1963 lincoln motor ideas
Discussion in 'The Hokey Ass Message Board' started by noxided, Oct 18, 2010.
  1. noxided
    noxided
    Well i havent bought the car yet, still looking, thats why im doing my reserch on here first. apreciate it though, ill keep your #
  2. Parts48
    Parts48
    from Tucson, Az
    Hey..they are retiring the Space Shuttle..maybe you could get cheap spare parts..
  3. Maybe you should buy a different car for a first project.
  4. LincolnLars
    LincolnLars
    from Sweden
    hmmm.. I did put a 350 Olds +th350 in my first low-low-budget-build 61 Conti,since I bought it cheap without engine,and did have some junk layin around. Tons of work,poor acceleration. Wouldnt recommend anythin else than a BB,preferally a MEL.
  5. X38
    X38
    Maybe a diesel?
  6. 61TBird
    61TBird
  7. toddc
    toddc
  8. nocoastsaint
    nocoastsaint
    Send that Lincoln our way, with the webers you want to run and I will make you an intake. And it -will- be 'de-cluttered'.
  9. das858
    das858
    POST #66, and#67, funny,funny ****!
  10. noxided
    noxided
    this will be about my 12th project, thank you though.
  11. mart3406
    mart3406
    from Canada
    Ditto on that. Seriously -Please, sell the
    Lincoln to someone who can and will do
    something proper with it. I don't mean
    to put you down, but If you're actually
    serious, this is one of most ridiculous
    queries I've ever seen posted on the
    HAMB. You don't seem to have even a
    basic understanding of engines - re what
    type and size and characteristics are
    required to pull a 5500-plus lb. car around
    or what certain mods cost or even actually
    do to the characteristics of an engine. First,
    a 302 Ford with Webers - and the appropriate
    cam and heads you'd need to properly use
    them, would make for a peaky, high rpm
    engine with lots of high rpm horsepower, but
    little or no usable low end torque. That kind
    of engine works well in a very light car with
    low rear end gears and 4 or 5 speed *manual*
    transmission that will allow the engine to run
    at high rpms and stay in a very narrow
    high-rpm power band. It's absolutely the exact
    opposite of the type of engine a 'cruiser' 5500 lb.
    '63 Lincoln needs. Why do you think they used a
    big, 430 cubic inch engine with lots of compression
    and a mild cam in them from the factory in
    the first place?? It wasn't because they liked
    the sound of the number "430" or that they
    were short of high rpm 'screamer' small blocks
    to put in them! They used a relatively mildly
    tuned, big bore and long stroke, 430 cubic inch
    engine because that's the type of engine
    required to make enough and low and mid
    range torque to adequately move a car that
    big. Secondly, you say you can't afford to rebuild
    the original 430 engine? Just so you know, just
    an intake and 4 Weber carbs alone will cost you
    more than rebuilding the 430. Add to the that, the
    cost of building or buying a 302 with enough cam
    and head work to use the Webers and for what??
    So you can have a complete dog to drive????
    Mart3406
  12. Reijer
    Reijer
    By the way, the late fifties MELs were designed with racing in mind. They were actually tuned down for street cars. The first ('58) model was still found to be too powerful so the '59 model was subsequently altered.
  13. mart3406
    mart3406
    from Canada
    Probably not "too powerful"....just too
    peaky and rough running at low and medium
    speeds for a luxury car. There's no such thing
    as too much power!:D
    Mart3406
  14. Reijer
    Reijer
    Well... not a**** this crowd, obviously. But consider the people who bought these cars new. Not quite the street racing type, I believe.
  15. lostforawhile
    lostforawhile
    unless you put it in a model A of course :D
    here's some inspiration for you, dual exaust with dual cherry bombs, dam this sounds good on one http://www.youtube.com/watch?v=HWBoUPhAO3c&feature=related
  16. noxided
    noxided
    thats why i posted on here. I knew nothing about 430's ad now i do and i see thats the only way to go. I appreieate all the positive and hepful comments and as for the others... go screw yourselfs.
  17. studhud
    studhud
    I really dont get it?
    check this
    http://www.jalopyjournal.com/forum/showthread.php?t=525967
    Dave Hitch
  18. davidp2364
    davidp2364
    Were did you get your 3x2 I want one cant seem to find one and the Mel 430 is the only way to go!!!!!
  19. davidp2364
    davidp2364
    Well I have a 63 Linc and I need parts anyone know were to find a 3x2 for my car
    Oh and DON'T BUY A 63 IF YOU WANT TO CHANGE ENGENS?
  20. petemonster
    petemonster
    from Minnesota
    Use a 4-53 detroit turbo diesel or a CATc7
  21. marc Henderson
    marc Henderson
    Not sure if you are still here but I live in Montgomery also. Join suicideslabs fb page plenty of people have done coyote Ls, and diesel swaps. Be interested in what you did.
