Customs 35 Ford 3-window build
Discussion in 'The Hokey Ass Message Board' started by Fomocokid, Oct 25, 2010.
  1. TomH
    TomH
    That's Gene's roadster on the lift, is he trying to get all the salt off??
    So the sedan door isn’t a direct fit, but with your expert skills it wasn't a problem. Looks good.
    Going to Watertown?
  2. Fomocokid
    Fomocokid
    from Rapid City
    Yes Gene was desalting that poor old roadster.
    I am planning on Watertown
  3. stlcrzn
    stlcrzn
    What???? No update? Planning on Watertown also.
  4. flatheadfever
    flatheadfever
    Wow what great work!
  5. Fomocokid
    Fomocokid
    from Rapid City
    between last night and tonight I cleaned the rust off of the upper quarters and the back of the roof. I also welded the patches into the inner door. I straightened the inner door as well. I just have to make the bottom of the inner door and i can put it in. I did some measuring and by the time i finish this door there will be about 17.5 feet of welding on it
    mgtstumpy likes this.
  6. oldman2
    oldman2
    Quick question, are you filling the top, or using the vinyl insert?
  7. Fomocokid
    Fomocokid
    from Rapid City
    I plan on filling the top. I would love a vinyl top. The channel around the opening it rusted out. I figure if I have to weld around most of it anyways I might as well fill it. It will be one less leak to worry about and it gives a little more of that custom look as well
  8. Fomocokid
    Fomocokid
    from Rapid City
    Tonight I replaced a piece at the top of the door that was badly bent. I made the bottom of the inner door and got it welded on. I have the inner screwed in right now with the bottom edge of the skin hemmed over. Just have to plug weld it in tomorrow night.
  9. oldman2
    oldman2
    Great job....Jim
  10. Fomocokid
    Fomocokid
    from Rapid City
    I got the inner door welded in tonight. I just have to gap the door once I fix the latch. I bought a better windshield frame this week. I fit the opening much better and it should be chromeable
  11. stlcrzn
    stlcrzn
    Looks great!!!!!
  12. six pack to go
    six pack to go
    from new jersey
    True save!!! AWESOME!
  13. fordb132
    fordb132
    from Norway
    Looking great...doing a wonderful job there.I would dress up the windshield frame in 0,5 mm 316 steel,instead of chroming it.Its nearly free and last forever.Easy to do also.
  14. TomH
    TomH
    Holy **** Kellan, I think fordb132 is the guy that made a coupe out of a beat-up sedan. ( calls himself a black smith, best dam black smith I ever saw ) maybe he can give you some pointers. All through looks like you’re doing fine.
  15. Fomocokid
    Fomocokid
    from Rapid City
    Sorry about the delay. Got a new camera but it takes a different memory card. I need to get a card reader and then I will get pics up for you guys
  16. Fomocokid
    Fomocokid
    from Rapid City
    Here is what I have been up too. I brought a bunch of my parts down to rapid city on Labor Day. I took all the trim off of the hood and I took the hood apart. I brought an extra firewall to help repair mine. I have garnish moldings and door tops off of a 4-door to help with the chop. I took my inner fenders out of the old fenders over the weekend. I took the rear window regulator apart. I took the new windsheild frame apart.
  17. Fomocokid
    Fomocokid
    from Rapid City
    I also have a roof section off of the 4-door. I started by removing all the tack strips, header panel and weather stripping. I took all of the lead out of it. I then drilled the spot welds and took all of the inner structure out of it.
  18. Fomocokid
    Fomocokid
    from Rapid City
    When I was home I lucked out and got 3 16 inch wheels Ive been looking for. I got the tires off of them at work and it turned out I had 3 different widths. I have a 4", a 4.5", and a 5". Then I got another 4.5" from Jamie. Still looking for another 4" or 5"
  19. stlcrzn
    stlcrzn
    Nice wheels, almost went to the s**** pile! I will check for one more tomorrow.
  20. Fomocokid
    Fomocokid
    from Rapid City
    Today I took the door latch apart. I fixed the broken striker. I fixed the slightly bent pull rod for the inner door handle. I then gapped the front and back of the door
  21. Fomocokid
    Fomocokid
    from Rapid City
    Here are some better quality pics of the car now that I finally have a camera again
  22. stlcrzn
    stlcrzn
    more top quality work!!!!!
  23. oldman2
    oldman2
    That thing is really coming together nice, excellent work.....Jim
  24. Fomocokid
    Fomocokid
    from Rapid City
    Today I took the female dovetail out. I repaired it and welded it back in. I then put the replacement femail dovetail in. I put the male dovetail on the door. I also put the male dovetail on the p***enger door
  25. billylo
    billylo
    Looking good. Keep up the good work.
  26. TomH
    TomH
    Missed ya at Wartertown this year!!
  27. Retro61
    Retro61
    Nice! Keep posting, Enjoy the Build!
  28. farmer12
    farmer12
    This is one awesome car, keep up the great work! You know we're all watching you! :D
  29. Fomocokid
    Fomocokid
    from Rapid City
    I bought a heater at a swap meet over the weekend. I took it apart and blasted everything. Does anyone know what exactly it is out of? Im thinking late 40's to early 50's Ford PU. I got all of my other parts back from the blaster today as well
  30. TomH
    TomH
    Did it come with a core??
