junkyard Dodge steel rims. Fifteens. No modification on them at all. they are aftermarket stainless steel...:)
  16. EXK
    EXK
    from SO CAL
    If interesed I have some Nos 52 Sombreros polished stainless steel that have never been plated. Will sell them for $150. ea
    Mcveys makes a good quailty repo stainless steel chrome plated 52 and 57 cap but there chrome is not so great.
    I mount the 52/53 sombreros to the smaller Od 15" trim ring with a good epoxy. The trim rings that show about 1/2" of the outside edge of the rim. They are kind of hard to find used and cheap so I usally buy these trim rings new from Jim at Night Prowller for about $25. a set 2.
    Sorry, no pics at this moment but will be doing some 52's and 53's next week and will snap a few pics for you
  17. Gotzy
    Gotzy
    Doh!!
    Has anyone adated Sombrero's for 16" rims? Suppose it's the same deal as fixing them to a trim ring?
  18. John Denich
    John Denich
    I have 53's on Chevy rims...Really easy to put on and NO I did not weld or bond the ring on them I wanted them to fit flush to the rim...Like I said really easy!!!!
  19. barfers
    barfers
    from Florida
    on the 51' sombreros what size cap do you customize for a stock ford rim, 15" or 16" cap?
  20. TOYBOX
    TOYBOX
    The 54-55 caddy hubcap inner ring fits well. Just grind on the outside lip.
  21. TOYBOX
    TOYBOX
    They fit under lip.
  22. TOYBOX
    TOYBOX
    YOU CAN TIG THEM OR EPOXY THEM. They sit inside the rim lip. Real tight.
  23. TOYBOX
    TOYBOX
    Just be careful if you weld them. The heat will mess up the chrome.
  24. CutawayAl
    CutawayAl
    from MI
    Answering an old question, there were 16" Sombreros. I had a '49 he**** that was factory built with 16" wheels, and it had sombreros. I have no idea what other years or cars(limo?) would have had them. I was missing one and tried a 15". It fit securely onto the wheel, but the width or offset of the 15" wheels was apparently different than the 16" wheels. The edge of the 15' wheel cover stood away from the rim of the 16" wheel maybe 3/4". It looked better than nothing, but people were constantly warning me that my wheel cover was coming off.
  25. TOYBOX
    TOYBOX
    <TABLE border=1 width="100%"><TBODY><TR><TH>Model</TH><TH>Wheelbase</TH><TH>Overall Length</TH><TH>Front Tread</TH><TH>Rear Tread</TH><TH>Tires</TH></TR><TR><TH>Series 61</TH><TH>126 inches</TH><TH>215 inches</TH><TH>59 inches</TH><TH>63 inches</TH><TH>7.00 x 15</TH></TR><TR><TH>Series 62</TH><TH>129 inches</TH><TH>220 inches</TH><TH>59 inches</TH><TH>63 inches</TH><TH>7.00 x 15</TH></TR><TR><TH>Series 60S</TH><TH>133 inches</TH><TH>224 inches</TH><TH>59 inches</TH><TH>63 inches</TH><TH>7.00 x 15</TH></TR><TR><TH>Series 75</TH><TH>136 inches</TH><TH>226 inches</TH><TH>59 inches</TH><TH>63 inches</TH><TH>7.50 x 16</TH></TR></TBODY></TABLE>
    Yes they made 15'' and 16''. 15'' measure 16'' across. And the 16'' measure 17'' across. They were used on the Series 75. Used from 1947-1949.
  26. CutawayAl
    CutawayAl
    from MI
    Thanks for the info. The chart you posted lists the Series 75 limousine ch***is. Not included is Series 86, which at that time was called the "commercial" ch***is. Series 86 was used mostly for ambulances and he****s. As I already posted, my '49 Series 86 he**** had 16" wheels with sombreros.
  27. GreggAz
    GreggAz
  28. Theo Douglas
    Theo Douglas
    Anyone with a spare 16-inch Sombrero--send me a private message. Please! I'm down one.
    I have three Series 75 sombreros that are going on my shoebox, and the reason I need a fourth is because the guy who sold them to me thought he HAD four.
    That's how closely the 15-inch and 16-inch sombreros resemble each other.
    You have to measure to figure out that the Series 75/86 ones measure 17 inches in diameter.
    Thanks for the great information, and especially for the Series 86 information. I never knew that; I thought all the 16-inch caps were Series 75.
    The HAMB comes through again!
