When were hood scoops first used?
Discussion in 'The Hokey Ass Message Board' started by Kerry, Aug 10, 2011.
  1. Kerry
    Kerry
    When were hood scoops first used? Any pictures? I'm fighting a hood clearance issue but I want the wagon to look early sixties.
  2. mid 1963 from Mopar
    Several cars had fake ones before that - T Birds etc.
  3. Ned Ludd
    Ned Ludd
    Austin-Healey 100-6, introduced 1956:
    This was more about clearance for the six-cylinder engine than engine breathing, but as far as I know it is a real scoop.
  4. pwschuh
    pwschuh
    I hate fake hood scoops.
  5. Kerry
    Kerry
    This would be real. I learned about driving with a functional scoop in my Camaro. Drove it in freezing rain on the way home from college once and couldn't understand where all my power went when the air cleaner froze up.
  6. Had the throttle blades freeze open on my Duster once on a cold damp morning - a little scary
  7. squirrel
    Leave the hood off it, until you find an older pair of heads and a different intake....
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The SD Catalinas used a scoop from Ford medium duty trucks.
  9. tommy
    tommy
    I never knew that the 55-57 T-bird hood scoops had a removable block off plate. I was checking out a beautiful bird and in the trunk was a piece of metal with a decal on it that says remove for summer operation or something close to that. It's a block off plate for the hood scoop. I always thought that they were fake. I'd have lost a 20 on a bar bet.:D They are indeed functional.
  10. flamedabone
    flamedabone
    So....what exactly are you doing that won't fit under the hood??????
    -Abone.
  11. 296ardun
    296ardun
    I don't have a picture of it handy, but Gene Adams' 50 Olds fastback had a hoodscoop back in '57, to clear the blower on his 371 motor...someone else may have a shot of it, was featured in a '57 HRM...so you can have a scoop and even get the late '50s look
  12. Squablow
    Squablow
    Yes they did, so '55 would probably be the first year of functional ones on anything production. I got a couple junk hoods at an auction recently that I bought just to cut the scoop part out to weld into something custom, they're good looking.
    My '53 Ford has a '58 T-bird scoop welded to the hood where the opening was redone with round rod to make it functional and to eliminate the pot metal insert, looks really nice I think.
  13. squirrel
    It appears he's building a tow vehicle for his old dragster, and wants the tow vehicle to look "right". It also appears that he bought a "late model" small block mopar mill for it, and the only intake that will fit, that works with a carb, is too tall, since it's more of a race piece.
    A proper period tow vehicle will have a mostly stock, era correct big block in it...??? I'm thinking a 413.
    Tough situation to be in.
  14. Kerry
    Kerry
    Yep Squirrel, that pretty much sums it up. I put an A833 O/d behind the 360 magnum.
  15. Gotgas
    Gotgas
    from DFW USA
    '53 Dodge had an opening to the engine compartment on cars built with the Hemi. Is it a scoop? Dunno...
  16. flamedabone
    flamedabone
    Yea, but I wouldn't have been suprised if you would have showed up at the HAMB Drags with something like this crammed in there...
    See ya, -Abone.
  17. Cerberus
    Cerberus
    Here's a '55 tbird hood scoop I saw-sawed off a hood in '74. I put it on my 55 Wgn and ran it 10 years. Now it's on the garage wall with a few others. LOL
  18. aircap
    aircap
    If I remember correctly, Packard had functional scoops first - in the 50's, maybe on a Caribbean?
  19. Kerry
    Kerry
    In my dreams Abone, in my dreams!
  20. tommy
    tommy
    How about a cowl scoop?
  21. johnny bondo
    johnny bondo
    from illinois
    well ive seen scoops on 30s race cars....
  22. ehdubya
    ehdubya
    They're as old as cars
  23. HealeyRick
    HealeyRick
    from Mass.
    This sure looks like a 55 'bird scoop on this Healey with a 283 swap done in 1957 by Max Balchowsky.
  24. Normbc9
    Normbc9
    I do believe your memory is correct. We had '51 Packard Henney ambulances in our Fire Department with the straight eights and they had factory air scoops on the hood. That was more than 60 years ago.
    Normbc9
  25. pwschuh
    pwschuh
  26. greendragon
    greendragon
    Henny would build what ever you wanted. but the scoops were not the norm for them. but Packard did use one on the 52 pan-american show cars. they then put them into production with the introduction of the caribbean.
  27. Magnus_Jager
    Magnus_Jager
    My 54 dodge has one as well. The scoop has a metal p***age that lets cold air p*** the radiator towards the top of the old oil bath filter. Its not connected but its kind of a cooler air source for the carb. I'm toying with a shroud/tunnel to connect mine to the carb.
