1957 Chevy Trans. search...
Discussion in 'The Hokey Ass Message Board' started by sledbuilder, Sep 6, 2011.
  1. sledbuilder
    sledbuilder
    hey guy's... i'm on the hunt for a 57' chevy 3 speed trans. however i'm looking specifically for a close ratio...i think they came in the "high performance" cars and possible the corvettes.. Id also be interested in any info on how to identify these models from the standard ratio trans.
    thanks!
  2. Thumper
    Thumper
    Good luck with that search.......those old saginaws are tougher to find than a good lookin 40 year old virgin..:rolleyes:
  3. all I have is a rebuilt 3 speed OD that I'm saving till Gas prices go up lol
  4. Mike Morand
    Mike Morand
    You need a close ratio gear set. They will fit into a standard 3 speed case. Try Gary Pronesti at Pronesti Cl***ics in Florida.
  5. sledbuilder
    sledbuilder
    hey mike, i actually have a standard 3 speed complete... i'll look into getting the gears! thanks guys.
  6. Hmmm, I just picked up a '57 3 speed at Brad's swap last Sat- will have to see if it's a close ratio or not :)
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    There were actually three ratio spreads for the '55-'65 Muncie non-syncro three speeds. The 6 cylinder trans had a low gear ratio of 2.94:1, V8s were 2.47:1, and the close ratio 'vette transmission was 2.21:1.
  8. jipp
    jipp
    no shortage of them 40 year old virgin types in prison these days.
    chris.
  9. jipp
    jipp
    while we are on the subject of 57. for some reason in the back of my melon i remember a factory hotrod if you will code named "widow maker" my memory says it was a factory 4 speed, black/white... fuel injected and bad to the bone.. did i make this car up out of the blue or did GM build this car that the engineer nick named "widow maker". if they did i bet she is worth a pretty penny ***uming she is still stomping asphalt.
    chris.
  10. HEATHEN
    HEATHEN
    from SIDNEY, NY
    That's "black widow", and they still used three speed transmissions.
  11. Deuce Roadster
    Deuce Roadster
  12. sledbuilder
    sledbuilder
    oh yes...that is the baddest of the bad....at least in my book. 6 lug wheels..killer!
  13. sledbuilder
    sledbuilder
    is there anyway to tell the ratio with out opening the side cover? grooves on the input shaft or casting number?
    thanks again!
  14. HEATHEN
    HEATHEN
    from SIDNEY, NY
    No, but if the trans still turns, you can always put it in low gear, mark the input and output shafts with a tire crayon, and count the revolutions.
  15. jipp
    jipp
    thank you.. thats one sweet ride. pure poison.
    chris.
