Distributor will not sit all the way down..
Discussion in 'The Hokey Ass Message Board' started by 33_chevy, Aug 31, 2011.
  1. 33_chevy
    33_chevy
    from TX
    I got a 1962 327 sbc and for some reason the dizzy will not sit all the way down on the intake.It sticks up about 1/8 to 3/16.the oil pump is a melling HV pump and intake is a 4x2 wiend and dizzy is a unilite mallory.Could it be this pump is for big block??..I have tried everything to get it to sit down..Any help would be appreciated..
  2. squirrel
    you did line up the notch in the shaft? Or did you try turning the crankshaft, and letting the distributor drop in place when the notch lines up?
  3. 33_chevy
    33_chevy
    from TX
    I did..I took the pan off also and it looks like it is in place..
  4. Mr48chev
    Squirrel beat me to it while I was typing. Have you cranked the engine over or turned the crank over by hand a couple of times to see if the distributor drops down on the intake. It's pretty normal for them to not drop down all the way when you set them in.
  5. barslazyr
    barslazyr
    Is it possible you have a front sump pump? The drive on a front sump is a little longer than a normal pump.
  6. Hotrodbuilderny
    Hotrodbuilderny
    What he said!^^ Try turning the motor with light pressure holding down on the distributor, if it doesn't go down might be a burr on the shaft ,or inside the bottom of the distributor, if not you might have a big block drive rod
  7. BADBIRDCAGE
    BADBIRDCAGE
    from Virginia
    Wouldn't be the oil pump but could be an incorrect intermediate shaft. If you have a big block shaft in a small block it will cause the distributor to sit up even when fully seated in the notch on the shaft. It will engage the camshaft drive gear and the engine will run but your right side lifters and rockers won't get proper oiling as the distributor is not sealing the oil p***age correctly.
    Hopefully it is just a case of the distributor not being all the way seated down in the correct intermediate shaft.
  8. 33_chevy
    33_chevy
    from TX
    I just got the motor together so it's pretty tight.I will hook a battery up and see if i can crank it..
  9. davidbistolas
    davidbistolas
    you could also just pull the plugs, eh? (Drop a squirt of oil into the cyls too, so it's not totally dry when you crank it over).
  10. 33_chevy
    33_chevy
    from TX
    I did check on the shaft and it was for a small block..Is there a difference in big block pump and small block??as far as pump shaft
  11. swade41
    swade41
    from Buffalo,NY
    Take the cap off and wiggle the rotor a little as you are dropping it in, I've had to do that in the past. Another thing make sure it's not hanging up on the distributor hold down clamp.
  12. 37gmc
    37gmc
    from upstate ny
    is the manifold new? just wondering if the manifold had been cut to fit shaved heads
  13. 408 AA/D
    408 AA/D
    If it is a B.B. Chev. pump you need a 5.625 length oil pump shaft best I remember. I suspect that the distributor is not dropping into the oil pump shaft though. As stated earlier apply pressure to the rotor and rotate the ***y. You can also just try to drop the distributor in at different locations and if it fully seats then the shaft is not aligned with the slot at the base of distributor at the # 1 position.
  14. squirrel
    I have a long screwdriver that I scored a line on the end of the handle, in line with the blade. I use it to turn the pump shaft to line up with the tang on the distributor, before I install the distributor. Works almost every time.
  15. chevelle bob
    chevelle bob
    from Linton
    Has the distributor been used before or is it new? I bought a new one for a 305 I was building and could not get it to go in. Found out the housing was drilled off center and the gear would hit the cam and not line up. I had to take the guts out of it an put into an old housing and it fell right in place.
  16. perk30
    perk30
    I had that problem once and had to file the end of the distributor shaft where it fits in the groove in the oil pump shaft because it was not fitting in completely. Didn't have to file a lot but once I did, it dropped all the way down.
  17. resqd37Zep
    resqd37Zep
    from Nor Cal
    Make sure the gear isn't upside down.
  18. Fopelaez
    Fopelaez
    What he said, has happened to me and I spent two days figuring out why it was not going all the way down. :eek:
  19. Ebbsspeed
    Ebbsspeed
    Crossed my mind too, although 1/8 to 3/16 of an inch would be quite a bit.
