Projects My 1950 Chevy Styleline DeLuxe
Discussion in 'The Hokey Ass Message Board' started by LeftCoastErik, May 7, 2011.
  1. LeftCoastErik
    LeftCoastErik
    CHOP UPDATE!
    It happened today, the lid got lopped. I think this is decent progress for day 1. HUGE thanks to Logan for spending the day and making sure I didn't screw too much up. I'll be working on the catwalk and the sail panels tomorrow.
  2. LeftCoastErik
    LeftCoastErik
    more
  3. LeftCoastErik
    LeftCoastErik
    pics
  4. LeftCoastErik
    LeftCoastErik
    sorry these are out of order!
  5. tylerbrasher
    tylerbrasher
    pretty nice looking chop!
  6. LeftCoastErik
    LeftCoastErik
    Thanks man! We ended up with about 3"/4". I thought I might want more, but we stuck the door tops and window opening in there and I really like the proportions of the window area to the body.
    Today I have to mess with the beltline below the window and try to get that all tacked in. The on to cutting the sail panels out and making new ones. With my buddy's help, that whole chop took place in about 9 hours.
  7. LeftCoastErik
    LeftCoastErik
    More pics from today. I cut the beltline trim land from the body and moved it up to the bottom of the window. Then I pie cut the corners and moved them up. I test fit the trim back in place and it looks like it should work. Just have to trim and cap the forward edges of the trim.
    Got my marks made to cut the sail panels out. I think I am going to fill in the catwalk first to make everything as sturdy as possible before I cut out the sail panel.
  8. LeftCoastErik
    LeftCoastErik
    Thanks Sean. I am crapping my pants a little about making the sail panels, but I guess its only metal and I gotta give it a try..
  9. LeftCoastErik
    LeftCoastErik
    Got some more done today. Made the filler for the catwalk and got it installed, tacked it to the window frame, made the fillter for the bottom of the c-pillar and cut out the crown piece. Made a pattern for the hole, just have to cut a couple of new pieces and start fitting them up.
  10. robleticia
    robleticia
    Looking good Erik!
  11. LeftCoastErik
    LeftCoastErik
    This week I made it to the shop by 6:15 every morning to get an hour or so in on the car. I just don't have the energy after a full day, so this is working. I got the passenger's sail panel pretty much done, I think it needs one more relief cut to soften the crown and make the transition smoother. I am kind of winging it, but its looking pretty decent to me.
    The driver's side went MUCH faster and easier than the passenger's side....I had a little better idea of what I was trying to do and managed a tighter fitting panel. Got most of that tacked in today. Going to work on finishing the tack and shaping the sails, then on to the package tray.
    Logan should be out this week to help me with the B Pillars, window frames and rear quarter openings.
  12. Looks good the more I see you guys wacking the roofs on your chevies the more I want the same for my Buick . It will come but I have to get the car together from the back to the midway point of the car at least before I cut up the roof .
  13. LeftCoastErik
    LeftCoastErik
    OK, so over the last few days, I have been fingerfucking the panels I made and they look great from almost every angle..except one. Without an english wheel I think I am screwed on how they look. SOOOO....I fortunately kept the pieces I cut out. I tweaked them so that I have some of the crown that the new pieces were lacking. Robleticia, I am going to take a page from your build thread and relief cut the metal that I have, make a little tweak in the angle of the rear window and try again.
    I'll get some pics up after a marathon day tomorrow...>Arggggg.. I guess this is what they call experience, right?
    Any HAMBers wanna help me out tomorrow??
  14. LeftCoastErik
    LeftCoastErik
    Today, Danny and I got the old crown pieces back in place, and Brian helped is figure out where to make new pieces, etc. We got a new center section made and installed.
    We tacked everything in, relief cut what we needed to, beat it into submission, then started stiching it up. Danny used his baby TIG and I used the MIG on the other side. We were able to do a ton without any significant warpage. I think its starting to look pretty sweet!
      499.2 KB
      496.2 KB
      491 KB
  15. LeftCoastErik
    LeftCoastErik
    Some more pics here. ALSO..Sport brought by some '49 Buick Roadmaster Tail Lights to check out. I LOVE them! Going to trim the bottom off the bezel and then french them just a bit. I think I will use some round rod on the top of the fender to peak it into the peak on the tail light. REALLY cool, I am excited.
      490.9 KB
      485.5 KB
      495 KB
      489.6 KB
  16. LeftCoastErik
    LeftCoastErik
    More progress tonight..Got almost all of the stitching up completed. Tomorrow morning I'll do the rest and do some grinding, then on to some shaping up and hopefully I can call that part "ready for duraglass"
  17. robleticia
    robleticia
    Looking good Erik! Alot of welding huh? Its alot of weld grind repeat! But its worth it. Now hurry up and roll that baby outside so we can get a good side profile shot.
  18. LeftCoastErik
    LeftCoastErik
    Yeah. and to think I couldn't weld at all a month ago....I should get it outside later this week and get a bunch more pics.
  19. 35mastr
    35mastr
    from Norcal
    Some how I missed this one. The car is looking good Erik.
  20. sledbuilder
    sledbuilder
    damn! you move quick.
  21. LeftCoastErik
    LeftCoastErik
    Thanks guys! I am kinda OCD when I get into a project. Once I have a goal, I'll work like a dog to make it happen. Plus I a learning a bunch of new skills (or butchering techniques, depending on who you ask) and that keeps me energized.
  22. LeftCoastErik
    LeftCoastErik
    Cool, where are your pics man? Let's see what your up to
  23. Jroc0801
    Jroc0801
    from Katy Tx
    bad ass ride i got a 52 i wish i had the time to finish it your cars in great shape love the way its looking keep up the good work
  24. rat seeker
    rat seeker
  25. LeftCoastErik
    LeftCoastErik
    The sails are all stitched up. The ones I made were too flat on the back, I couldn't get two curves into the metal with my lack of skills and tools. So I used the old pieces and made new filler pieces. I think it looks pretty good, I may need to relieve it in one or two spots and knock it down, but we'll see.
    Mine is pretty ugly right now, but they keep telling me thats what Bondo is for...
  26. LeftCoastErik
    LeftCoastErik
  27. Very cool project, all the right parts, love the 6-popper, I wish mine still had one! TTT somebody help this man!
    James
  28. LeftCoastErik
    LeftCoastErik
    Today was a good day. Got the rest of the roof stripped, finished the stitching, got most of the package shelf reattached and finally got the thing outside for a look.
    I also tried metal shrinking for the first time and it worked out great. Had some oil canning in the roof and managed to get rid of it.
    Going to get the pillars and some muddin done this week.
  29. LeftCoastErik
    LeftCoastErik
    some more pics!
  30. steve14733
    steve14733
    very nice job looks great