  20. CutawayAl
    CutawayAl
    from MI
    If the engine can't be rotated with a breaker bar or flywheel tool I would be concerned about that.
  21. H.G. Wells
    H.G. Wells
    I had this happen recently with a BBC. The MSD that came with the motor fit fine, the Vertex mag would not drop. Turns out the oil pump shaft was mushoomed just enought to not slip inside the dist. gear. The gear on the MSD was opened just enough to allow the fit. Pain in the *** to swap the drive, but that is what it took to cure it.
    Hopefully yours will be one of the simple solutions mentioned above. But if not look down the hole with enough light to see if the ears on the shaft are splayed out.
  22. 37.5
    37.5
    from mn
    If that oil pump is for an early nova, it will do exactly what is happening. The oil pump on the earlier models were shorter. Just a thought.....good luck!
  23. BADBIRDCAGE
    BADBIRDCAGE
    from Virginia
    This is the second post where someone has mentioned a difference in length of the oil pump. I am not familiar with what your are speaking of. In every generation one small block chevy I have seen the oil pump (factory application; not dry sump) mounts to the rear main cap.
    Regardless of stock, high volume (longer gears in the pump so the pump housing is longer but does not change the mounting point) or front sump application the pump mounting point is the same. The intermediate shaft is attached to the oil pump and is driven by the distributor shaft when the distributor is installed.
    The only time I have seen the failure of a distributor to seat on the manifold, as described by the OP, is when a big block intermediate shaft was mistakenly used as the big block shaft is longer than the small block shaft. In that case the distributor sat about a half inch above the manifold and was completely seated into the intermediate shaft.
    I've been out of the automotive machine shop business for quite a while but I am still willing to learn. Can someone explain to me what the difference is in the oil pump mounting point on an early Nova (front sump application) that would make the distributor sit high?:confused:Ready to learn.
  24. Hotrodbuilderny
    Hotrodbuilderny
    Another thought is, do you know what the distributor is for,is it possible it's for a tall deck block? I had a customer about 25 yrs ago bring in his car for the same problem, turned out he had an accel for the chevy truck block. same as the newer tall deck heght,
    measure it against a known small-big block distributor
  25. fms427
    fms427
    This is taxing the old memory banks.......I used to run a Melling "big block high volume pump" made for small blocks - as I remember it the difference was the shaft length - which tells me the pump shaft length is different between big and small blocks, and you could have a big block pump. About all the help I can be - check the other stuff first !
  26. Igosplut
    Igosplut
    This is exactly what I thought hearing this....
  27. lippy
    lippy
    from Ks
    Just a thought. Is this a new engine? If so, could the dist housing flange be hitting the intake? I always leave the intake bolts loose when I install the dist for the first time , get the dist centered and down, then tighten the intake bolts. Lippy
  28. 37.5
    37.5
    from mn
    1964 Chevrolet Nova with a factory V-8 has it's own special oil pan, oil pump, which is shorter, and a distributor shaft that goes from the distributor to the oil pump is about 3/16 of an inch shorter than any other small block motor. All three of those items have different part numbers. They are Nova only. I know this because I have installed a regular oil pump drive in a Nova and the Distributor sticks up 3/16 of an inch above the maniford. The oil pump still mounts on the main exactly the same as all other small blocks. It is just tighter to the crank. Terry.
  29. lexington
    lexington
    All though im not familiar with the dist you are using, if its an after market one many of them such as msd are adjustable the flange on the bottom of the dist is movable. They are made this way because as previously stated it is done for head milling purposes.also there are three different intermediate shafts to cope with the same problem.i see you are going to attempt a startup.donot pull dist down with clamp and try to start. The dist will seize because of too much end loading and sometime breaks the cam and dist gear. Dont ask me how i know this. Hope this helps
  30. Thorkle Rod
    Thorkle Rod
    37.5 Nailed it perfectly. I experianced the exact same thing with a Nova pump and shaft the Nova takes a shorter shaft. I had to go to 6 parts store to find the old grey haired man that new this, dropped in the new shaft and never looked back.
